SSLM: Configuring multi-tier certificates issues
sgonsalv
Level 3
Level 3
Hi Guys,
Wanted to know what was the preferred or Cisco accepted way to install / configure multi-tier certificates on the SSL module?  When reading the config guide, it discusses in detail how to handle a single tier cert (i.e just a root ca cert), however there is no real example for handling multi-tier certs (i.e. a root ca cert and an intermediate cert)..
As an example, we've always installed a multi tier cert the following way:
! Setup the main trustpoint which contains the subject name
crypto pki trustpoint DIRECTORY
  enrollment terminal
  fqdn directory.monash.edu.au
  subject-name C=AU, ST=Victoria, L=Clayton, O=Monash University, OU=ITS, CN=directory.monash.edu.au
  revocation-check none
  rsakeypair DIRECTORY
! Setup a trustpoint for the Root certificate
crypto pki trustpoint DIRECTORY-Root
  enrollment terminal pem
  crl optional
! Setup a trustpoint for the Intermediate certificate
crypto pki trustpoint DIRECTORY-Intermediate
  enrollment terminal
  crl optional
! Enroll the trustpoint DIRECTORY for the CSR
! Obtain signed cert from CA (Thawte)
! Authenticate DIRECTORY-Intermediate using the intermediate cert
crypto pki authenticate DIRECTORY-Intermediate
<paste intermediate cert>
! Authenticate DIRECTORY-Root using the root cert
crypto pki authenticate HYBRID-Root
<paste root cert>
! Authenticate DIRECTORY using the root cert
<paste root cert>
! Import signed cert against DIRECTORY
crypto pki import DIRECTORY cert
<paste signed cert>
This has always worked fine, until recently we've noticed on one of our SSL modules, that we get the following error when authenticating the intermediate cert against DIRECTORY-Intermediate
Trustpoint 'DIRECTORY-Intermediate' is a subordinate CA.
Authentication failed - could not validate certificate% Error in saving certificate: status = FAIL
Hence i can't continue to install the rest of the chain.  Am going to chase this up via TAC, however i wanted to post this here just to know whether there is anything that immediately sticks out to people, as far as the procedure we follow or anything else?
thanks
Sheldon
6 Replies 6
cschneid
Sheldon,
Not sure if you've seen this document but it covers an example of installing a multi-tiered
cert install on the SSLM:
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_configuration_example09186a008037d1c8.shtml
Maybe go through this step-by-step and if you run into any problems then open
a TAC case for assistance.
Good luck!
-Chip
mjuch
Level 2
Level 2
Hello Sheldon, if you forget "revocation-check none" within the root trustpoint the validation failed even the root Cert is valid. In debug (for IOS PKI) crypto pki validation you can see
Oct  4 07:35:13.496: CRYPTO_PKI: Checking certificate revocation
Oct  4 07:35:13.496: CRYPTO_PKI: Matching CRL not found
and the validation failed with
br Mike
hi Sridhar,
I found this link which explains
" Authenticating the Three Certificate Authorities (One Root And Two Subordinate Certificate Authorities)":
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ssl/2.1/configuration/guide/config.html#wp1201447
is this what you were looking for ?
Rajesh.
Thank you for the link Suresh, the section "
Example of Importing PEM Files for Three Levels of Certificate Authority" does cover the mulitiple CA installation, but when I followed this, I did root CA installation, the cert got authenticated. I created trustpoint for first intermediate CA and then tried authenticating it threw me an error saying this
Trustpoint "XXXXXXXX' is a subordinate CA.
I have masked trustpoint name with XXX.
Still not understanding how to authenticate the CAs including the root.
Sridhar
marinogr
Level 3
Level 3
It is very important the order of Chain cert  (RootCA->SubCA->Cert):
crypto pki authenticate DNAC-CA
-----BEGIN CERTIFICATE-----
RootCA
-----END CERTIFICATE-----
SubCA
Cert
quit
Certificate has the following attributes:
Fingerprint MD5: "omitted"
Fingerprint SHA1: "omitted"
% Do you accept this certificate? [yes/no]: yes
Trustpoint CA certificate accepted.
% Certificate successfully imported
jackjame6es
Community Member
That’s a solid walkthrough of multi-tier certs! While you troubleshoot the SSL module, I’ve been exploring some secure setups and testing features over at Golo777 their platform handles certificates and secure connections really smoothly.
