Switching capacity of Nexus 7010 Switch
How "show inventory" command helps to calculate the Switching capacity of Nexus 7010 switch?
Is there any other command or way to calculate the switching capacity of switch?
Thanks & regards,
Muhammad Hamid Ashraf
InayathUlla Sharieff
Hamid,
few commands are there...which can help you in what you want to see.
http://www.cisco.com/en/US/docs/switches/datacenter/sw/4_2/nx-os/system_management/command/reference/sm_cmd_show.html#wp1324326
Inayath
Hi Inayat,
Thanks for the response. I already knew it but wanted to have some accurate answer.
Thanks again
