03-01-2016 05:35 AM
Good Morning!
You can perform traffic shaping configuration on the Nexus 7000 and set the IP source and destination? What would be the setup to do?
03-01-2016 07:39 PM
I don't know the answer, but found this post.
https://supportforums.cisco.com/discussion/11008441/nexus-7k-egress-traffic-shaping
Jeey Ye says:
Looks like you want to configure some type of MQC shaping in the N7K. The only shaping that is supported in the N7K is Shaped Round Robin (SRR) on the egress port. The shaping is based on COS value where the COS are mapped to queues and each queue is given a specific rate. Here is an example on N7K shaping from NXOS 4.2
03-02-2016 06:24 AM
Philip, thanks for the answer.
03-02-2016 11:10 AM
If you think it was helpful it would be great if you could rate and mark it as an answer. :-)
