WAAS IP ACL not matching traffic
i'm trying to configure some ip access-lists on a WAAS but it seems that it's not matching the traffic.
interface InlineGroup 1/0
inline vlan all
ip access-group test in
exit
ip access-list extended test
deny icmp any any
exit
Im still able to ping wherever i want.
Any ideas? Or is it not possible to handle traffic with ACLs like that on WAAS?
Markus
rajsures
Hi Markus,
Interface ACL—Applied on the built-in, port channel, standby, and inline group interfaces. This type of ACL is intended to control management traffic (Telnet, SSH, and Central Manager GUI). The ACL rules apply only to traffic that is destined for the WAE or originates from the WAE, not WCCP transit traffic. Use the
ip access-group interface configuration command to apply an interface ACL.
As explained above the ACL rule apply only to traffic destined to the WAE or originated from the WAE and not for transit traffic. Hope this helps.
Rajesh
rajsures
Hi Markus,
Rajesh
Thanks Rajesh,
thanks for the explanation. Thats the info i was searching for.
Best,
Markus
