WAE without CM
josephschung
Sir,
We have two WAEs registered with CM already and optimizing traffic. Now, after some routing change, one of the WAE cannot access the CM anymore. Will it keep on optimizing traffic without accessing the CM?
Hi Joseph,
Even though you can perform some of this below from the CLI, it would be difficult to :
  • Monitor and maintain the WAAS system
  • deploy or change policies etc.
If your running with certificates or secure store, it would be almost impossible,
So I really suggest that you change the routing or get the problem fixed otherwise.
Best regards
Finn Poulsen
finn.poulsen
Level 3
Level 3
Hi Joseph,
Yes, if the two accellerators both still are in the data path, optimization will continue.
If you can telnet/ssh into the WAAS units, issue "show statistics conn" to verify.
Best regards
Finn Poulsen
Thanks Finn.
Do you know what will be the impact for the WAAS units that cannot access the central manager any more?
Thanks.
Joseph
Hi Joseph,
Best regards
Finn Poulsen
