WCCP Issue
c.walsh
Level 3
Level 3
We have an issue with WCCP on a 2811 router with an NM-WAE 502.
Has anyone seen this error ?
Nov 30 10:14:50.595: %WCCP-1-SERVICELOST: Service 61 lost on WCCP client 10.2.100.250
Nov 30 10:14:50.595: %WCCP-1-SERVICELOST: Service 62 lost on WCCP client 10.2.100.250
Colin
6 Replies 6
Phillip Hichens
Hi Colin
This is an indication of WCCP communication loss between the router and the WAE.
Can you post your WCCP config for the router and WAE.
To what interface does 10.2.100.250 belong? Do you have a loopback on the router?
Cheers
Phillip
router config...
ip wccp 61 redirect-list wccp_redirect
ip wccp 62 redirect-list wccp_redirect
ip cef
ip inspect log drop-pkt
ip inspect WAAS enable
ip inspect name internet tcp
ip inspect name internet udp
ip inspect name internet ftp
ip inspect name Internet udp
ip inspect name Internet tcp
ip inspect name Internet icmp
ip inspect name Internet telnet
ip inspect name Internet ssh
ip inspect name Internet ftp
ip inspect name Internet http
ip inspect name Internet https
ip inspect name Internet tftp
no ip domain lookup
interface Loopback0
ip address 109.204.113.145 255.255.255.248
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 10.2.1.254 255.255.255.0
ip wccp 61 redirect in
ip wccp 62 redirect out
ip nat inside
ip virtual-reassembly
interface FastEthernet0/0.2
encapsulation dot1Q 2
ip address 10.2.2.254 255.255.255.0
interface FastEthernet0/1
description Connection to BT Wholesale EFM 10Mb
ip address 109.204.113.246 255.255.255.252
ip access-group outside-in in
ip inspect internet out
ip nat outside
duplex full
speed 10
crypto map vpn-access
interface Integrated-Service-Engine1/0
ip address 10.2.100.1 255.255.255.0
ip wccp redirect exclude in
ip nat inside
service-module ip address 10.2.100.250 255.255.255.0
!Application: Restarted at Sat Jun 24 10:10:58 2006
service-module ip default-gateway 10.2.100.1
no keepalive
router bgp 65530
no synchronization
bgp log-neighbor-changes
network 109.204.113.144 mask 255.255.255.248
neighbor 109.204.113.245 remote-as 20500
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 109.204.113.245 200
ip route 94.195.246.11 255.255.255.255 109.204.109.229
i
ip access-list extended wccp_redirect
permit ip 10.1.0.0 0.0.255.255 10.2.1.0 0.0.0.255
permit ip 10.2.1.0 0.0.0.255 10.1.0.0 0.0.255.255
permit ip 10.2.100.0 0.0.0.255 10.1.0.0 0.0.255.255
permit ip 10.1.0.0 0.0.255.255 10.2.100.0 0.0.0.255
NM-WAE config...
primary-interface GigabitEthernet 1/0
no autosense
bandwidth 1000
full-duplex
exit
interface GigabitEthernet 2/0
shutdown
exit
no auto-register enable
! ip path-mtu-discovery is disabled in WAAS by default
ip name-server 10.1.8.1
ntp server 10.1.9.254
bypass static 10.2.4.7 any-server
wccp router-list 1 109.204.113.145
wccp tcp-promiscuous router-list-num 1
wccp version 2
egress-method generic-gre intercept-method wccp
transaction-logs flow enable
windows-domain netbios-name "LON-WAAS-NM"
authentication login local enable primary
authentication configuration local enable primary
crypto ssl services global-settings
   version all
   exit
Hi Colin,
Generic GRE as the return method (egress method) is not recommended by an ISR router, but only on Cat 6500/Cisco 7600.
Check this URL :
http://www.cisco.com/en/US/prod/collateral/contnetw/ps5680/ps6870/white_paper_c11-608042.html
What IOS version is the router running ?
What WAAS software are you using ?
Is the WCCP lost situation permanent or did it come up immediately after ?
Best Regards
Finn Poulsen
Bhavin Yadav
Hi Colin,
As earlier user pointed out, this is a communication failure between NME and the router. As this is an NME module, is this doing WCCP with 2811 itself (local 2811 where NME is installed?). If yes, there may be something else.
But if the router is not local NME module, this is clearly communication failure between NME and the router - 109.204.113.145.
If this is still down, try pinging WCCP router from NME and vice versa. These kind of issues can be caused by routing changes, ip address changes, etc. Please make sure router and NME can talk to each other over UDP port 2048.
Regards.
PS: Please mark this as Answered, if this answers your question.
c.walsh
Level 3
Level 3
All,
     Thanks for your help & advice, but i have now opened up a service request with Cisco TAC as this is not a config issue!
Thanks for the update, Colin. Please share the resolution with us, if you can.
Regards.
