What happen when SSL daughter card fails?
andrea.meconi
Level 2
Level 2
I'm using two CSM with SSL duaghter card with redundancy.
What happen if the card fails? CSM fails too?
Thanks.
Andrea
Gilles Dufour
The CSM will most of the time fail as well.
Gilles.
mchin345
Level 6
Level 6
When the SSL daughter card failure is detected, the SSL daughter card is restarted causing all SSL flows to fail, and they will need to be re-established.
During a supervisor engine switch over, the standby CSM-S fails to initialize and the new standby supervisor engine prints the following message for all CSM-S ports:
%PM-STDBY-4-INT_FAILUP:GigabitEthernet7/2 failed to come up.No internal VLAN available
Thanks.
But I don't understand if when SSL card fails, CSM fails too; so active CSM becomes standby.
Regards.
Andrea
Gilles Dufour
Gilles.
