WLC IP (Vlan3047) can not ping tunnel IP in same VRF in the same switch
ArvindSoni3117
I have two switch configured for same VRF and EIGRP routes are being exchanged through GRE Tunnel.
WLC is connected to Switch A in same VRF and can ping its Switch HSRP IP, But WLC not able to ping Switch A Tunnel IP address.
However, WLC IP can be ping from Switch B and Switch A.
Need help in this regard.
WLC ----> Switch A (byod )   ---------EIGRP ( GRE )----------- Switch B ( byod)
Switch Vlan3047 ( 10.74.16.2 255.255.248.0)
Lo1 Int on Switch - 1.1.1.1 (No VRF)
WLC IP - 10.74.16.10
WLC GW - Switch HSRP IP -10.74.16.1
Switch Vlan and Tunnel Config
______________
interface Vlan3047
description byod
ip vrf forwarding byod
ip address 10.74.16.2 255.255.248.0
standby 0 ip 10.74.16.1
standby 0 priority 110
standby 0 preempt
standby 0 track 2 decrement 40
logging event link-status
no snmp trap link-status
interface Tunnel 2
ip vrf forwarding VRF A
ip address 10.74.0.181 255.255.255.252
no ip redirects
tunnel source Loopback1
tunnel destination 10.74.254.37
0 Replies 0
