Voice gateway can not sent call to cell phone number
1290
Md.soriful
Beginner
Community Live (Formerly known as Webcast)
thru
Can not reach to local cell phone number but can reach to international number. Is it dial peer issue?
Calling no: 11230
Called no: 01988833070
Result: cant reach
no debug voip ccapi inoutdebug voip ccapi inout debug voip ccapi inout debug voip ccapi inout d
voip ccapi inout debugging is on
CTG-RT-01#ter mi oni
CTG-RT-01#deb
CTG-RT-01#debug voi
CTG-RT-01#debug voip
CTG-RT-01#debug voip dia
CTG-RT-01#debug voip dialpeer in
CTG-RT-01#debug voip dialpeer inout
Sep 16 06:37:14.310: //-1/0D38CE800001/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=11219
----- ccCallInfo IE subfields -----
cisco-ani=sip:11219@172.16.7.71
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=sip:01941300400@9.9.9.36:5060
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFFFFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
Sep 16 06:37:14.310: //-1/0D38CE800001/CCAPI/cc_api_call_setup_ind_common:
Interface=0x7F8189EC5CC8, Call Info(
Calling Number=sip:11219@172.16.7.71,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=sip:01941300400@9.9.9.36:5060(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=1100, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=1336
Sep 16 06:37:14.310: //-1/0D38CE800001/CCAPI/ccCheckClipClir:
In: Calling Number=sip:11219@172.16.7.71(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Out: Calling Number=sip:11219@172.16.7.71(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Sep 16 06:37:14.310: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 16 06:37:14.310: :cc_get_feature_vsa malloc success
Sep 16 06:37:14.310: cc_get_feature_vsa count is 1
Sep 16 06:37:14.310: :FEATURE_VSA attributes are: feature_name:0,feature_time:140194363926860,feature_id:622
Sep 16 06:37:14.311: //1336/0D38CE800001/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown))
Sep 16 06:37:14.311: //1336/0D38CE800001/CCAPI/cc_process_call_setup_ind:
Event=0x7F818B451968
Sep 16 06:37:14.311: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 01941300400
Sep 16 06:37:14.311: //1336/0D38CE800001/CCAPI/ccCallSetContext:
Context=0x7F819C4BC480
>>>>CCAPI handed cid 1336 with tag 1100 to app "_ManagedAppProcess_Default"
Sep 16 06:37:14.312: //1336/0D38CE800001/CCAPI/ccCallProceeding:
Sep 16 06:37:14.313: //-1/xxxxxxxxxxxx/CCAPI/ccGetMemPoolFromContainer:
mempool not found from usrContainer(7F819C2BFD00)
Sep 16 06:37:14.313: //-1/xxxxxxxxxxxx/CCAPI/ccCreateMemPoolInContainer:
Mempool(7F8184A0C320) created in usrContainer(7F819C2BFD00)
Sep 16 06:37:14.313: //1336/0D38CE800001/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=3, Params=0x7F819C4BDBA8, Progress Indication=NULL(0)
Sep 16 06:37:14.313: //1336/0D38CE800001/CCAPI/cc_fill_tg_params:
Not a cic call
Trunk Group Select Interface Success;
Interface=0x7F818EA07E98, Selected Interface=1, Selected DSL=-1
Sep 16 06:37:14.313: //1336/0D38CE800001/CCAPI/ccCheckClipClir:
Destination Pattern=[0,2,3,9,8,7,6]T, Called Number=01941300400, Digit Strip=TRUE
Calling Number=sip:11219@172.16.7.71(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=01941300400(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=Shibu-AM-IT 11219
Account Number=11219, Final Destination Flag=TRUE,
Guid=0D38CE80-0001-0000-0001-37E1470710AC, Outgoing Dial-peer=3
Sep 16 06:37:14.313: //1336/0D38CE800001/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=01941300400
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Sep 16 06:37:14.314: //1336/0D38CE800001/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x7F818EA07E98, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=sip:11219@172.16.7.71,(Calling Name=Shibu-AM-IT 11219)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=01941300400(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=3, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=FXO, tg_label_flag=2, Application Call Id=)
Sep 16 06:37:14.314: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 16 06:37:14.314: :cc_get_feature_vsa malloc success
Sep 16 06:37:14.314: cc_get_feature_vsa count is 2
Sep 16 06:37:14.314: :FEATURE_VSA attributes are: feature_name:0,feature_time:140194363926636,feature_id:623
Sep 16 06:37:14.314: //1337/0D38CE800001/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Sep 16 06:37:14.314: //1336/0D38CE800001/CCAPI/ccCallSetupRequest:
Trunk Group Call Setting;
Call Entry(Retry Count=0, Voice Class Cause Code=0)
Sep 16 06:37:14.314: //1337/0D38CE800001/CCAPI/ccCallSetContext:
voip dialpeer inout debugging is on
CTG-RT-01#Context=0x7F819C4BDB28
Sep 16 06:37:14.314: //1336/0D38CE800001/CCAPI/ccSaveDialpeerTag:
Sep 16 06:37:14.314: //1336/0D38CE800001/CCAPI/cc_api_modify_tgt_cid_call_active_record:
Target Trkgrp Route Label=FXO, tg_label_flag=TRUE, Call Id=0x538
Sep 16 06:37:14.316: //1337/0D38CE800001/CCAPI/cc_api_call_proceeding:
Interface=0x7F818EA07E98, Progress Indication=NULL(0)
Sep 16 06:37:15.575: //1337/0D38CE800001/CCAPI/cc_api_call_disconnected:
Cause Value=34, Interface=0x7F818EA07E98, Call Id=1337
Call Entry(Responsed=TRUE, Cause Value=34, Retry Count=0)
Sep 16 06:37:15.576: //1336/0D38CE800001/CCAPI/ccCallReleaseResources:
release reserved xcoding resource.
Sep 16 06:37:15.576: //1337/0D38CE800001/CCAPI/ccCallSetAAA_Accounting:
Accounting=1, Call Id=1337
Sep 16 06:37:15.576: //1337/0D38CE800001/CCAPI/ccCallDisconnect:
Cause Value=34, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=34)
Cause Value=34, Call Entry(Responsed=TRUE, Cause Value=34)
Sep 16 06:37:15.580: //1337/0D38CE800001/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F818EA07E98, Tag=0x0, Call Id=1337,
Call Entry(Disconnect Cause=34, Voice Class Cause Code=0, Retry Count=0)
tg for this call is FXO success/fail is 0
Call Disconnect Event Sent
Sep 16 06:37:15.580: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 16 06:37:15.580: :cc_free_feature_vsa freeing 7F818B42E860
Sep 16 06:37:15.580: vsacount in free is 1
Sep 16 06:37:15.580: //1336/0D38CE800001/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=1200, Params=0x7F819C4C3648, Progress Indication=NULL(0)
Sep 16 06:37:15.580: //1336/0D38CE800001/CCAPI/ccCheckClipClir:
Sep 16 06:37:15.581: //1336/0D38CE800001/CCAPI/ccCallSetupRequest:
Destination Pattern=.T, Called Number=01941300400, Digit Strip=FALSE
Guid=0D38CE80-0001-0000-0001-37E1470710AC, Outgoing Dial-peer=1200
Sep 16 06:37:15.581: //1336/0D38CE800001/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=01941300400
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Sep 16 06:37:15.581: //1336/0D38CE800001/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x7F8189EC5CC8, Interface Type=3, Destination=, Mode=0x0,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1200, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Sep 16 06:37:15.581: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 16 06:37:15.581: :cc_get_feature_vsa malloc success
Sep 16 06:37:15.581: cc_get_feature_vsa count is 2
Sep 16 06:37:15.581: :FEATURE_VSA attributes are: feature_name:0,feature_time:140194363926636,feature_id:624
Sep 16 06:37:15.582: //1336/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:15.582: cc_api_get_xcode_stream : 4983
Sep 16 06:37:15.582: //1336/0D38CE800001/CCAPI/cc_api_event_indication:
Event=101, Call Id=1336
Event Is Sent To Conferenced SPI(s) Directly
Sep 16 06:37:15.582: //1338/0D38CE800001/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Sep 16 06:37:15.582: //1338/0D38CE800001/CCAPI/ccCallSetContext:
Context=0x7F819C4C35C8
Sep 16 06:37:15.582: //1336/0D38CE800001/CCAPI/ccSaveDialpeerTag:
Sep 16 06:37:15.582: //1338/0D38CE800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:15.582: //1338/0D38CE800001/CCAPI/ccSetMediaclassIp2ipTags:
media class tags set: NR 0, ASP 0
Sep 16 06:37:15.582: //1336/0D38CE800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:15.582: //1336/0D38CE800001/CCAPI/ccSetMediaclassIp2ipTags:
Sep 16 06:37:15.582: //1338/0D38CE800001/CCAPI/ccGet_xc_nr_asp_info:
media class tags: NR 0, ASP 0
Sep 16 06:37:15.582: //1336/0D38CE800001/CCAPI/ccGet_xc_nr_asp_info:
Sep 16 06:37:15.582: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 1336
Sep 16 06:37:15.583: //1338/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:15.583: cc_api_get_xcode_stream : 4983
Sep 16 06:37:15.583: //1338/0D38CE800001/CCAPI/cc_api_call_proceeding:
Interface=0x7F8189EC5CC8, Progress Indication=NULL(0)
Sep 16 06:37:15.594: //1338/0D38CE800001/CCAPI/cc_api_call_disconnected:
Cause Value=38, Interface=0x7F8189EC5CC8, Call Id=1338
Call Entry(Responsed=TRUE, Cause Value=38, Retry Count=0)
Sep 16 06:37:15.594: //1336/0D38CE800001/CCAPI/ccCallReleaseResources:
Sep 16 06:37:15.594: //1338/0D38CE800001/CCAPI/ccCallSetAAA_Accounting:
Accounting=1, Call Id=1338
Sep 16 06:37:15.595: //1338/0D38CE800001/CCAPI/ccCallDisconnect:
Cause Value=38, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=38)
Cause Value=38, Call Entry(Responsed=TRUE, Cause Value=38)
Sep 16 06:37:15.595: //1338/0D38CE800001/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F8189EC5CC8, Tag=0x0, Call Id=1338,
Call Entry(Disconnect Cause=38, Voice Class Cause Code=0, Retry Count=0)
Sep 16 06:37:15.595: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 16 06:37:15.595: :cc_free_feature_vsa freeing 7F818B42E860
Sep 16 06:37:15.595: vsacount in free is 1
Sep 16 06:37:15.596: //1336/0D38CE800001/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=1201, Params=0x7F819C4C4CF0, Progress Indication=NULL(0)
Sep 16 06:37:15.596: //1336/0D38CE800001/CCAPI/ccCheckClipClir:
Guid=0D38CE80-0001-0000-0001-37E1470710AC, Outgoing Dial-peer=1201
Sep 16 06:37:15.596: //1336/0D38CE800001/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=01941300400
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Sep 16 06:37:15.597: //1336/0D38CE800001/CCAPI/ccIFCallSetupRequestPrivate:
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1201, Call Count On=FALSE,
Sep 16 06:37:15.597: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 16 06:37:15.597: :cc_get_feature_vsa malloc success
Sep 16 06:37:15.597: cc_get_feature_vsa count is 2
Sep 16 06:37:15.597: :FEATURE_VSA attributes are: feature_name:0,feature_time:140194363926636,feature_id:625
Sep 16 06:37:15.597: //1336/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:15.597: cc_api_get_xcode_stream : 4983
Sep 16 06:37:15.597: //1336/0D38CE800001/CCAPI/cc_api_event_indication:
Sep 16 06:37:15.597: //1339/0D38CE800001/CCAPI/ccIFCallSetupRequestPrivate:
Sep 16 06:37:15.597: //1339/0D38CE800001/CCAPI/ccCallSetContext:
Context=0x7F819C4C4C70
Sep 16 06:37:15.597: //1336/0D38CE800001/CCAPI/ccSaveDialpeerTag:
Sep 16 06:37:15.598: //1339/0D38CE800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:15.598: //1339/0D38CE800001/CCAPI/ccSetMediaclassIp2ipTags:
Sep 16 06:37:15.598: //1336/0D38CE800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:15.598: //1336/0D38CE800001/CCAPI/ccSetMediaclassIp2ipTags:
Sep 16 06:37:15.598: //1339/0D38CE800001/CCAPI/ccGet_xc_nr_asp_info:
Sep 16 06:37:15.598: //1336/0D38CE800001/CCAPI/ccGet_xc_nr_asp_info:
Sep 16 06:37:15.598: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 1336
Sep 16 06:37:15.598: //1339/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:15.598: cc_api_get_xcode_stream : 4983
Sep 16 06:37:15.599: //1339/0D38CE800001/CCAPI/cc_api_call_proceeding:
Sep 16 06:37:15.599: //1339/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:15.599: cc_api_get_xcode_stream : 4983
Sep 16 06:37:15.621: //1339/0D38CE800001/CCAPI/cc_api_call_disconnected:
Cause Value=1, Interface=0x7F8189EC5CC8, Call Id=1339
Call Entry(Responsed=TRUE, Cause Value=1, Retry Count=0)
Sep 16 06:37:15.621: //1336/0D38CE800001/CCAPI/ccCallReleaseResources:
Sep 16 06:37:15.621: //1339/0D38CE800001/CCAPI/ccCallSetAAA_Accounting:
Accounting=1, Call Id=1339
Sep 16 06:37:15.621: //1339/0D38CE800001/CCAPI/ccCallDisconnect:
Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=1)
Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
Sep 16 06:37:15.622: //1339/0D38CE800001/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F8189EC5CC8, Tag=0x0, Call Id=1339,
Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
Sep 16 06:37:15.622: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 16 06:37:15.622: :cc_free_feature_vsa freeing 7F818B42E860
Sep 16 06:37:15.622: vsacount in free is 1
Sep 16 06:37:15.623: //1336/0D38CE800001/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=1101, Params=0x7F819C4D0230, Progress Indication=NULL(0)
Sep 16 06:37:15.623: //1336/0D38CE800001/CCAPI/ccCheckClipClir:
Guid=0D38CE80-0001-0000-0001-37E1470710AC, Outgoing Dial-peer=1101
Sep 16 06:37:15.623: //1336/0D38CE800001/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=01941300400
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Sep 16 06:37:15.623: //1336/0D38CE800001/CCAPI/ccIFCallSetupRequestPrivate:
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1101, Call Count On=FALSE,
Sep 16 06:37:15.623: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 16 06:37:15.623: :cc_get_feature_vsa malloc success
Sep 16 06:37:15.623: cc_get_feature_vsa count is 2
Sep 16 06:37:15.623: :FEATURE_VSA attributes are: feature_name:0,feature_time:140194363926636,feature_id:626
Sep 16 06:37:15.624: //1336/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:15.624: cc_api_get_xcode_stream : 4983
Sep 16 06:37:15.624: //1336/0D38CE800001/CCAPI/cc_api_event_indication:
Sep 16 06:37:15.624: //1340/0D38CE800001/CCAPI/ccIFCallSetupRequestPrivate:
Sep 16 06:37:15.624: //1340/0D38CE800001/CCAPI/ccCallSetContext:
Context=0x7F819C4D01B0
Sep 16 06:37:15.624: //1336/0D38CE800001/CCAPI/ccSaveDialpeerTag:
Sep 16 06:37:15.624: //1340/0D38CE800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:15.624: //1340/0D38CE800001/CCAPI/ccSetMediaclassIp2ipTags:
Sep 16 06:37:15.624: //1336/0D38CE800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:15.624: //1336/0D38CE800001/CCAPI/ccSetMediaclassIp2ipTags:
Sep 16 06:37:15.624: //1340/0D38CE800001/CCAPI/ccGet_xc_nr_asp_info:
Sep 16 06:37:15.624: //1336/0D38CE800001/CCAPI/ccGet_xc_nr_asp_info:
Sep 16 06:37:15.624: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 1336
Sep 16 06:37:15.625: //1340/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:15.625: cc_api_get_xcode_stream : 4983
Sep 16 06:37:15.625: //1340/0D38CE800001/CCAPI/cc_api_call_proceeding:
Sep 16 06:37:15.626: cc_api_get_xcode_stream : 4983
Sep 16 06:37:15.643: //1340/0D38CE800001/CCAPI/cc_api_call_disconnected:
Cause Value=1, Interface=0x7F8189EC5CC8, Call Id=1340
Sep 16 06:37:15.643: //1336/0D38CE800001/CCAPI/ccCallReleaseResources:
Sep 16 06:37:15.643: //1340/0D38CE800001/CCAPI/ccCallSetAAA_Accounting:
Accounting=1, Call Id=1340
Sep 16 06:37:15.643: //1340/0D38CE800001/CCAPI/ccCallDisconnect:
Sep 16 06:37:15.644: //1340/0D38CE800001/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F8189EC5CC8, Tag=0x0, Call Id=1340,
Sep 16 06:37:15.644: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 16 06:37:15.644: :cc_free_feature_vsa freeing 7F818B42E860
Sep 16 06:37:15.644: vsacount in free is 1
Sep 16 06:37:15.645: //1336/0D38CE800001/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=1100, Params=0x7F819C4B6A60, Progress Indication=NULL(0)
Sep 16 06:37:15.645: //1336/0D38CE800001/CCAPI/ccCheckClipClir:
Guid=0D38CE80-0001-0000-0001-37E1470710AC, Outgoing Dial-peer=1100
Sep 16 06:37:15.645: //1336/0D38CE800001/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=01941300400
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Sep 16 06:37:15.646: //1336/0D38CE800001/CCAPI/ccIFCallSetupRequestPrivate:
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1100, Call Count On=FALSE,
Sep 16 06:37:15.646: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 16 06:37:15.646: :cc_get_feature_vsa malloc success
Sep 16 06:37:15.646: cc_get_feature_vsa count is 2
Sep 16 06:37:15.646: :FEATURE_VSA attributes are: feature_name:0,feature_time:140194363926636,feature_id:627
Sep 16 06:37:15.646: //1336/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:15.646: cc_api_get_xcode_stream : 4983
Sep 16 06:37:15.646: //1336/0D38CE800001/CCAPI/cc_api_event_indication:
Sep 16 06:37:15.646: //1341/0D38CE800001/CCAPI/ccIFCallSetupRequestPrivate:
Sep 16 06:37:15.646: //1341/0D38CE800001/CCAPI/ccCallSetContext:
Context=0x7F819C4B69E0
Sep 16 06:37:15.646: //1336/0D38CE800001/CCAPI/ccSaveDialpeerTag:
Sep 16 06:37:15.646: //1341/0D38CE800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:15.646: //1341/0D38CE800001/CCAPI/ccSetMediaclassIp2ipTags:
Sep 16 06:37:15.647: //1336/0D38CE800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:15.647: //1336/0D38CE800001/CCAPI/ccSetMediaclassIp2ipTags:
Sep 16 06:37:15.647: //1341/0D38CE800001/CCAPI/ccGet_xc_nr_asp_info:
Sep 16 06:37:15.647: //1336/0D38CE800001/CCAPI/ccGet_xc_nr_asp_info:
Sep 16 06:37:15.647: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 1336
Sep 16 06:37:15.647: //1341/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:15.647: cc_api_get_xcode_stream : 4983
Sep 16 06:37:15.647: //1341/0D38CE800001/CCAPI/cc_api_call_proceeding:
Sep 16 06:37:15.648: //1341/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:15.648: cc_api_get_xcode_stream : 4983
Sep 16 06:37:15.666: //1341/0D38CE800001/CCAPI/cc_api_call_disconnected:
Cause Value=1, Interface=0x7F8189EC5CC8, Call Id=1341
Sep 16 06:37:15.666: //1336/0D38CE800001/CCAPI/ccCallReleaseResources:
Sep 16 06:37:15.666: //1341/0D38CE800001/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=1341
Sep 16 06:37:15.666: //1341/0D38CE800001/CCAPI/ccCallDisconnect:
Sep 16 06:37:15.666: //1341/0D38CE800001/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F8189EC5CC8, Tag=0x0, Call Id=1341,
Sep 16 06:37:15.666: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 16 06:37:15.666: :cc_free_feature_vsa freeing 7F818B42E860
Sep 16 06:37:15.667: vsacount in free is 1
Sep 16 06:37:15.668: //1336/0D38CE800001/CCAPI/ccCallDisconnect:
Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Sep 16 06:37:15.668: //-1/xxxxxxxxxxxx/CCAPI/ccMemPoolTDFreeHelper:
data = 7F819C2C1B20
Sep 16 06:37:15.668: ccMemPoolTDFreeHelper:mem_mgr_mempool_free: mem_refcnt(7F8184A0C320)=0 - mempool cleanup
Sep 16 06:37:15.679: //1336/0D38CE800001/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F8189EC5CC8, Tag=0x0, Call Id=1336,
Sep 16 06:37:15.680: //1336/0D38CE800001/CCAPI/cc_api_call_disconnect_done:
Sep 16 06:37:15.680: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 16 06:37:15.680: :cc_free_feature_vsa freeing 7F818B42E940
Sep 16 06:37:15.680: vsacount in free is 0
Sep 16 06:37:46.449: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=01988833070, Called Number=01988833070, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=01988833070
Result=Success(0) after DP_MATCH_DEST
Sep 16 06:37:46.449: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=01988833070, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Sep 16 06:37:46.450: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=3
2: Dial-peer Tag=1100
3: Dial-peer Tag=1101
4: Dial-peer Tag=1200
5: Dial-peer Tag=1201
Sep 16 06:37:46.450: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=11230, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=1100
Sep 16 06:37:46.450: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Sep 16 06:37:46.450: //-1/204B9E800001/DPM/dpAssociateIncomingPeerCore:
Calling Number=11230, Called Number=01988833070, Voice-Interface=0x0,
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=1100
Sep 16 06:37:46.450: //-1/204B9E800001/DPM/dpMatchSafModulePlugin:
Sep 16 06:37:46.451: //-1/xxxxxxxxxxxx/DPM/dpGetSIPUriProvisionBmp:
Tag=1100
Result=0 Bitmap=0x0
Sep 16 06:37:46.451: //-1/204B9E800001/CCAPI/cc_api_display_ie_subfields:
cisco-username=11230
cisco-ani=sip:11230@172.16.7.71
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=sip:01988833070@9.9.9.36:5060
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Sep 16 06:37:46.452: //-1/204B9E800001/CCAPI/cc_api_call_setup_ind_common:
Calling Number=sip:11230@172.16.7.71,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=sip:01988833070@9.9.9.36:5060(TON=Unknown, NPI=Unknown),
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=1342
Sep 16 06:37:46.452: //-1/204B9E800001/CCAPI/ccCheckClipClir:
In: Calling Number=sip:11230@172.16.7.71(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Out: Calling Number=sip:11230@172.16.7.71(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Sep 16 06:37:46.452: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 16 06:37:46.452: :cc_get_feature_vsa malloc success
Sep 16 06:37:46.452: cc_get_feature_vsa count is 1
Sep 16 06:37:46.452: :FEATURE_VSA attributes are: feature_name:0,feature_time:140194363926860,feature_id:628
Sep 16 06:37:46.452: //1342/204B9E800001/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Sep 16 06:37:46.452: //1342/204B9E800001/CCAPI/cc_process_call_setup_ind:
Sep 16 06:37:46.452: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 01988833070
Sep 16 06:37:46.452: //1342/204B9E800001/CCAPI/ccCallSetContext:
Context=0x7F819C4D1858
>>>>CCAPI handed cid 1342 with tag 1100 to app "_ManagedAppProcess_Default"
Sep 16 06:37:46.454: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Sep 16 06:37:46.454: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Sep 16 06:37:46.454: //1342/204B9E800001/CCAPI/ccCallProceeding:
Sep 16 06:37:46.454: //-1/xxxxxxxxxxxx/CCAPI/ccGetMemPoolFromContainer:
mempool not found from usrContainer(7F819C2BDD20)
Sep 16 06:37:46.454: //-1/xxxxxxxxxxxx/CCAPI/ccCreateMemPoolInContainer:
Mempool(7F8184A0C320) created in usrContainer(7F819C2BDD20)
Sep 16 06:37:46.454: //-1/204B9E800001/DPM/dpMatchPeersCore:
Calling Number=, Called Number=01988833070, Peer Info Type=DIALPEER_INFO_SPEECH
Sep 16 06:37:46.454: //-1/204B9E800001/DPM/dpMatchSafModulePlugin:
dialstring=01988833070, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Sep 16 06:37:46.454: //-1/204B9E800001/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=3
2: Dial-peer Tag=1200
3: Dial-peer Tag=1201
4: Dial-peer Tag=1100
5: Dial-peer Tag=1101
Result=SUCCESS(0)
1: Dial-peer Tag=3
Sep 16 06:37:46.454: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Sep 16 06:37:46.455: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Sep 16 06:37:46.455: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=3
Sep 16 06:37:46.455: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=01988833070, Called Number=, Voice-Interface=0x0,
Sep 16 06:37:46.455: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Result=SUCCESS(0)
1: Dial-peer Tag=3
2: Dial-peer Tag=1201
3: Dial-peer Tag=1200
4: Dial-peer Tag=1101
5: Dial-peer Tag=1100
Sep 16 06:37:46.455: //-1/204B9E800001/DPM/dpMatchPeersCore:
Sep 16 06:37:46.455: //-1/204B9E800001/DPM/dpMatchSafModulePlugin:
Sep 16 06:37:46.455: //-1/204B9E800001/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=3
Sep 16 06:37:46.455: //1342/204B9E800001/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=3, Params=0x7F819C4CA790, Progress Indication=NULL(0)
Sep 16 06:37:46.456: //1342/204B9E800001/CCAPI/cc_fill_tg_params:
Not a cic call
Sep 16 06:37:46.456: //1342/204B9E800001/CCAPI/ccCallSetupRequest:
Sep 16 06:37:46.456: //1342/204B9E800001/CCAPI/ccCheckClipClir:
Destination Pattern=[0,2,3,9,8,7,6]T, Called Number=01988833070, Digit Strip=TRUE
Calling Number=sip:11230@172.16.7.71(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=01988833070(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=Shubhra-AM-IT 11230
Account Number=11230, Final Destination Flag=TRUE,
Guid=204B9E80-0001-0000-0001-37E2470710AC, Outgoing Dial-peer=3
Sep 16 06:37:46.456: //1342/204B9E800001/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=01988833070
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Sep 16 06:37:46.456: //1342/204B9E800001/CCAPI/ccIFCallSetupRequestPrivate:
Call Params(Calling Number=sip:11230@172.16.7.71,(Calling Name=Shubhra-AM-IT 11230)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=01988833070(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Sep 16 06:37:46.456: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 16 06:37:46.456: :cc_get_feature_vsa malloc success
Sep 16 06:37:46.456: cc_get_feature_vsa count is 2
Sep 16 06:37:46.456: :FEATURE_VSA attributes are: feature_name:0,feature_time:140194363926636,feature_id:629
Sep 16 06:37:46.456: //1343/204B9E800001/CCAPI/ccIFCallSetupRequestPrivate:
Sep 16 06:37:46.456: //1343/204B9E800001/CCAPI/ccCallSetContext:
Context=0x7F819C4CA710
Sep 16 06:37:46.456: //1342/204B9E800001/CCAPI/ccSaveDialpeerTag:
Sep 16 06:37:46.456: //1342/204B9E800001/CCAPI/cc_api_modify_tgt_cid_call_active_record:
Target Trkgrp Route Label=FXO, tg_label_flag=TRUE, Call Id=0x53E
Sep 16 06:37:46.457: //1343/204B9E800001/CCAPI/cc_api_call_proceeding:
Sep 16 06:37:47.722: //1343/204B9E800001/CCAPI/cc_api_call_disconnected:
Cause Value=34, Interface=0x7F818EA07E98, Call Id=1343
Sep 16 06:37:47.722: //1342/204B9E800001/CCAPI/ccCallReleaseResources:
Sep 16 06:37:47.722: //1343/204B9E800001/CCAPI/ccCallSetAAA_Accounting:
Accounting=1, Call Id=1343
Sep 16 06:37:47.722: //1343/204B9E800001/CCAPI/ccCallDisconnect:
Sep 16 06:37:47.728: //1343/204B9E800001/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F818EA07E98, Tag=0x0, Call Id=1343,
Sep 16 06:37:47.728: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 16 06:37:47.728: :cc_free_feature_vsa freeing 7F818B42E860
Sep 16 06:37:47.728: vsacount in free is 1
Sep 16 06:37:47.729: //1342/204B9E800001/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=1201, Params=0x7F819C4C90E8, Progress Indication=NULL(0)
Sep 16 06:37:47.729: //1342/204B9E800001/CCAPI/ccCheckClipClir:
Destination Pattern=.T, Called Number=01988833070, Digit Strip=FALSE
Guid=204B9E80-0001-0000-0001-37E2470710AC, Outgoing Dial-peer=1201
Sep 16 06:37:47.729: //1342/204B9E800001/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=01988833070
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Sep 16 06:37:47.729: //1342/204B9E800001/CCAPI/ccIFCallSetupRequestPrivate:
Sep 16 06:37:47.730: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 16 06:37:47.730: :cc_get_feature_vsa malloc success
Sep 16 06:37:47.730: cc_get_feature_vsa count is 2
Sep 16 06:37:47.730: :FEATURE_VSA attributes are: feature_name:0,feature_time:140194363926636,feature_id:630
Sep 16 06:37:47.730: //1342/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:47.730: cc_api_get_xcode_stream : 4983
Sep 16 06:37:47.730: //1342/204B9E800001/CCAPI/cc_api_event_indication:
Event=101, Call Id=1342
Sep 16 06:37:47.730: //1344/204B9E800001/CCAPI/ccIFCallSetupRequestPrivate:
Sep 16 06:37:47.730: //1344/204B9E800001/CCAPI/ccCallSetContext:
Context=0x7F819C4C9068
Sep 16 06:37:47.730: //1342/204B9E800001/CCAPI/ccSaveDialpeerTag:
Sep 16 06:37:47.730: //1344/204B9E800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:47.730: //1344/204B9E800001/CCAPI/ccSetMediaclassIp2ipTags:
Sep 16 06:37:47.731: //1342/204B9E800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:47.731: //1342/204B9E800001/CCAPI/ccSetMediaclassIp2ipTags:
Sep 16 06:37:47.731: //1344/204B9E800001/CCAPI/ccGet_xc_nr_asp_info:
Sep 16 06:37:47.731: //1342/204B9E800001/CCAPI/ccGet_xc_nr_asp_info:
Sep 16 06:37:47.731: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 1342
Sep 16 06:37:47.731: //1344/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:47.731: cc_api_get_xcode_stream : 4983
Sep 16 06:37:47.731: //1344/204B9E800001/CCAPI/cc_api_call_proceeding:
Sep 16 06:37:47.732: //1344/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:47.732: cc_api_get_xcode_stream : 4983
Sep 16 06:37:47.752: //1344/204B9E800001/CCAPI/cc_api_call_disconnected:
Cause Value=1, Interface=0x7F8189EC5CC8, Call Id=1344
Sep 16 06:37:47.752: //1342/204B9E800001/CCAPI/ccCallReleaseResources:
Sep 16 06:37:47.752: //1344/204B9E800001/CCAPI/ccCallSetAAA_Accounting:
Accounting=1, Call Id=1344
Sep 16 06:37:47.752: //1344/204B9E800001/CCAPI/ccCallDisconnect:
Sep 16 06:37:47.753: //1344/204B9E800001/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F8189EC5CC8, Tag=0x0, Call Id=1344,
Sep 16 06:37:47.753: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 16 06:37:47.753: :cc_free_feature_vsa freeing 7F818B42E860
Sep 16 06:37:47.753: vsacount in free is 1
Sep 16 06:37:47.754: //1342/204B9E800001/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=1200, Params=0x7F819C4C1FA0, Progress Indication=NULL(0)
Sep 16 06:37:47.754: //1342/204B9E800001/CCAPI/ccCheckClipClir:
Guid=204B9E80-0001-0000-0001-37E2470710AC, Outgoing Dial-peer=1200
Sep 16 06:37:47.754: //1342/204B9E800001/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=01988833070
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Sep 16 06:37:47.754: //1342/204B9E800001/CCAPI/ccIFCallSetupRequestPrivate:
Sep 16 06:37:47.754: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 16 06:37:47.754: :cc_get_feature_vsa malloc success
Sep 16 06:37:47.754: cc_get_feature_vsa count is 2
Sep 16 06:37:47.755: :FEATURE_VSA attributes are: feature_name:0,feature_time:140194363926636,feature_id:631
Sep 16 06:37:47.755: //1342/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:47.755: cc_api_get_xcode_stream : 4983
Sep 16 06:37:47.755: //1342/204B9E800001/CCAPI/cc_api_event_indication:
Sep 16 06:37:47.755: //1345/204B9E800001/CCAPI/ccIFCallSetupRequestPrivate:
Sep 16 06:37:47.755: //1345/204B9E800001/CCAPI/ccCallSetContext:
Context=0x7F819C4C1F20
Sep 16 06:37:47.755: //1342/204B9E800001/CCAPI/ccSaveDialpeerTag:
Sep 16 06:37:47.755: //1345/204B9E800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:47.755: //1345/204B9E800001/CCAPI/ccSetMediaclassIp2ipTags:
Sep 16 06:37:47.755: //1342/204B9E800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:47.755: //1342/204B9E800001/CCAPI/ccSetMediaclassIp2ipTags:
Sep 16 06:37:47.755: //1345/204B9E800001/CCAPI/ccGet_xc_nr_asp_info:
Sep 16 06:37:47.755: //1342/204B9E800001/CCAPI/ccGet_xc_nr_asp_info:
Sep 16 06:37:47.755: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 1342
Sep 16 06:37:47.756: //1345/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:47.756: cc_api_get_xcode_stream : 4983
Sep 16 06:37:47.756: //1345/204B9E800001/CCAPI/cc_api_call_proceeding:
Sep 16 06:37:47.757: //1345/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:47.757: cc_api_get_xcode_stream : 4983
Sep 16 06:37:47.771: //1345/204B9E800001/CCAPI/cc_api_call_disconnected:
Cause Value=38, Interface=0x7F8189EC5CC8, Call Id=1345
Sep 16 06:37:47.771: //1342/204B9E800001/CCAPI/ccCallReleaseResources:
Sep 16 06:37:47.771: //1345/204B9E800001/CCAPI/ccCallSetAAA_Accounting:
Accounting=1, Call Id=1345
Sep 16 06:37:47.771: //1345/204B9E800001/CCAPI/ccCallDisconnect:
Sep 16 06:37:47.772: //1345/204B9E800001/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F8189EC5CC8, Tag=0x0, Call Id=1345,
Sep 16 06:37:47.772: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 16 06:37:47.772: :cc_free_feature_vsa freeing 7F818B42E860
Sep 16 06:37:47.772: vsacount in free is 1
Sep 16 06:37:47.773: //1342/204B9E800001/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=1100, Params=0x7F819C4C6398, Progress Indication=NULL(0)
Sep 16 06:37:47.773: //1342/204B9E800001/CCAPI/ccCheckClipClir:
Guid=204B9E80-0001-0000-0001-37E2470710AC, Outgoing Dial-peer=1100
Sep 16 06:37:47.773: //1342/204B9E800001/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=01988833070
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Sep 16 06:37:47.773: //1342/204B9E800001/CCAPI/ccIFCallSetupRequestPrivate:
Sep 16 06:37:47.774: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 16 06:37:47.774: :cc_get_feature_vsa malloc success
Sep 16 06:37:47.774: cc_get_feature_vsa count is 2
Sep 16 06:37:47.774: :FEATURE_VSA attributes are: feature_name:0,feature_time:140194363926636,feature_id:632
Sep 16 06:37:47.774: //1342/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:47.774: cc_api_get_xcode_stream : 4983
Sep 16 06:37:47.774: //1342/204B9E800001/CCAPI/cc_api_event_indication:
Sep 16 06:37:47.774: //1346/204B9E800001/CCAPI/ccIFCallSetupRequestPrivate:
Sep 16 06:37:47.774: //1346/204B9E800001/CCAPI/ccCallSetContext:
Context=0x7F819C4C6318
Sep 16 06:37:47.774: //1342/204B9E800001/CCAPI/ccSaveDialpeerTag:
Sep 16 06:37:47.774: //1346/204B9E800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:47.774: //1346/204B9E800001/CCAPI/ccSetMediaclassIp2ipTags:
Sep 16 06:37:47.774: //1342/204B9E800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:47.774: //1342/204B9E800001/CCAPI/ccSetMediaclassIp2ipTags:
Sep 16 06:37:47.775: //1346/204B9E800001/CCAPI/ccGet_xc_nr_asp_info:
Sep 16 06:37:47.775: //1342/204B9E800001/CCAPI/ccGet_xc_nr_asp_info:
Sep 16 06:37:47.775: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 1342
Sep 16 06:37:47.775: //1346/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:47.775: cc_api_get_xcode_stream : 4983
Sep 16 06:37:47.775: //1346/204B9E800001/CCAPI/cc_api_call_proceeding:
Sep 16 06:37:47.776: //1346/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:47.776: cc_api_get_xcode_stream : 4983
Sep 16 06:37:47.793: //1346/204B9E800001/CCAPI/cc_api_call_disconnected:
Cause Value=1, Interface=0x7F8189EC5CC8, Call Id=1346
Sep 16 06:37:47.793: //1342/204B9E800001/CCAPI/ccCallReleaseResources:
Sep 16 06:37:47.793: //1346/204B9E800001/CCAPI/ccCallSetAAA_Accounting:
Accounting=1, Call Id=1346
Sep 16 06:37:47.793: //1346/204B9E800001/CCAPI/ccCallDisconnect:
Sep 16 06:37:47.794: //1346/204B9E800001/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F8189EC5CC8, Tag=0x0, Call Id=1346,
Sep 16 06:37:47.794: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 16 06:37:47.794: :cc_free_feature_vsa freeing 7F818B42E860
Sep 16 06:37:47.794: vsacount in free is 1
Sep 16 06:37:47.795: //1342/204B9E800001/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=1101, Params=0x7F819C4C7A40, Progress Indication=NULL(0)
Sep 16 06:37:47.795: //1342/204B9E800001/CCAPI/ccCheckClipClir:
Guid=204B9E80-0001-0000-0001-37E2470710AC, Outgoing Dial-peer=1101
Sep 16 06:37:47.795: //1342/204B9E800001/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=01988833070
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Sep 16 06:37:47.795: //1342/204B9E800001/CCAPI/ccIFCallSetupRequestPrivate:
Sep 16 06:37:47.795: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 16 06:37:47.795: :cc_get_feature_vsa malloc success
Sep 16 06:37:47.796: cc_get_feature_vsa count is 2
Sep 16 06:37:47.796: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 16 06:37:47.796: :FEATURE_VSA attributes are: feature_name:0,feature_time:140194363926636,feature_id:633
Sep 16 06:37:47.796: //1342/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:47.796: cc_api_get_xcode_stream : 4983
Sep 16 06:37:47.796: //1342/204B9E800001/CCAPI/cc_api_event_indication:
Sep 16 06:37:47.796: //1347/204B9E800001/CCAPI/ccIFCallSetupRequestPrivate:
Sep 16 06:37:47.796: //1347/204B9E800001/CCAPI/ccCallSetContext:
Context=0x7F819C4C79C0
Sep 16 06:37:47.796: //1342/204B9E800001/CCAPI/ccSaveDialpeerTag:
Sep 16 06:37:47.796: //1347/204B9E800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:47.796: //1347/204B9E800001/CCAPI/ccSetMediaclassIp2ipTags:
Sep 16 06:37:47.796: //1342/204B9E800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:47.796: //1342/204B9E800001/CCAPI/ccSetMediaclassIp2ipTags:
Sep 16 06:37:47.796: //1347/204B9E800001/CCAPI/ccGet_xc_nr_asp_info:
Sep 16 06:37:47.796: //1342/204B9E800001/CCAPI/ccGet_xc_nr_asp_info:
Sep 16 06:37:47.797: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 1342
Sep 16 06:37:47.797: //1347/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:47.797: cc_api_get_xcode_stream : 4983
Sep 16 06:37:47.797: //1347/204B9E800001/CCAPI/cc_api_call_proceeding:
Sep 16 06:37:47.798: //1347/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:47.798: cc_api_get_xcode_stream : 4983
Sep 16 06:37:47.818: //1347/204B9E800001/CCAPI/cc_api_call_disconnected:
Cause Value=1, Interface=0x7F8189EC5CC8, Call Id=1347
Sep 16 06:37:47.818: //1342/204B9E800001/CCAPI/ccCallReleaseResources:
Sep 16 06:37:47.818: //1347/204B9E800001/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=1347
Sep 16 06:37:47.818: //1347/204B9E800001/CCAPI/ccCallDisconnect:
Sep 16 06:37:47.818: //1347/204B9E800001/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F8189EC5CC8, Tag=0x0, Call Id=1347,
Sep 16 06:37:47.819: //1347/204B9E800001/CCAPI/cc_api_call_disconnect_done:
Sep 16 06:37:47.819: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 16 06:37:47.819: :cc_free_feature_vsa freeing 7F818B42E860
Sep 16 06:37:47.819: vsacount in free is 1
Sep 16 06:37:47.820: //1342/204B9E800001/CCAPI/ccCallDisconnect:
Sep 16 06:37:47.820: //-1/xxxxxxxxxxxx/CCAPI/ccMemPoolTDFreeHelper:
data = 7F819C2BDA20
Sep 16 06:37:47.820: ccMemPoolTDFreeHelper:mem_mgr_mempool_free: mem_refcnt(7F8184A0C320)=0 - mempool cleanup
Sep 16 06:37:47.831: //1342/204B9E800001/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F8189EC5CC8, Tag=0x0, Call Id=1342,
Sep 16 06:37:47.831: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 16 06:37:47.831: :cc_free_feature_vsa freeing 7F818B42E940
Sep 16 06:37:47.831: vsacount in free is 0
Sep 16 06:37:48.092: //-1/F858C14C880E/DPM/dpAssociateIncomingPeerCore:
Calling Number=50096, Called Number=50096, Voice-Interface=0x0,
Sep 16 06:37:48.092: //-1/F858C14C880E/DPM/dpMatchSafModulePlugin:
Sep 16 06:37:48.451: //-1/F88F87C2880F/DPM/dpAssociateIncomingPeerCore:
Calling Number=50097, Called Number=50097, Voice-Interface=0x0,
Sep 16 06:37:48.451: //-1/F88F87C2880F/DPM/dpMatchSafModulePlugin:
CTG-RT-01#debug voip dialpeer inout ter moni debug voip ccapi inoutndebug voip ccapi inoutodebug voip ccapi inout debug voip ccapi inout
voip ccapi inout debugging is off
CTG-RT-01#no debug voip ccapi inoutdebug voip dialpeer inout ter moni debug voip ccapi inoutno debug voip ccapi inoutdebug voip ccapi inout ter moni debug voip dialpeer inout ndebug voip dialpeer inout odebug voip dialpeer inout  debug voip dialpeer inout
voip dialpeer inout debugging is off
CTG-RT-01#
7 Comments
Create
Recognize Your Peers
Content for Community-Ad
