Md.soriful
Can not reach to local cell phone number but can reach to international number. Is it dial peer issue?
Calling no: 11230
Called no: 01988833070
Result: cant reach
no debug voip ccapi inoutdebug voip ccapi inout debug voip ccapi inout debug voip ccapi inout d
voip ccapi inout debugging is on
CTG-RT-01#ter mi oni
CTG-RT-01#deb
CTG-RT-01#debug voi
CTG-RT-01#debug voip
CTG-RT-01#debug voip dia
CTG-RT-01#debug voip dialpeer in
CTG-RT-01#debug voip dialpeer inout
Sep 16 06:37:14.310: //-1/0D38CE800001/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=11219
----- ccCallInfo IE subfields -----
cisco-ani=sip:11219@172.16.7.71
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=sip:01941300400@9.9.9.36:5060
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFFFFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
Sep 16 06:37:14.310: //-1/0D38CE800001/CCAPI/cc_api_call_setup_ind_common:
Interface=0x7F8189EC5CC8, Call Info(
Calling Number=sip:11219@172.16.7.71,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=sip:01941300400@9.9.9.36:5060(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=1100, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=1336
Sep 16 06:37:14.310: //-1/0D38CE800001/CCAPI/ccCheckClipClir:
In: Calling Number=sip:11219@172.16.7.71(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Out: Calling Number=sip:11219@172.16.7.71(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Sep 16 06:37:14.310: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 16 06:37:14.310: :cc_get_feature_vsa malloc success
Sep 16 06:37:14.310: cc_get_feature_vsa count is 1
Sep 16 06:37:14.310: :FEATURE_VSA attributes are: feature_name:0,feature_time:140194363926860,feature_id:622
Sep 16 06:37:14.311: //1336/0D38CE800001/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown))
Sep 16 06:37:14.311: //1336/0D38CE800001/CCAPI/cc_process_call_setup_ind:
Event=0x7F818B451968
Sep 16 06:37:14.311: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 01941300400
Sep 16 06:37:14.311: //1336/0D38CE800001/CCAPI/ccCallSetContext:
Context=0x7F819C4BC480
>>>>CCAPI handed cid 1336 with tag 1100 to app "_ManagedAppProcess_Default"
Sep 16 06:37:14.312: //1336/0D38CE800001/CCAPI/ccCallProceeding:
Sep 16 06:37:14.313: //-1/xxxxxxxxxxxx/CCAPI/ccGetMemPoolFromContainer:
mempool not found from usrContainer(7F819C2BFD00)
Sep 16 06:37:14.313: //-1/xxxxxxxxxxxx/CCAPI/ccCreateMemPoolInContainer:
Mempool(7F8184A0C320) created in usrContainer(7F819C2BFD00)
Sep 16 06:37:14.313: //1336/0D38CE800001/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=3, Params=0x7F819C4BDBA8, Progress Indication=NULL(0)
Sep 16 06:37:14.313: //1336/0D38CE800001/CCAPI/cc_fill_tg_params:
Not a cic call
Trunk Group Select Interface Success;
Interface=0x7F818EA07E98, Selected Interface=1, Selected DSL=-1
Sep 16 06:37:14.313: //1336/0D38CE800001/CCAPI/ccCheckClipClir:
Destination Pattern=[0,2,3,9,8,7,6]T, Called Number=01941300400, Digit Strip=TRUE
Calling Number=sip:11219@172.16.7.71(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=01941300400(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=Shibu-AM-IT 11219
Account Number=11219, Final Destination Flag=TRUE,
Guid=0D38CE80-0001-0000-0001-37E1470710AC, Outgoing Dial-peer=3
Sep 16 06:37:14.313: //1336/0D38CE800001/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=01941300400
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Sep 16 06:37:14.314: //1336/0D38CE800001/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x7F818EA07E98, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=sip:11219@172.16.7.71,(Calling Name=Shibu-AM-IT 11219)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=01941300400(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=3, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=FXO, tg_label_flag=2, Application Call Id=)
Sep 16 06:37:14.314: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 16 06:37:14.314: :cc_get_feature_vsa malloc success
Sep 16 06:37:14.314: cc_get_feature_vsa count is 2
Sep 16 06:37:14.314: :FEATURE_VSA attributes are: feature_name:0,feature_time:140194363926636,feature_id:623
Sep 16 06:37:14.314: //1337/0D38CE800001/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Sep 16 06:37:14.314: //1336/0D38CE800001/CCAPI/ccCallSetupRequest:
Trunk Group Call Setting;
Call Entry(Retry Count=0, Voice Class Cause Code=0)
Sep 16 06:37:14.314: //1337/0D38CE800001/CCAPI/ccCallSetContext:
voip dialpeer inout debugging is on
CTG-RT-01#Context=0x7F819C4BDB28
Sep 16 06:37:14.314: //1336/0D38CE800001/CCAPI/ccSaveDialpeerTag:
Sep 16 06:37:14.314: //1336/0D38CE800001/CCAPI/cc_api_modify_tgt_cid_call_active_record:
Target Trkgrp Route Label=FXO, tg_label_flag=TRUE, Call Id=0x538
Sep 16 06:37:14.316: //1337/0D38CE800001/CCAPI/cc_api_call_proceeding:
Interface=0x7F818EA07E98, Progress Indication=NULL(0)
Sep 16 06:37:15.575: //1337/0D38CE800001/CCAPI/cc_api_call_disconnected:
Cause Value=34, Interface=0x7F818EA07E98, Call Id=1337
Call Entry(Responsed=TRUE, Cause Value=34, Retry Count=0)
Sep 16 06:37:15.576: //1336/0D38CE800001/CCAPI/ccCallReleaseResources:
release reserved xcoding resource.
Sep 16 06:37:15.576: //1337/0D38CE800001/CCAPI/ccCallSetAAA_Accounting:
Accounting=1, Call Id=1337
Sep 16 06:37:15.576: //1337/0D38CE800001/CCAPI/ccCallDisconnect:
Cause Value=34, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=34)
Cause Value=34, Call Entry(Responsed=TRUE, Cause Value=34)
Sep 16 06:37:15.580: //1337/0D38CE800001/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F818EA07E98, Tag=0x0, Call Id=1337,
Call Entry(Disconnect Cause=34, Voice Class Cause Code=0, Retry Count=0)
tg for this call is FXO success/fail is 0
Call Disconnect Event Sent
Sep 16 06:37:15.580: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 16 06:37:15.580: :cc_free_feature_vsa freeing 7F818B42E860
Sep 16 06:37:15.580: vsacount in free is 1
Sep 16 06:37:15.580: //1336/0D38CE800001/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=1200, Params=0x7F819C4C3648, Progress Indication=NULL(0)
Sep 16 06:37:15.580: //1336/0D38CE800001/CCAPI/ccCheckClipClir:
Sep 16 06:37:15.581: //1336/0D38CE800001/CCAPI/ccCallSetupRequest:
Destination Pattern=.T, Called Number=01941300400, Digit Strip=FALSE
Guid=0D38CE80-0001-0000-0001-37E1470710AC, Outgoing Dial-peer=1200
Sep 16 06:37:15.581: //1336/0D38CE800001/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=01941300400
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Sep 16 06:37:15.581: //1336/0D38CE800001/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x7F8189EC5CC8, Interface Type=3, Destination=, Mode=0x0,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1200, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Sep 16 06:37:15.581: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 16 06:37:15.581: :cc_get_feature_vsa malloc success
Sep 16 06:37:15.581: cc_get_feature_vsa count is 2
Sep 16 06:37:15.581: :FEATURE_VSA attributes are: feature_name:0,feature_time:140194363926636,feature_id:624
Sep 16 06:37:15.582: //1336/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:15.582: cc_api_get_xcode_stream : 4983
Sep 16 06:37:15.582: //1336/0D38CE800001/CCAPI/cc_api_event_indication:
Event=101, Call Id=1336
Event Is Sent To Conferenced SPI(s) Directly
Sep 16 06:37:15.582: //1338/0D38CE800001/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Sep 16 06:37:15.582: //1338/0D38CE800001/CCAPI/ccCallSetContext:
Context=0x7F819C4C35C8
Sep 16 06:37:15.582: //1336/0D38CE800001/CCAPI/ccSaveDialpeerTag:
Sep 16 06:37:15.582: //1338/0D38CE800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:15.582: //1338/0D38CE800001/CCAPI/ccSetMediaclassIp2ipTags:
media class tags set: NR 0, ASP 0
Sep 16 06:37:15.582: //1336/0D38CE800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:15.582: //1336/0D38CE800001/CCAPI/ccSetMediaclassIp2ipTags:
Sep 16 06:37:15.582: //1338/0D38CE800001/CCAPI/ccGet_xc_nr_asp_info:
media class tags: NR 0, ASP 0
Sep 16 06:37:15.582: //1336/0D38CE800001/CCAPI/ccGet_xc_nr_asp_info:
Sep 16 06:37:15.582: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 1336
Sep 16 06:37:15.583: //1338/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:15.583: cc_api_get_xcode_stream : 4983
Sep 16 06:37:15.583: //1338/0D38CE800001/CCAPI/cc_api_call_proceeding:
Interface=0x7F8189EC5CC8, Progress Indication=NULL(0)
Sep 16 06:37:15.594: //1338/0D38CE800001/CCAPI/cc_api_call_disconnected:
Cause Value=38, Interface=0x7F8189EC5CC8, Call Id=1338
Call Entry(Responsed=TRUE, Cause Value=38, Retry Count=0)
Sep 16 06:37:15.594: //1336/0D38CE800001/CCAPI/ccCallReleaseResources:
Sep 16 06:37:15.594: //1338/0D38CE800001/CCAPI/ccCallSetAAA_Accounting:
Accounting=1, Call Id=1338
Sep 16 06:37:15.595: //1338/0D38CE800001/CCAPI/ccCallDisconnect:
Cause Value=38, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=38)
Cause Value=38, Call Entry(Responsed=TRUE, Cause Value=38)
Sep 16 06:37:15.595: //1338/0D38CE800001/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F8189EC5CC8, Tag=0x0, Call Id=1338,
Call Entry(Disconnect Cause=38, Voice Class Cause Code=0, Retry Count=0)
Sep 16 06:37:15.595: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 16 06:37:15.595: :cc_free_feature_vsa freeing 7F818B42E860
Sep 16 06:37:15.595: vsacount in free is 1
Sep 16 06:37:15.596: //1336/0D38CE800001/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=1201, Params=0x7F819C4C4CF0, Progress Indication=NULL(0)
Sep 16 06:37:15.596: //1336/0D38CE800001/CCAPI/ccCheckClipClir:
Guid=0D38CE80-0001-0000-0001-37E1470710AC, Outgoing Dial-peer=1201
Sep 16 06:37:15.596: //1336/0D38CE800001/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=01941300400
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Sep 16 06:37:15.597: //1336/0D38CE800001/CCAPI/ccIFCallSetupRequestPrivate:
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1201, Call Count On=FALSE,
Sep 16 06:37:15.597: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 16 06:37:15.597: :cc_get_feature_vsa malloc success
Sep 16 06:37:15.597: cc_get_feature_vsa count is 2
Sep 16 06:37:15.597: :FEATURE_VSA attributes are: feature_name:0,feature_time:140194363926636,feature_id:625
Sep 16 06:37:15.597: //1336/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:15.597: cc_api_get_xcode_stream : 4983
Sep 16 06:37:15.597: //1336/0D38CE800001/CCAPI/cc_api_event_indication:
Sep 16 06:37:15.597: //1339/0D38CE800001/CCAPI/ccIFCallSetupRequestPrivate:
Sep 16 06:37:15.597: //1339/0D38CE800001/CCAPI/ccCallSetContext:
Context=0x7F819C4C4C70
Sep 16 06:37:15.597: //1336/0D38CE800001/CCAPI/ccSaveDialpeerTag:
Sep 16 06:37:15.598: //1339/0D38CE800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:15.598: //1339/0D38CE800001/CCAPI/ccSetMediaclassIp2ipTags:
Sep 16 06:37:15.598: //1336/0D38CE800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:15.598: //1336/0D38CE800001/CCAPI/ccSetMediaclassIp2ipTags:
Sep 16 06:37:15.598: //1339/0D38CE800001/CCAPI/ccGet_xc_nr_asp_info:
Sep 16 06:37:15.598: //1336/0D38CE800001/CCAPI/ccGet_xc_nr_asp_info:
Sep 16 06:37:15.598: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 1336
Sep 16 06:37:15.598: //1339/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:15.598: cc_api_get_xcode_stream : 4983
Sep 16 06:37:15.599: //1339/0D38CE800001/CCAPI/cc_api_call_proceeding:
Sep 16 06:37:15.599: //1339/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:15.599: cc_api_get_xcode_stream : 4983
Sep 16 06:37:15.621: //1339/0D38CE800001/CCAPI/cc_api_call_disconnected:
Cause Value=1, Interface=0x7F8189EC5CC8, Call Id=1339
Call Entry(Responsed=TRUE, Cause Value=1, Retry Count=0)
Sep 16 06:37:15.621: //1336/0D38CE800001/CCAPI/ccCallReleaseResources:
Sep 16 06:37:15.621: //1339/0D38CE800001/CCAPI/ccCallSetAAA_Accounting:
Accounting=1, Call Id=1339
Sep 16 06:37:15.621: //1339/0D38CE800001/CCAPI/ccCallDisconnect:
Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=1)
Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
Sep 16 06:37:15.622: //1339/0D38CE800001/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F8189EC5CC8, Tag=0x0, Call Id=1339,
Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
Sep 16 06:37:15.622: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 16 06:37:15.622: :cc_free_feature_vsa freeing 7F818B42E860
Sep 16 06:37:15.622: vsacount in free is 1
Sep 16 06:37:15.623: //1336/0D38CE800001/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=1101, Params=0x7F819C4D0230, Progress Indication=NULL(0)
Sep 16 06:37:15.623: //1336/0D38CE800001/CCAPI/ccCheckClipClir:
Guid=0D38CE80-0001-0000-0001-37E1470710AC, Outgoing Dial-peer=1101
Sep 16 06:37:15.623: //1336/0D38CE800001/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=01941300400
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Sep 16 06:37:15.623: //1336/0D38CE800001/CCAPI/ccIFCallSetupRequestPrivate:
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1101, Call Count On=FALSE,
Sep 16 06:37:15.623: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 16 06:37:15.623: :cc_get_feature_vsa malloc success
Sep 16 06:37:15.623: cc_get_feature_vsa count is 2
Sep 16 06:37:15.623: :FEATURE_VSA attributes are: feature_name:0,feature_time:140194363926636,feature_id:626
Sep 16 06:37:15.624: //1336/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:15.624: cc_api_get_xcode_stream : 4983
Sep 16 06:37:15.624: //1336/0D38CE800001/CCAPI/cc_api_event_indication:
Sep 16 06:37:15.624: //1340/0D38CE800001/CCAPI/ccIFCallSetupRequestPrivate:
Sep 16 06:37:15.624: //1340/0D38CE800001/CCAPI/ccCallSetContext:
Context=0x7F819C4D01B0
Sep 16 06:37:15.624: //1336/0D38CE800001/CCAPI/ccSaveDialpeerTag:
Sep 16 06:37:15.624: //1340/0D38CE800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:15.624: //1340/0D38CE800001/CCAPI/ccSetMediaclassIp2ipTags:
Sep 16 06:37:15.624: //1336/0D38CE800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:15.624: //1336/0D38CE800001/CCAPI/ccSetMediaclassIp2ipTags:
Sep 16 06:37:15.624: //1340/0D38CE800001/CCAPI/ccGet_xc_nr_asp_info:
Sep 16 06:37:15.624: //1336/0D38CE800001/CCAPI/ccGet_xc_nr_asp_info:
Sep 16 06:37:15.624: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 1336
Sep 16 06:37:15.625: //1340/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:15.625: cc_api_get_xcode_stream : 4983
Sep 16 06:37:15.625: //1340/0D38CE800001/CCAPI/cc_api_call_proceeding:
Sep 16 06:37:15.626: cc_api_get_xcode_stream : 4983
Sep 16 06:37:15.643: //1340/0D38CE800001/CCAPI/cc_api_call_disconnected:
Cause Value=1, Interface=0x7F8189EC5CC8, Call Id=1340
Sep 16 06:37:15.643: //1336/0D38CE800001/CCAPI/ccCallReleaseResources:
Sep 16 06:37:15.643: //1340/0D38CE800001/CCAPI/ccCallSetAAA_Accounting:
Accounting=1, Call Id=1340
Sep 16 06:37:15.643: //1340/0D38CE800001/CCAPI/ccCallDisconnect:
Sep 16 06:37:15.644: //1340/0D38CE800001/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F8189EC5CC8, Tag=0x0, Call Id=1340,
Sep 16 06:37:15.644: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 16 06:37:15.644: :cc_free_feature_vsa freeing 7F818B42E860
Sep 16 06:37:15.644: vsacount in free is 1
Sep 16 06:37:15.645: //1336/0D38CE800001/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=1100, Params=0x7F819C4B6A60, Progress Indication=NULL(0)
Sep 16 06:37:15.645: //1336/0D38CE800001/CCAPI/ccCheckClipClir:
Guid=0D38CE80-0001-0000-0001-37E1470710AC, Outgoing Dial-peer=1100
Sep 16 06:37:15.645: //1336/0D38CE800001/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=01941300400
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Sep 16 06:37:15.646: //1336/0D38CE800001/CCAPI/ccIFCallSetupRequestPrivate:
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1100, Call Count On=FALSE,
Sep 16 06:37:15.646: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 16 06:37:15.646: :cc_get_feature_vsa malloc success
Sep 16 06:37:15.646: cc_get_feature_vsa count is 2
Sep 16 06:37:15.646: :FEATURE_VSA attributes are: feature_name:0,feature_time:140194363926636,feature_id:627
Sep 16 06:37:15.646: //1336/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:15.646: cc_api_get_xcode_stream : 4983
Sep 16 06:37:15.646: //1336/0D38CE800001/CCAPI/cc_api_event_indication:
Sep 16 06:37:15.646: //1341/0D38CE800001/CCAPI/ccIFCallSetupRequestPrivate:
Sep 16 06:37:15.646: //1341/0D38CE800001/CCAPI/ccCallSetContext:
Context=0x7F819C4B69E0
Sep 16 06:37:15.646: //1336/0D38CE800001/CCAPI/ccSaveDialpeerTag:
Sep 16 06:37:15.646: //1341/0D38CE800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:15.646: //1341/0D38CE800001/CCAPI/ccSetMediaclassIp2ipTags:
Sep 16 06:37:15.647: //1336/0D38CE800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:15.647: //1336/0D38CE800001/CCAPI/ccSetMediaclassIp2ipTags:
Sep 16 06:37:15.647: //1341/0D38CE800001/CCAPI/ccGet_xc_nr_asp_info:
Sep 16 06:37:15.647: //1336/0D38CE800001/CCAPI/ccGet_xc_nr_asp_info:
Sep 16 06:37:15.647: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 1336
Sep 16 06:37:15.647: //1341/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:15.647: cc_api_get_xcode_stream : 4983
Sep 16 06:37:15.647: //1341/0D38CE800001/CCAPI/cc_api_call_proceeding:
Sep 16 06:37:15.648: //1341/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:15.648: cc_api_get_xcode_stream : 4983
Sep 16 06:37:15.666: //1341/0D38CE800001/CCAPI/cc_api_call_disconnected:
Cause Value=1, Interface=0x7F8189EC5CC8, Call Id=1341
Sep 16 06:37:15.666: //1336/0D38CE800001/CCAPI/ccCallReleaseResources:
Sep 16 06:37:15.666: //1341/0D38CE800001/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=1341
Sep 16 06:37:15.666: //1341/0D38CE800001/CCAPI/ccCallDisconnect:
Sep 16 06:37:15.666: //1341/0D38CE800001/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F8189EC5CC8, Tag=0x0, Call Id=1341,
Sep 16 06:37:15.666: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 16 06:37:15.666: :cc_free_feature_vsa freeing 7F818B42E860
Sep 16 06:37:15.667: vsacount in free is 1
Sep 16 06:37:15.668: //1336/0D38CE800001/CCAPI/ccCallDisconnect:
Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Sep 16 06:37:15.668: //-1/xxxxxxxxxxxx/CCAPI/ccMemPoolTDFreeHelper:
data = 7F819C2C1B20
Sep 16 06:37:15.668: ccMemPoolTDFreeHelper:mem_mgr_mempool_free: mem_refcnt(7F8184A0C320)=0 - mempool cleanup
Sep 16 06:37:15.679: //1336/0D38CE800001/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F8189EC5CC8, Tag=0x0, Call Id=1336,
Sep 16 06:37:15.680: //1336/0D38CE800001/CCAPI/cc_api_call_disconnect_done:
Sep 16 06:37:15.680: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 16 06:37:15.680: :cc_free_feature_vsa freeing 7F818B42E940
Sep 16 06:37:15.680: vsacount in free is 0
Sep 16 06:37:46.449: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=01988833070, Called Number=01988833070, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=01988833070
Result=Success(0) after DP_MATCH_DEST
Sep 16 06:37:46.449: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=01988833070, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Sep 16 06:37:46.450: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=3
2: Dial-peer Tag=1100
3: Dial-peer Tag=1101
4: Dial-peer Tag=1200
5: Dial-peer Tag=1201
Sep 16 06:37:46.450: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=11230, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=1100
Sep 16 06:37:46.450: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Sep 16 06:37:46.450: //-1/204B9E800001/DPM/dpAssociateIncomingPeerCore:
Calling Number=11230, Called Number=01988833070, Voice-Interface=0x0,
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=1100
Sep 16 06:37:46.450: //-1/204B9E800001/DPM/dpMatchSafModulePlugin:
Sep 16 06:37:46.451: //-1/xxxxxxxxxxxx/DPM/dpGetSIPUriProvisionBmp:
Tag=1100
Result=0 Bitmap=0x0
Sep 16 06:37:46.451: //-1/204B9E800001/CCAPI/cc_api_display_ie_subfields:
cisco-username=11230
cisco-ani=sip:11230@172.16.7.71
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=sip:01988833070@9.9.9.36:5060
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Sep 16 06:37:46.452: //-1/204B9E800001/CCAPI/cc_api_call_setup_ind_common:
Calling Number=sip:11230@172.16.7.71,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=sip:01988833070@9.9.9.36:5060(TON=Unknown, NPI=Unknown),
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=1342
Sep 16 06:37:46.452: //-1/204B9E800001/CCAPI/ccCheckClipClir:
In: Calling Number=sip:11230@172.16.7.71(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Out: Calling Number=sip:11230@172.16.7.71(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Sep 16 06:37:46.452: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 16 06:37:46.452: :cc_get_feature_vsa malloc success
Sep 16 06:37:46.452: cc_get_feature_vsa count is 1
Sep 16 06:37:46.452: :FEATURE_VSA attributes are: feature_name:0,feature_time:140194363926860,feature_id:628
Sep 16 06:37:46.452: //1342/204B9E800001/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Sep 16 06:37:46.452: //1342/204B9E800001/CCAPI/cc_process_call_setup_ind:
Sep 16 06:37:46.452: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 01988833070
Sep 16 06:37:46.452: //1342/204B9E800001/CCAPI/ccCallSetContext:
Context=0x7F819C4D1858
>>>>CCAPI handed cid 1342 with tag 1100 to app "_ManagedAppProcess_Default"
Sep 16 06:37:46.454: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Sep 16 06:37:46.454: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Sep 16 06:37:46.454: //1342/204B9E800001/CCAPI/ccCallProceeding:
Sep 16 06:37:46.454: //-1/xxxxxxxxxxxx/CCAPI/ccGetMemPoolFromContainer:
mempool not found from usrContainer(7F819C2BDD20)
Sep 16 06:37:46.454: //-1/xxxxxxxxxxxx/CCAPI/ccCreateMemPoolInContainer:
Mempool(7F8184A0C320) created in usrContainer(7F819C2BDD20)
Sep 16 06:37:46.454: //-1/204B9E800001/DPM/dpMatchPeersCore:
Calling Number=, Called Number=01988833070, Peer Info Type=DIALPEER_INFO_SPEECH
Sep 16 06:37:46.454: //-1/204B9E800001/DPM/dpMatchSafModulePlugin:
dialstring=01988833070, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Sep 16 06:37:46.454: //-1/204B9E800001/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=3
2: Dial-peer Tag=1200
3: Dial-peer Tag=1201
4: Dial-peer Tag=1100
5: Dial-peer Tag=1101
Result=SUCCESS(0)
1: Dial-peer Tag=3
Sep 16 06:37:46.454: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Sep 16 06:37:46.455: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Sep 16 06:37:46.455: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=3
Sep 16 06:37:46.455: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=01988833070, Called Number=, Voice-Interface=0x0,
Sep 16 06:37:46.455: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Result=SUCCESS(0)
1: Dial-peer Tag=3
2: Dial-peer Tag=1201
3: Dial-peer Tag=1200
4: Dial-peer Tag=1101
5: Dial-peer Tag=1100
Sep 16 06:37:46.455: //-1/204B9E800001/DPM/dpMatchPeersCore:
Sep 16 06:37:46.455: //-1/204B9E800001/DPM/dpMatchSafModulePlugin:
Sep 16 06:37:46.455: //-1/204B9E800001/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=3
Sep 16 06:37:46.455: //1342/204B9E800001/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=3, Params=0x7F819C4CA790, Progress Indication=NULL(0)
Sep 16 06:37:46.456: //1342/204B9E800001/CCAPI/cc_fill_tg_params:
Not a cic call
Sep 16 06:37:46.456: //1342/204B9E800001/CCAPI/ccCallSetupRequest:
Sep 16 06:37:46.456: //1342/204B9E800001/CCAPI/ccCheckClipClir:
Destination Pattern=[0,2,3,9,8,7,6]T, Called Number=01988833070, Digit Strip=TRUE
Calling Number=sip:11230@172.16.7.71(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=01988833070(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=Shubhra-AM-IT 11230
Account Number=11230, Final Destination Flag=TRUE,
Guid=204B9E80-0001-0000-0001-37E2470710AC, Outgoing Dial-peer=3
Sep 16 06:37:46.456: //1342/204B9E800001/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=01988833070
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Sep 16 06:37:46.456: //1342/204B9E800001/CCAPI/ccIFCallSetupRequestPrivate:
Call Params(Calling Number=sip:11230@172.16.7.71,(Calling Name=Shubhra-AM-IT 11230)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=01988833070(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Sep 16 06:37:46.456: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 16 06:37:46.456: :cc_get_feature_vsa malloc success
Sep 16 06:37:46.456: cc_get_feature_vsa count is 2
Sep 16 06:37:46.456: :FEATURE_VSA attributes are: feature_name:0,feature_time:140194363926636,feature_id:629
Sep 16 06:37:46.456: //1343/204B9E800001/CCAPI/ccIFCallSetupRequestPrivate:
Sep 16 06:37:46.456: //1343/204B9E800001/CCAPI/ccCallSetContext:
Context=0x7F819C4CA710
Sep 16 06:37:46.456: //1342/204B9E800001/CCAPI/ccSaveDialpeerTag:
Sep 16 06:37:46.456: //1342/204B9E800001/CCAPI/cc_api_modify_tgt_cid_call_active_record:
Target Trkgrp Route Label=FXO, tg_label_flag=TRUE, Call Id=0x53E
Sep 16 06:37:46.457: //1343/204B9E800001/CCAPI/cc_api_call_proceeding:
Sep 16 06:37:47.722: //1343/204B9E800001/CCAPI/cc_api_call_disconnected:
Cause Value=34, Interface=0x7F818EA07E98, Call Id=1343
Sep 16 06:37:47.722: //1342/204B9E800001/CCAPI/ccCallReleaseResources:
Sep 16 06:37:47.722: //1343/204B9E800001/CCAPI/ccCallSetAAA_Accounting:
Accounting=1, Call Id=1343
Sep 16 06:37:47.722: //1343/204B9E800001/CCAPI/ccCallDisconnect:
Sep 16 06:37:47.728: //1343/204B9E800001/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F818EA07E98, Tag=0x0, Call Id=1343,
Sep 16 06:37:47.728: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 16 06:37:47.728: :cc_free_feature_vsa freeing 7F818B42E860
Sep 16 06:37:47.728: vsacount in free is 1
Sep 16 06:37:47.729: //1342/204B9E800001/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=1201, Params=0x7F819C4C90E8, Progress Indication=NULL(0)
Sep 16 06:37:47.729: //1342/204B9E800001/CCAPI/ccCheckClipClir:
Destination Pattern=.T, Called Number=01988833070, Digit Strip=FALSE
Guid=204B9E80-0001-0000-0001-37E2470710AC, Outgoing Dial-peer=1201
Sep 16 06:37:47.729: //1342/204B9E800001/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=01988833070
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Sep 16 06:37:47.729: //1342/204B9E800001/CCAPI/ccIFCallSetupRequestPrivate:
Sep 16 06:37:47.730: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 16 06:37:47.730: :cc_get_feature_vsa malloc success
Sep 16 06:37:47.730: cc_get_feature_vsa count is 2
Sep 16 06:37:47.730: :FEATURE_VSA attributes are: feature_name:0,feature_time:140194363926636,feature_id:630
Sep 16 06:37:47.730: //1342/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:47.730: cc_api_get_xcode_stream : 4983
Sep 16 06:37:47.730: //1342/204B9E800001/CCAPI/cc_api_event_indication:
Event=101, Call Id=1342
Sep 16 06:37:47.730: //1344/204B9E800001/CCAPI/ccIFCallSetupRequestPrivate:
Sep 16 06:37:47.730: //1344/204B9E800001/CCAPI/ccCallSetContext:
Context=0x7F819C4C9068
Sep 16 06:37:47.730: //1342/204B9E800001/CCAPI/ccSaveDialpeerTag:
Sep 16 06:37:47.730: //1344/204B9E800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:47.730: //1344/204B9E800001/CCAPI/ccSetMediaclassIp2ipTags:
Sep 16 06:37:47.731: //1342/204B9E800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:47.731: //1342/204B9E800001/CCAPI/ccSetMediaclassIp2ipTags:
Sep 16 06:37:47.731: //1344/204B9E800001/CCAPI/ccGet_xc_nr_asp_info:
Sep 16 06:37:47.731: //1342/204B9E800001/CCAPI/ccGet_xc_nr_asp_info:
Sep 16 06:37:47.731: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 1342
Sep 16 06:37:47.731: //1344/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:47.731: cc_api_get_xcode_stream : 4983
Sep 16 06:37:47.731: //1344/204B9E800001/CCAPI/cc_api_call_proceeding:
Sep 16 06:37:47.732: //1344/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:47.732: cc_api_get_xcode_stream : 4983
Sep 16 06:37:47.752: //1344/204B9E800001/CCAPI/cc_api_call_disconnected:
Cause Value=1, Interface=0x7F8189EC5CC8, Call Id=1344
Sep 16 06:37:47.752: //1342/204B9E800001/CCAPI/ccCallReleaseResources:
Sep 16 06:37:47.752: //1344/204B9E800001/CCAPI/ccCallSetAAA_Accounting:
Accounting=1, Call Id=1344
Sep 16 06:37:47.752: //1344/204B9E800001/CCAPI/ccCallDisconnect:
Sep 16 06:37:47.753: //1344/204B9E800001/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F8189EC5CC8, Tag=0x0, Call Id=1344,
Sep 16 06:37:47.753: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 16 06:37:47.753: :cc_free_feature_vsa freeing 7F818B42E860
Sep 16 06:37:47.753: vsacount in free is 1
Sep 16 06:37:47.754: //1342/204B9E800001/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=1200, Params=0x7F819C4C1FA0, Progress Indication=NULL(0)
Sep 16 06:37:47.754: //1342/204B9E800001/CCAPI/ccCheckClipClir:
Guid=204B9E80-0001-0000-0001-37E2470710AC, Outgoing Dial-peer=1200
Sep 16 06:37:47.754: //1342/204B9E800001/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=01988833070
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Sep 16 06:37:47.754: //1342/204B9E800001/CCAPI/ccIFCallSetupRequestPrivate:
Sep 16 06:37:47.754: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 16 06:37:47.754: :cc_get_feature_vsa malloc success
Sep 16 06:37:47.754: cc_get_feature_vsa count is 2
Sep 16 06:37:47.755: :FEATURE_VSA attributes are: feature_name:0,feature_time:140194363926636,feature_id:631
Sep 16 06:37:47.755: //1342/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:47.755: cc_api_get_xcode_stream : 4983
Sep 16 06:37:47.755: //1342/204B9E800001/CCAPI/cc_api_event_indication:
Sep 16 06:37:47.755: //1345/204B9E800001/CCAPI/ccIFCallSetupRequestPrivate:
Sep 16 06:37:47.755: //1345/204B9E800001/CCAPI/ccCallSetContext:
Context=0x7F819C4C1F20
Sep 16 06:37:47.755: //1342/204B9E800001/CCAPI/ccSaveDialpeerTag:
Sep 16 06:37:47.755: //1345/204B9E800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:47.755: //1345/204B9E800001/CCAPI/ccSetMediaclassIp2ipTags:
Sep 16 06:37:47.755: //1342/204B9E800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:47.755: //1342/204B9E800001/CCAPI/ccSetMediaclassIp2ipTags:
Sep 16 06:37:47.755: //1345/204B9E800001/CCAPI/ccGet_xc_nr_asp_info:
Sep 16 06:37:47.755: //1342/204B9E800001/CCAPI/ccGet_xc_nr_asp_info:
Sep 16 06:37:47.755: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 1342
Sep 16 06:37:47.756: //1345/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:47.756: cc_api_get_xcode_stream : 4983
Sep 16 06:37:47.756: //1345/204B9E800001/CCAPI/cc_api_call_proceeding:
Sep 16 06:37:47.757: //1345/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:47.757: cc_api_get_xcode_stream : 4983
Sep 16 06:37:47.771: //1345/204B9E800001/CCAPI/cc_api_call_disconnected:
Cause Value=38, Interface=0x7F8189EC5CC8, Call Id=1345
Sep 16 06:37:47.771: //1342/204B9E800001/CCAPI/ccCallReleaseResources:
Sep 16 06:37:47.771: //1345/204B9E800001/CCAPI/ccCallSetAAA_Accounting:
Accounting=1, Call Id=1345
Sep 16 06:37:47.771: //1345/204B9E800001/CCAPI/ccCallDisconnect:
Sep 16 06:37:47.772: //1345/204B9E800001/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F8189EC5CC8, Tag=0x0, Call Id=1345,
Sep 16 06:37:47.772: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 16 06:37:47.772: :cc_free_feature_vsa freeing 7F818B42E860
Sep 16 06:37:47.772: vsacount in free is 1
Sep 16 06:37:47.773: //1342/204B9E800001/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=1100, Params=0x7F819C4C6398, Progress Indication=NULL(0)
Sep 16 06:37:47.773: //1342/204B9E800001/CCAPI/ccCheckClipClir:
Guid=204B9E80-0001-0000-0001-37E2470710AC, Outgoing Dial-peer=1100
Sep 16 06:37:47.773: //1342/204B9E800001/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=01988833070
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Sep 16 06:37:47.773: //1342/204B9E800001/CCAPI/ccIFCallSetupRequestPrivate:
Sep 16 06:37:47.774: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 16 06:37:47.774: :cc_get_feature_vsa malloc success
Sep 16 06:37:47.774: cc_get_feature_vsa count is 2
Sep 16 06:37:47.774: :FEATURE_VSA attributes are: feature_name:0,feature_time:140194363926636,feature_id:632
Sep 16 06:37:47.774: //1342/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:47.774: cc_api_get_xcode_stream : 4983
Sep 16 06:37:47.774: //1342/204B9E800001/CCAPI/cc_api_event_indication:
Sep 16 06:37:47.774: //1346/204B9E800001/CCAPI/ccIFCallSetupRequestPrivate:
Sep 16 06:37:47.774: //1346/204B9E800001/CCAPI/ccCallSetContext:
Context=0x7F819C4C6318
Sep 16 06:37:47.774: //1342/204B9E800001/CCAPI/ccSaveDialpeerTag:
Sep 16 06:37:47.774: //1346/204B9E800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:47.774: //1346/204B9E800001/CCAPI/ccSetMediaclassIp2ipTags:
Sep 16 06:37:47.774: //1342/204B9E800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:47.774: //1342/204B9E800001/CCAPI/ccSetMediaclassIp2ipTags:
Sep 16 06:37:47.775: //1346/204B9E800001/CCAPI/ccGet_xc_nr_asp_info:
Sep 16 06:37:47.775: //1342/204B9E800001/CCAPI/ccGet_xc_nr_asp_info:
Sep 16 06:37:47.775: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 1342
Sep 16 06:37:47.775: //1346/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:47.775: cc_api_get_xcode_stream : 4983
Sep 16 06:37:47.775: //1346/204B9E800001/CCAPI/cc_api_call_proceeding:
Sep 16 06:37:47.776: //1346/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:47.776: cc_api_get_xcode_stream : 4983
Sep 16 06:37:47.793: //1346/204B9E800001/CCAPI/cc_api_call_disconnected:
Cause Value=1, Interface=0x7F8189EC5CC8, Call Id=1346
Sep 16 06:37:47.793: //1342/204B9E800001/CCAPI/ccCallReleaseResources:
Sep 16 06:37:47.793: //1346/204B9E800001/CCAPI/ccCallSetAAA_Accounting:
Accounting=1, Call Id=1346
Sep 16 06:37:47.793: //1346/204B9E800001/CCAPI/ccCallDisconnect:
Sep 16 06:37:47.794: //1346/204B9E800001/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F8189EC5CC8, Tag=0x0, Call Id=1346,
Sep 16 06:37:47.794: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 16 06:37:47.794: :cc_free_feature_vsa freeing 7F818B42E860
Sep 16 06:37:47.794: vsacount in free is 1
Sep 16 06:37:47.795: //1342/204B9E800001/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=1101, Params=0x7F819C4C7A40, Progress Indication=NULL(0)
Sep 16 06:37:47.795: //1342/204B9E800001/CCAPI/ccCheckClipClir:
Guid=204B9E80-0001-0000-0001-37E2470710AC, Outgoing Dial-peer=1101
Sep 16 06:37:47.795: //1342/204B9E800001/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=01988833070
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Sep 16 06:37:47.795: //1342/204B9E800001/CCAPI/ccIFCallSetupRequestPrivate:
Sep 16 06:37:47.795: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 16 06:37:47.795: :cc_get_feature_vsa malloc success
Sep 16 06:37:47.796: cc_get_feature_vsa count is 2
Sep 16 06:37:47.796: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 16 06:37:47.796: :FEATURE_VSA attributes are: feature_name:0,feature_time:140194363926636,feature_id:633
Sep 16 06:37:47.796: //1342/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:47.796: cc_api_get_xcode_stream : 4983
Sep 16 06:37:47.796: //1342/204B9E800001/CCAPI/cc_api_event_indication:
Sep 16 06:37:47.796: //1347/204B9E800001/CCAPI/ccIFCallSetupRequestPrivate:
Sep 16 06:37:47.796: //1347/204B9E800001/CCAPI/ccCallSetContext:
Context=0x7F819C4C79C0
Sep 16 06:37:47.796: //1342/204B9E800001/CCAPI/ccSaveDialpeerTag:
Sep 16 06:37:47.796: //1347/204B9E800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:47.796: //1347/204B9E800001/CCAPI/ccSetMediaclassIp2ipTags:
Sep 16 06:37:47.796: //1342/204B9E800001/CCAPI/ccGetMediaClassTag:
media class tag 0
Sep 16 06:37:47.796: //1342/204B9E800001/CCAPI/ccSetMediaclassIp2ipTags:
Sep 16 06:37:47.796: //1347/204B9E800001/CCAPI/ccGet_xc_nr_asp_info:
Sep 16 06:37:47.796: //1342/204B9E800001/CCAPI/ccGet_xc_nr_asp_info:
Sep 16 06:37:47.797: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 1342
Sep 16 06:37:47.797: //1347/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:47.797: cc_api_get_xcode_stream : 4983
Sep 16 06:37:47.797: //1347/204B9E800001/CCAPI/cc_api_call_proceeding:
Sep 16 06:37:47.798: //1347/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 16 06:37:47.798: cc_api_get_xcode_stream : 4983
Sep 16 06:37:47.818: //1347/204B9E800001/CCAPI/cc_api_call_disconnected:
Cause Value=1, Interface=0x7F8189EC5CC8, Call Id=1347
Sep 16 06:37:47.818: //1342/204B9E800001/CCAPI/ccCallReleaseResources:
Sep 16 06:37:47.818: //1347/204B9E800001/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=1347
Sep 16 06:37:47.818: //1347/204B9E800001/CCAPI/ccCallDisconnect:
Sep 16 06:37:47.818: //1347/204B9E800001/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F8189EC5CC8, Tag=0x0, Call Id=1347,
Sep 16 06:37:47.819: //1347/204B9E800001/CCAPI/cc_api_call_disconnect_done:
Sep 16 06:37:47.819: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 16 06:37:47.819: :cc_free_feature_vsa freeing 7F818B42E860
Sep 16 06:37:47.819: vsacount in free is 1
Sep 16 06:37:47.820: //1342/204B9E800001/CCAPI/ccCallDisconnect:
Sep 16 06:37:47.820: //-1/xxxxxxxxxxxx/CCAPI/ccMemPoolTDFreeHelper:
data = 7F819C2BDA20
Sep 16 06:37:47.820: ccMemPoolTDFreeHelper:mem_mgr_mempool_free: mem_refcnt(7F8184A0C320)=0 - mempool cleanup
Sep 16 06:37:47.831: //1342/204B9E800001/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F8189EC5CC8, Tag=0x0, Call Id=1342,
Sep 16 06:37:47.831: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 16 06:37:47.831: :cc_free_feature_vsa freeing 7F818B42E940
Sep 16 06:37:47.831: vsacount in free is 0
Sep 16 06:37:48.092: //-1/F858C14C880E/DPM/dpAssociateIncomingPeerCore:
Calling Number=50096, Called Number=50096, Voice-Interface=0x0,
Sep 16 06:37:48.092: //-1/F858C14C880E/DPM/dpMatchSafModulePlugin:
Sep 16 06:37:48.451: //-1/F88F87C2880F/DPM/dpAssociateIncomingPeerCore:
Calling Number=50097, Called Number=50097, Voice-Interface=0x0,
Sep 16 06:37:48.451: //-1/F88F87C2880F/DPM/dpMatchSafModulePlugin:
CTG-RT-01#debug voip dialpeer inout ter moni debug voip ccapi inoutndebug voip ccapi inoutodebug voip ccapi inout debug voip ccapi inout
voip ccapi inout debugging is off
CTG-RT-01#no debug voip ccapi inoutdebug voip dialpeer inout ter moni debug voip ccapi inoutno debug voip ccapi inoutdebug voip ccapi inout ter moni debug voip dialpeer inout ndebug voip dialpeer inout odebug voip dialpeer inout  debug voip dialpeer inout
voip dialpeer inout debugging is off
CTG-RT-01#
7 Comments
Can tou share your dial peer.01988833070 Is this what ITSP expect ?
Md.soriful
RT-01#terminal length 0
RT-01#sh run
Building configuration...
Current configuration : 20350 bytes
! No configuration change since last restart
version 15.5
service password-encryption
no platform punt-keepalive disable-kernel-core
hostname RT-01
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 $1$x/GM$6Zw4YZGUTfRqLzSEI3jlQ/
no aaa new-model
ip domain name
subscriber templating
flow record ipv4
match ipv4 tos
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match interface input
collect interface output
collect counter bytes
collect counter packets
collect application name
flow exporter FNF_exporter
destination 172.16.7.88
transport udp 9996
flow monitor FNF_monitor
cache timeout inactive 120
cache timeout active 60
record ipv4
trunk group FXO
voice call send-alert
voice call convert-discpi-to-prog
voice call carrier capacity active
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
redirect ip2ip
signaling forward unconditional
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
emptycapability
no h225 timeout keepalive
h225 id-passthru
h225 connect-passthru
call start interwork
h245 passthru tcsnonstd-passthru
sip
bind control source-interface GigabitEthernet0/0/0
bind media source-interface GigabitEthernet0/0/0
rel1xx disable
header-passing
registrar server expires max 3600 min 3600
no update-callerid
early-offer forced
midcall-signaling passthru
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice class h323 1
h225 timeout tcp establish 5
h225 timeout setup 10
call start fast
voice register global
mode esrst
no allow-hash-in-dn
system message ESRST MODE
max-dn 100
max-pool 42
voice register pool 1
id network 172.17.22.0 mask 255.255.255.0
number 1 50101
codec g711alaw
voice register pool 2
number 1 50102
codec g711alaw
voice register pool 3
number 1 50103
codec g711alaw
voice register pool 4
number 1 50104
codec g711alaw
voice register pool 5
number 1 50105
codec g711alaw
voice register pool 6
number 1 50106
codec g711alaw
voice register pool 7
number 1 50107
codec g711alaw
voice register pool 8
id network 10.95.20.0 mask 255.255.255.0
number 1 50208
codec g711alaw
voice register pool 9
number 1 50109
codec g711alaw
voice register pool 11
number 1 50118
codec g711alaw
voice register pool 12
number 1 50116
codec g711alaw
voice register pool 13
number 1 50121
codec g711alaw
voice register pool 14
number 1 50122
codec g711alaw
voice register pool 15
number 1 50123
codec g711alaw
voice register pool 16
number 1 50124
codec g711alaw
voice register pool 17
number 1 50152
codec g711alaw
voice register pool 18
number 1 50148
codec g711alaw
voice register pool 19
number 1 50155
codec g711alaw
voice register pool 20
number 1 50164
codec g711alaw
voice register pool 21
number 1 50167
codec g711alaw
voice register pool 23
number 1 50181
codec g711alaw
voice register pool 25
number 1 50199
codec g711alaw
voice translation-rule 1
rule 1 /\(^1\)/ //
voice translation-profile DiscardDigit9
translate called 1
voice translation-profile fax
translate called 1
voice-card 0/1
no watchdog
license udi pid ISR4321/K9 sn FDO22461JN4
license accept end user agreement
license boot level appxk9
license boot level uck9
license boot level securityk9
archive
path tftp://172.16.7.88/$h
time-period 1440
username support privilege 15 secret 5 $1$hLdS$eYBkrrDe/d.i7d5QxLT6L/
username noc privilege 2 password 7 0942410A
username dnac.access privilege 15 password 7 110D1704145C0A0F072F3837
redundancy
mode none
vlan internal allocation policy ascending
crypto isakmp policy 10
encr aes
authentication pre-share
group 14
crypto isakmp key Metronet_MG1HOKEY address 9.9.9.34
crypto isakmp key Metronet_MG1HOKEY address 9.9.9.35
crypto isakmp key Aamra_MG1HOKEY address 9.9.9.66
crypto isakmp key Aamra_MG1HOKEY address 9.9.9.67
crypto ipsec transform-set MGI_TRANSFORM esp-aes 256 esp-sha256-hmac
mode tunnel
crypto ipsec profile Aamra_MGI_IPSEC_PROF
set transform-set MGI_TRANSFORM
crypto ipsec profile Metronet_MGI_IPSEC_PROF
interface Loopback0
description $$ Use for Router ID $$
ip address 6.6.6.6 255.255.255.255
interface Tunnel102032
description ## Chittagong Office_Metronet_Primary_Tunnel ##
ip address 10.20.3.2 255.255.255.252
ip ospf authentication message-digest
ip ospf message-digest-key 1 md5 7 013234217A5B2639087F6F
ip ospf mtu-ignore
ip ospf cost 30
tunnel source 9.9.9.36
tunnel mode ipsec ipv4
tunnel destination 9.9.9.34
tunnel path-mtu-discovery
tunnel protection ipsec profile Metronet_MGI_IPSEC_PROF
interface Tunnel102042
description ## Chittagong HO_Aamra_Primary_Tunnel ##
ip address 10.20.4.2 255.255.255.252
ip ospf message-digest-key 1 md5 7 096D7C2C38553724223F25
ip ospf mtu-ignore
ip ospf cost 10
tunnel source 9.9.9.68
tunnel destination 9.9.9.66
tunnel protection ipsec profile Aamra_MGI_IPSEC_PROF
interface Tunnel103032
description ## Chittagong Office_Metronet_Secondary_Tunnel ##
ip address 10.30.3.2 255.255.255.252
ip ospf message-digest-key 1 md5 7 106F3B3C2447323D25370B
ip ospf mtu-ignore
ip ospf cost 40
tunnel destination 9.9.9.35
interface Tunnel103042
description ## Chittagong HO_Aamra_Secondary_Tunnel ##
ip address 10.30.4.2 255.255.255.252
ip ospf message-digest-key 1 md5 7 072E13696F5939333E212A
ip ospf mtu-ignore
ip ospf cost 20
tunnel destination 9.9.9.67
description $$ Connected to LAN $$
ip address 10.10.22.1 255.255.255.252
no negotiation auto
interface GigabitEthernet0/0/1
description ## Chittagong Office_Metronet_L2IP ##
ip address 9.9.9.36 255.255.255.240
negotiation auto
interface Service-Engine0/1/0
interface GigabitEthernet0/2/0
description ## Chittagong Office_Aamra_L2IP ##
ip address 9.9.9.68 255.255.255.240
ip flow monitor FNF_monitor input
ip flow monitor FNF_monitor output
negotiation auto
interface GigabitEthernet0/2/1
no ip address
shutdown
negotiation auto
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
router ospf 1
auto-cost reference-bandwidth 10000
redistribute connected subnets
redistribute static subnets
network 6.6.6.6 0.0.0.0 area 0
network 10.10.22.0 0.0.0.3 area 0
network 10.20.3.0 0.0.0.3 area 0
network 10.20.4.0 0.0.0.3 area 0
network 10.30.3.0 0.0.0.3 area 0
network 10.30.4.0 0.0.0.3 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip http client source-interface GigabitEthernet0/0/1
ip tftp source-interface GigabitEthernet0/2/0
ip route 192.168.78.0 255.255.255.0 9.9.9.66 140 name SAP_HO_Pri_Route
ip route 192.168.78.0 255.255.255.0 9.9.9.67 150 name SAP_HO_Sec_Route
ip route 192.168.79.0 255.255.255.0 9.9.9.66 140 name SAP_HO_Pri_Route
ip route 192.168.79.0 255.255.255.0 9.9.9.67 150 name SAP_HO_Sec_Route
ip route 192.168.80.0 255.255.255.0 9.9.9.66 140 name SAP_HO_Pri_Route
ip route 192.168.80.0 255.255.255.0 9.9.9.67 150 name SAP_HO_Sec_Route
ip ssh source-interface GigabitEthernet0/0/1
ip ssh version 2
logging trap critical
logging host 10.101.7.42
snmp-server community MGIRO RW
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps vrrp
snmp-server enable traps pfr
snmp-server enable traps flowmon
snmp-server enable traps ds1
snmp-server enable traps ds3
snmp-server enable traps call-home message-send-fail server-fail
snmp-server enable traps tty
snmp-server enable traps eigrp
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps casa
snmp-server enable traps xgcp
snmp-server enable traps license
snmp-server enable traps cef resource-failure peer-state-change peer-fib-state-change inconsistency
snmp-server enable traps memory bufferpeak
snmp-server enable traps config-copy
snmp-server enable traps config-ctid
snmp-server enable traps dhcp
snmp-server enable traps dsp card-status
snmp-server enable traps dsp oper-state
snmp-server enable traps dsp video-usage
snmp-server enable traps dsp video-out-of-resource
snmp-server enable traps fru-ctrl
snmp-server enable traps entity
snmp-server enable traps event-manager
snmp-server enable traps frame-relay multilink bundle-mismatch
snmp-server enable traps frame-relay subif
snmp-server enable traps hsrp
snmp-server enable traps pimstdmib neighbor-loss invalid-register invalid-join-prune rp-mapping-change interface-election
snmp-server enable traps ipmulticast
snmp-server enable traps isis
snmp-server enable traps ip local pool
snmp-server enable traps msdp
snmp-server enable traps mvpn
snmp-server enable traps ospfv3 state-change
snmp-server enable traps ospfv3 errors
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps pppoe
snmp-server enable traps cpu threshold
snmp-server enable traps rsvp
snmp-server enable traps l2tun session
snmp-server enable traps l2tun pseudowire status
snmp-server enable traps aaa_server
snmp-server enable traps atm subif
snmp-server enable traps pki
snmp-server enable traps trustsec-sxp conn-srcaddr-err msg-parse-err conn-config-err binding-err conn-up conn-down binding-expn-fail oper-nodeid-change binding-conflict
snmp-server enable traps ethernet evc status create delete
snmp-server enable traps ether-oam
snmp-server enable traps ethernet cfm cc mep-up mep-down cross-connect loop config
snmp-server enable traps ethernet cfm crosscheck mep-missing mep-unknown service-up
snmp-server enable traps entity-state
snmp-server enable traps entity-qfp mem-res-thresh throughput-notif
snmp-server enable traps adslline
snmp-server enable traps vdsl2line
snmp-server enable traps flash insertion removal
snmp-server enable traps srp
snmp-server enable traps entity-diag boot-up-fail hm-test-recover hm-thresh-reached scheduled-test-fail
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps isdn chan-not-avail
snmp-server enable traps isdn ietf
snmp-server enable traps cnpd
snmp-server enable traps bgp cbgp2
snmp-server enable traps nhrp nhs
snmp-server enable traps nhrp nhc
snmp-server enable traps nhrp nhp
snmp-server enable traps nhrp quota-exceeded
snmp-server enable traps ipsla
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistency
snmp-server enable traps dial
snmp-server enable traps ike tunnel start
snmp-server enable traps ike tunnel stop
snmp-server enable traps ipsec cryptomap add
snmp-server enable traps gdoi gm-rekey-rcvd
snmp-server enable traps gdoi gm-rekey-fail
snmp-server enable traps gdoi ks-rekey-pushed
snmp-server enable traps gdoi gm-incomplete-cfg
snmp-server enable traps rf
snmp-server enable traps transceiver all
snmp-server enable traps voice
snmp-server enable traps ccme
snmp-server enable traps srst
snmp-server host 172.16.7.88 version 2c MGIRO
control-plane
voice-port 0/1/0
trunk-group FXO
supervisory disconnect dualtone mid-call
no comfort-noise
timeouts call-disconnect 3
timeouts wait-release 3
timing hookflash-out 50
timing guard-out 1000
connection plar 50199
description ****2519730*****
caller-id enable
voice-port 0/1/1
trunk-group FXO
no comfort-noise
caller-id enable
voice-port 0/1/2
trunk-group FXO
no comfort-noise
caller-id enable
voice-port 0/1/3
no comfort-noise
connection plar 50096
description ###713749###
caller-id enable
mgcp
mgcp call-agent 172.16.7.71 service-type mgcp version 0.1
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp validate domain-name
mgcp fax t38 ecm
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp ccm 172.16.7.71 identifier 1 version 7.0
sccp ccm group 1
associate ccm 1 priority 1
associate profile 2 register UCM_MTP
associate profile 1 register UCM_XCODE
keepalive retries 5
switchover method immediate
switchback method immediate
switchback interval 15
ccm-manager music-on-hold
ccm-manager redundant-host 172.20.7.71
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager config server 172.16.7.71
ccm-manager config
telephony-service
srst mode auto-provision all
srst ephone description SRST Mode : Jan 04 2017 18:07:35 : Apr 06 2017 11:10:10 : Jun 18 2020 10:40:50
srst dn line-mode dual
max-ephones 42
max-dn 42
ip source-address 10.10.22.1 port 2000
max-conferences 8 gain -6
call-forward pattern .T
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 9
dspfarm profile 1 transcode
associate application SCCP
shutdown
dial-peer voice 1100 voip
preference 2
destination-pattern .T
session protocol sipv2
session target ipv4:172.16.7.71
session transport udp
incoming called-number .
voice-class codec 1
voice-class sip bind control source-interface GigabitEthernet0/0/1
voice-class sip bind media source-interface GigabitEthernet0/0/1
dtmf-relay rtp-nte h245-signal h245-alphanumeric
fax-relay ecm disable
fax-relay sg3-to-g3
fax nsf 000000
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
dial-peer voice 3 pots
trunkgroup FXO
description ######------#######
preference 3
destination-pattern [0,2,3,9,8,7,6]T
dial-peer voice 4 pots
preference 1
destination-pattern 00T
incoming called-number 50096
port 0/1/3
forward-digits all
dial-peer voice 1101 voip
preference 2
session target ipv4:172.20.7.71
voice-class codec 1
dtmf-relay rtp-nte h245-signal h245-alphanumeric sip-notify
dial-peer voice 5 pots
trunkgroup FXO
translation-profile outgoing DiscardDigit9
preference 5
destination-pattern 9T
dial-peer voice 1 pots
dial-peer voice 1200 voip
preference 1
voice-class codec 1
voice-class sip bind control source-interface GigabitEthernet0/2/0
voice-class sip bind media source-interface GigabitEthernet0/2/0
fax-relay sg3-to-g3
fax nsf 000000
dial-peer voice 8 pots
translation-profile outgoing fax
preference 1
destination-pattern 1T
port 0/1/3
forward-digits all
dial-peer voice 1201 voip
preference 1
voice-class codec 1
gateway
media-inactivity-criteria all
timer receive-rtcp 6
timer receive-rtp 1200
ephone-dn 1 dual-line
number 50101
description SRST-50101
ephone-dn 2 dual-line
number 50102
description SRST-50102
ephone-dn 3 dual-line
number 50103
description SRST-50103
ephone-dn 4 dual-line
number 50104
description SRST-50104
ephone-dn 5 dual-line
number 50105
description SRST-50105
ephone-dn 6 dual-line
number 50106
description SRST-50106
ephone-dn 7 dual-line
number 50107
description SRST-50107
ephone-dn 8 dual-line
number 50108
description SRST-50108
ephone-dn 9 dual-line
number 50109
description SRST-50109
ephone-dn 11 dual-line
number 50118
description SRST-50118
ephone-dn 12 dual-line
number 50116
description SRST-50116
ephone-dn 13 dual-line
number 50121
description SRST-50121
ephone-dn 14 dual-line
number 50122
description SRST-50122
ephone-dn 15 dual-line
number 50123
description SRST-50123
ephone-dn 16 dual-line
number 50124
description SRST-50124
ephone-dn 17 dual-line
number 50152
description SRST-50152
ephone-dn 18 dual-line
number 50148
description SRST-50148
ephone-dn 19 dual-line
number 50155
description SRST-50155
ephone-dn 20 dual-line
number 50164
description SRST-50164
ephone-dn 21 dual-line
number 50167
description SRST-50167
ephone-dn 23 dual-line
number 50181
description SRST-50181
ephone-dn 25 dual-line
number 50199
description SRST-50199
privilege exec level 4 show logging
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login local
transport input ssh
ntp server 172.16.7.78
end
RT-01#
You have below dial peer matching your called number. you need to have more specific dial-peer.
destination-pattern .T >>>>>> Matching 01988833070
destination-pattern [0,2,3,9,8,7,6]T >>>>>> Matching 01988833070
Md.soriful
Ok.
Dial peer is matching but why call is not going to destination?
What is the solution?
01988833070 is this a correct number which your ISP expect to process  international call? whats your international call prefix and country code for called party.
if i need to make international call from my country i need to dial 00(international call prefix)+91(Country Code for India)+9902816548(Mobile Number).
Md.soriful
International call is working well, my problem is that "call can't success to our country mobile operator number 01988833070".
Your dial peer are bit odd. fine tune it and make it more precise.
