03-18-2010 11:12 AM
Hi Team
I tried to update the TBA by right click but nothing happens. I dont see any menu show up. at first I used Google Crome and the second time i used IE but the result were same.
do you guys know what wrong ?
Ping Petchged
03-18-2010 11:46 AM
Google Chrome is a known issue for us at the moment, including the dev and beta channel versions, and we aren't officially supporting it for the purposes of this trial (although I'm using it to write this). Which version of IE were you using?
-mike
03-18-2010 12:10 PM
Hi Mike;
im using IE7
03-18-2010 12:21 PM
Thanks Ping. I just tried in IE7 (on XP), and on mine I can both right-click and double-click the TBA to edit the device. As this is a Flash movie, I expect right-click to always draw some menu (Adobe's default menu, plus we add Edit Device at the top). Can you please visit http://kb2.adobe.com/cps/155/tn_15507.html and let us know which version of Flash player you are using? Perhaps we aren't properly blocking older 9.x.x versions as we should be doing.
-mike
03-18-2010 12:27 PM
03-18-2010 12:37 PM
Thanks Ping. We'll try to get a lab set up with Windows Server 2008 and IE7 and Flash Player 10.0.22 early next week and see if we can replicate the problem.
Another question, were you sitting at the console of this Windows 2008 Server, or accessing it through RDP or other terminal service?
-mike
03-18-2010 12:42 PM
I access to this server by using Ubuntu Terminal server client.
03-18-2010 12:50 PM
Ok, thanks. If you can try it directly from the console and it works then this is an issue or interaction with the Ubuntu TS client, and we probably don't need to try to debug that corner-case for the purposes of this trial. If it still doesn't work directly from the machine then please let us know and we'll set up a lab to investigate further.
-mike
03-19-2010 01:25 PM
Hi Mike;
I was able to right click now but I don't see the Upgrade Firmware botton. I saw the Edit device
03-19-2010 01:27 PM
Select Edit Device to open the main device control screen. You will see Firmware update under "Actions".
Marcos
03-19-2010 02:14 PM
HI Marcos;
I checked on the action menu too but I dont see the upgrade ,I have Make root device ,Reboot and Deactivate site. I think the box is already upgraded its firmware since I was able to put (.) on device name now.
Ping Petchged
03-19-2010 02:35 PM
Same here, no update for TBA available.
03-19-2010 03:04 PM
The TBA updates are automatically installed during the nightly maintenance period. The latest one came out yesterday evening, so if your maintenance period is set normally (early in the AM), it will have updated already. The firmware upgrade option is only offered when the TBA is down-rev, in which case it should be glowing yellow like other devices detected to be down-rev.
03-19-2010 03:33 PM
HI Andrew;
the TBA on my site still glowing yellow . can you tell me what is new version of the software now so I can check.
Ping petchged
03-19-2010 04:24 PM
Can you tell us the version of the firmware we should have? Mine is 12.308 and glowing nice and green constantly.
