Captive Portal - Authorization and de-authorization
lokibjensen
In the captive portal, is there a way to delete or unauthorize clients that have connected to the "Guest" network other than banning their MAC address through an ACL?  It would be nice to have an option to block them and/or release them under "Captive Portal->Authenticated Clients"
Brian Bergin
Level 4
Level 4
Agreed, an ACL is so "permanent".  I'm wondering if they can provide a way to shun a client for x minutes and then automatically remove the block.
You can go to Captive Portal->Instance configuration, choose one instance and configure "Away time/Session time" to control the global session time in a instance , but we not support control mac in Authenticated Clients alone.
Xiao
