DSL Training Issues on short loops
55
Some customers (particularly in New Zealand) have been reporting that the SRP527 will not train when they are installed very close to the DSLAM.
To manage the higher signal levels in this scenario, new DSL driver code is required.
The attached code may be installed on top of the current GA release [1.1.19(004)] for the SRP527W (ONLY).
Unless you are seeing this failure to train issue, it is strongly recommended that you do not use this code until it has been properly tested and integrated in to a formal firmware image.
Please provide feedback below if you do choose to test this code.
Beginner
Thanks Andy,
We will look to use this with custys with this issue, will advise how it goes
Phil Moore
