Hein555
Beginner
Outdoor access point connected with two patch antennas
Good day,
I would like to find out if it is possible to connect two patch antennas to the Cisco 1562E?
Like the AIR-ANT2513P4M-N= or something similar?
The idea is to use this in a warehouse setup where the access point will be on the end of the rack and then I want an antenna pointing down each row on opposite sides of the access point. So one access point to cover two rows with directional antennas.
I know the 1562 has four connectors for antennas, I am guessing two for 2.4Ghz and two for 5Ghz?
So I need to broadcast the 2.4Ghz down both the rows as it will predominantly be used for barcode scanners.  So perhaps a directional dual band antenna with two cables, one to the 2.4Ghz and one to the 5Ghz  that will cover each row?
Kind Regards
0 REPLIES 0
