06-01-2010 10:08 PM
(Don Diep is the originator of this post)
Please check out this POE issue that Dave had reported. We are looking into this issue. Wondering if anyone else might seen same problem?
Sent: Thursday, April 15, 2010 8:28 AM
To: Don Diep (ddiep)
Hi Don,
Saw a very interesting phenomena today on my SG300 switch.
Noticed in the hyperterminal console, that there is a option to put the SG300 in Layer 3 mode, so I did. Thought I would give it a try.
After doing that I again setup tagged VLAN for vlan 100 (uc520-voice) , because the unit factory defaulted…ok SG300 said it would do that…so ok.
But I noticed that my POE devices would not come up…I have the log below, but it shows nothing,
See the first screen shot, it shows max power available at 1W.
OK, thought then to default my machine and reboot. POE power was still gone.
I unplugged the power cable and after the reboot POE power was restored, see second screen capture below.
( My guess- Seems to me that something like a register may have got stuck off, and a removal of power initialized the registers.)
Otherwise all has been stable over the last week. No other problems observed.
I did think these units could go into cli mode, what is the new command to go into CLI mode?
Regards Dave
2147483614 2010-Mar-09 14:28:10 Informational %AAA-I-DISCONNECT: User CLI session for user cisco over console , source destination TERMINATED. The Telnet/SSH session may still be connected.
2147483615 2010-Mar-09 14:26:14 Note %COPY-N-TRAP: The copy operation was completed successfully
2147483616 2010-Mar-09 14:26:12 Informational %COPY-I-FILECPY: Files Copy - source URL flash://startup-config destination URL HTTP://192.168.10.111/
2147483617 2010-Mar-09 14:25:32 Note %COPY-N-TRAP: The copy operation was completed successfully
2147483618 2010-Mar-09 14:25:30 Informational %COPY-I-FILECPY: Files Copy - source URL running-config destination URL flash://startup-config
2147483619 2010-Mar-09 14:25:12 Warning %STP-W-PORTSTATUS: g1: STP status Forwarding
2147483620 2010-Mar-09 14:24:42 Informational %LINK-I-Up: g1
2147483621 2010-Mar-09 14:24:40 Warning %LINK-W-Down: g1
2147483622 2010-Mar-09 14:22:56 Informational %LINK-I-Up: Vlan 100
2147483623 2010-Mar-09 14:20:07 Informational %AAA-I-DISCONNECT: http connection for user cisco, source 192.168.10.111 destination 192.168.10.41 TERMINATED
2147483624 2010-Mar-09 14:19:17 Informational %AAA-I-CONNECT: New http connection for user cisco, source 192.168.10.111 destination 192.168.10.8 ACCEPTED
2147483625 2010-Mar-09 14:18:24 Informational %AAA-I-CONNECT: New http connection for user cisco, source 192.168.10.111 destination 192.168.10.41 ACCEPTED
2147483626 2010-Mar-09 14:18:12 Note %SYSLOG-N-LOGGING: Logging started.
2147483627 2010-Mar-09 14:17:52 Informational %BOOTP_DHCP_CL-I-DHCPCONFIGURED: The device has been configured on interface Vlan 1 , IP 192.168.10.41, mask 255.255.255.0, DHCP server 192.168.10.1
2147483628 2010-Mar-09 14:17:50 Warning %BOOTP_DHCP_CL-W-DHCPIPCANDIDATE: The device is waiting for IP address verification on interface Vlan 1 , IP 192.168.10.41, mask 255.255.255.0, DHCP server 192. 168.10.1
2147483629 2010-Mar-09 14:17:47 Warning %STP-W-PORTSTATUS: g1: STP status Forwarding
2147483630 2010-Mar-09 14:17:46 Warning %STP-W-PORTSTATUS: g10: STP status Forwarding
2147483631 2010-Mar-09 14:17:36 Informational %AAA-I-CONNECT: User CLI session for user cisco over console , source destination ACCEPTED
2147483632 2010-Mar-09 14:17:17 Informational %LINK-I-Up: g1
2147483633 2010-Mar-09 14:17:16 Informational %LINK-I-Up: g10
2147483634 2010-Mar-09 14:17:16 Informational %LINK-I-Up: Vlan 1
2147483635 2010-Mar-09 14:17:16 Warning %LINK-W-Down: g10
2147483636 2010-Mar-09 14:17:16 Warning %LINK-W-Down: g9
2147483637 2010-Mar-09 14:17:16 Warning %LINK-W-Down: g8
2147483638 2010-Mar-09 14:17:16 Warning %LINK-W-Down: g7
2147483639 2010-Mar-09 14:17:16 Warning %LINK-W-Down: g6
2147483640 2010-Mar-09 14:17:16 Warning %LINK-W-Down: g5
2147483641 2010-Mar-09 14:17:15 Warning %LINK-W-Down: g4
2147483642 2010-Mar-09 14:17:15 Warning %LINK-W-Down: g3
2147483643 2010-Mar-09 14:17:15 Warning %LINK-W-Down: g2
2147483644 2010-Mar-09 14:17:15 Warning %LINK-W-Down: g1
2147483645 2010-Mar-09 14:17:12 Informational %SNMP-I-CDBITEMSNUM: Number of startup configuration items loaded: 0
2147483646 2010-Mar-09 14:17:12 Informational %SNMP-I-CDBITEMSNUM: Number of running configuration items loaded: 0
2147483647 2010-Mar-09 14:17:06 Informational %INIT-I-InitCompleted: Initialization task is completed
Clear Logs
06-04-2010 10:17 AM
I will see if I can replicate this.
The command for entering the CLI is available in the FAQ:
- Log on to the console as normal with the configured user name and password
- Type ‘ctrl-z + 4’
- Type ‘lcli’
- Enter the same user name and password
To get out of cli mode
- Type ‘debug-mode’
- Type ‘menu’
06-07-2010 07:35 AM
I was able to recreate the issue, but only one time. Following your steps above, it happened the first time, but every attempt since then, I have been unable to recreate it.
The attached screenshot shows the max power 1w and used 0 when it should be 125 and 5. The POE device would not turn on.
