Remote Management - Local TFTP
gtrent
Beginner
Beginner
I'm confused about how to use the Local TFTP section on the SRP521 administration setup.
In the File: block I tried adding an xml config, and a binary.cfg.  Neither of these worked when I clicked "Get File"
I have the interface set to TFTP and the URL: tftp://xxx.xxx.xxx.xxx (my tftp server address)
File List shows a file:  /home/file_store/tftproot
2 Accepted Solutions
Maulik Shah
Contributor
Contributor
This is the SRP500 acting as a local TFTP server to say a phone behind it. What are you trying to do with TFTP?
2 options:
- If there is a DHCP server you control the WAN side, setup the DHCP server to send option 66 to the SRP. Option 66 is the IP address of your TFTP server - the SRP will go fetch the config if you reboot the box
- Look at the profile rule on Voice > Provisioning
Maulik Shah
Contributor
Contributor
Thanks, that makes sense and explains the reason for "Local" tftp.
Is there a way to tftp a config change to the device from the GUI other than http://.../admin/resync?tftp:.../config.xml?
2 options:
Recognize Your Peers
