Analog phone ringer LED wont light up under SPA8000
matant1973
I work for a Cisco disti and one of my customers installed a unit of SPA8000 at a taxi station.
Because of the background noises at the station, they rely on analog phones with a ringer led.
The phones that they are using are:
HYUNDAI HDT-1602
http://img.zap.co.il/pics/5/5/2/6/29486255c.gif
The closest model I could find at the manufacturer website is HT-2602:
http://www.hungtat-intl.com/en_products.php?page=3
When I connect the phone to the PSTN the ringer LED works o.k. (I am located in Israel)
When it’s connected to the SPA8000 the phone rings but the ringer LED won’t light up
I’ve tried to change the following fields at the regional settings tab:
Ring Waveform: Sinusoid
Ring voltage: 90
Ring Frequency: 25
FXS Port Impedance: 270 +750 || 150nF
No luck…
I’ve tried it with: SPA8000, SPA8800, SPA2102, SPA3102 and also tried to connect the phone to the integrated FXS ports on a UC520 unit
again with no luck...
The phone got a sticker on its back saying:
“This unit complies with part 68 FCC no GXATE18BHT-2112 REN.1.8b”
Does anyone have an idea of what I’m missing here?
Matan
Alberto Montilla
Dear Sir;
Please try changing waveform to Trapezoid first, reboot it and try. If it does not work, change frequency to 20.
Alberto
Thanks Alberto,
I tried it but I still get the same symptom
(the phone rings but the ringer LED won’t light up)
Any other ideas?
Umm...strange.
The other thing I can imagine is to try changing the ring cadence to something that generates a DC offset (more ON periods than OFF) to see if this affects the LED.
Alberto
Thanks Alberto,
I’ve tried:
60 (4/2)
and
60 (3/.1,3/.1,3/.1,3/.1)
No effect on the led
(I tried all sort of combination with waveform and frequency)
I’ve tried to connect the phone to a regular extension at our office’s analog PBX and it worked.
So far:
PSTN and regular PBX extension – works
SPA8000,2102,3102,8800 and UC520 FXS – doesn’t work
I’ll try to find out the ring output specifications for our PBX, maybe it will help
Matan
