Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
1259
Cisco DECT - SPA302D & CME
Hello.
Can Cisco DECT phones SPA302D and base station (
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps10998/ps12776/data_sheet_c78-717757.html
) be used with Cisco Communications Manager Express (CME) or can they only be used with Cisco UC540/560 and UC320?
Thank you for your help.
Best regards,
  Rui Antunes
4 REPLIES 4
Roman Szolga
Beginner
SPA302D is not supported with the CME.
You responded very old question.
It should be noted the SPA302D has been claimed EoL/EoS at all in the mean time ...
I know it was an old question, but these devices are still in use and my customer wants to deploy it on one of his sites. So someone might find this information useful.
In the meantime I found out that the SPA302D can be deployed on CME with the SPA232D Mobility Enhanced ATA connected to FXS port and configured as a standard analog endpoint.
True, but in such case it's just classic POTS/analog interconnection. No advanced function  will be available.
SPA232D+SPA302D bundle may be somewhat expensive solution here.
Any DECT base station with DECT handsets can be used as cheaper solution.
