Cisco SPA112 provisioning problem: FXS_Port_Power_Limit
alejandro37v
We have problems provisioning specific parameter in a SPA112: FXS_Port_Power_Limit. Here is a part of our XML:
<Force_G729a_Code ua="na">*02729</Force_G729a_Code>
<FXS_Port_Power_Limit ua="na">4</FXS_Port_Power_Limit>
<FXS_Port_Input_Gain ua="na">+2</FXS_Port_Input_Gain>
<FXS_Port_Output_Gain ua="na">+2</FXS_Port_Output_Gain>
The parameter "FXS_Port_Power_Limit" is not provisioning the XML parameter (in the example: 4). It keeps the default value (3). Other parameters in the same section like FXS_Port_Input_Gain and FXS_Port_Output_Gain gets the XML value correctly.
Thanks for your advice,
Alejandro.
