07-29-2013 09:56 PM - edited 03-21-2019 10:06 AM
Can I register handset SPA302D without SPA232D ATA via SIP? I will be using Asterisk, and we have a separate FXS/FXO gateway.
07-30-2013 01:27 AM
You will need a TDM400 FXO/FXS PCI/PCI Express card.
If you can configure the SPA302D with the authentication name, password and codec, then you can get away with direct registration to Asterisk.
Currently, I have an Asterisk/FreePBX on a Raspberry Pi. I have a 7960G, 7970G and an SPA122 (with two analogue phones) registering to my setup.
07-31-2013 07:28 AM
Hi Justin,
No. The SPA302D is a DECT handset and the SPA232D is the DECT base station [and FXS/FXO gateway] so the SPA232D is required for any/all SPA302D deployments.
The SPA232D will register to your SIP proxy, not the SPA302D.
Patrick---
