cisco SPA8800 Firmware BUG
reddragon24
we just bought spa8800 series gateway 4fxs with 4 fxo port. And found there is no option to set NAT mapping enable "No" however does allow to set for Phone 1 but for other lines its "Yes" by default and does not allow to set.
We did try to disable by provisioning method:(using .cfg)
Added NAT Mapping Enable "no" (parameter) under phone 1 2 3
but as soon as SPC tool compile .txt file to .cfg its prompt error " unknown parameter found"
Please do let us know if can be solved.
nseto
Level 6
Level 6
Correct, only line 1 and phone 1 has this option, line 2-4 and phone 2-4 are fixed.
Can you confirm that its a bug? If not any reasoning for not being able to set?
I experienced this same problem today.
icastrov
I'm afraid that it works like this as per design, I've raised a feature request in order to be able to de-activate the NAT mapping in lines 2-4.
Thanks!
-nacho
