06-21-2018 10:34 AM - edited 03-21-2019 10:44 AM
hi
we are trying to setup a viking RC-2A to Release our Door
it needs to receive a touch tone code from the phone in order it should release when we are doing it with a analog phone it works perfectly fine. but if we do it with the line going thru the SPA112 ATA Device, it just doesn't release , i believe its because the DTMF is not going thru to the viking device
i'm running Firmware version 1.4.1
any Idea on how to make sure that the viking device gets the Touch tone from the phone ?
thanks
06-21-2018 12:07 PM
Your description of the environment is so vague. It seems you have and analog device, Viking RC-2A connected to a line of SPA112. And there's an other phone, connected elsewhere, that wish to send DTMF to Viking. I'm unsure about the exact path between such phone and SPA112, codec used on digital part of the path, and DTMF transfer method selected. So hard to advise something valuable.
So, please describe complete path between Viking and the device trying to send DTMF.
06-25-2018 08:48 AM
We are using RFC2833 for DTMF sending.
06-25-2018 09:26 AM
For sending ? I assumed so far the Viking should receive DTMF, not send it.
Please describe exact environment and call path (as requsted already).
