Forwarding PSTN Calls to a VOIP number on SPA3102 does not work with voip providers that do not have proxy outbond
prsantos1
I'm using the SPA3102 to forward calls from PSTN toward Voip network. Is working very well with a local Voip Provider  called Vono (www.vono.net.br), i think because this provider is one  that has outbound proxy. However, I want to use SPA3102 forwardin PSTN calls  with other providers like Freevoipdeal, VoipWise, VoipRaider etc. .. These providers have no outbound proxy. How can I get around this? According to the link below, you need to schedule an outbound proxy. What to do?
http://www.cisco.com/en/US/products/ps10024/products_qanda_item09186a0080a359ae.shtml#q
For example, the provider voip freevoipdeal guides that leave the field blank Outbound Proxi as below.
https://www.freevoipdeal.com/sip
You can leave the Outbound Proxy field blank.  You do not have to have an entry in this field for the SPA3012 to work correctly.
