Linksys PAP2T - red light
Maryann Yu
My internet phone adapter suddenly worked with an failure.
Power light: Red
Internet light: Green
Phone 1 & 2: No light
Could you please let me know how to fix it?
6 Replies 6
Dan Lukes
Red power led mean an internal failure.
You may power cycle it, you may try reset to factory default, but you are out of luck if it will not help.
WhiteBehemoth
I had exactly the same problem. Googled it, did not find a solution and order a new PAP2T.
When I received it, I connected the new PAP2T to the power supply from the old one. Same thing solid RED and GREEN.
Then I tried the new power adapter. It worked. Both PAP2T are working!
So, the real issue is in power adapter.
Exactly this!  It's the power adapter!  Woohoo!  Thanks WB!
This is why I love the internet. It solves my most obscure problems like this one. Thank you WhiteBehemoth!
Computers help us solve problems that would not occur at all without computers.
Excelent this helped me
Thank You!!!
