Hello!
Connected Linksys spa 3102 and GSM Wavelink FCT C6 port FXO, caught in this classic problem of a busy signal.
Use the PSTN Disconnect Detection-> Detect Polarity Reversal failed, as when connecting to GSM sends something that SPA immediately terminates the connection.
Recorded a busy signal, it turned
450@-30;4(.35/.35/1)
Firmware 5.1.7
Country: Ukraine, Kyivstar GSM.
But no catches!
Can somebody help me?
Found solution after 2 days of headache.
“450@-30,450@-30;4(.35/.35/1+2)”. Note:
The SPA3102 supports two frequency components. If the tone has only one frequency, use the same value for both frequencies.
Maybe this helps someone.
