06-16-2009 06:58 AM - edited 03-21-2019 09:16 AM
Will a Linksys SPA2102 ATA work with Cisco Call Manager version 7?
06-16-2009 04:24 PM
Hi m.kirby,
We have not officially tested this, nor do we claim compatibility, but I have heard that some have configured with success.
The SPA2102 should provide standard SIP features such as making, answering, forwarding, conferencing and transferring calls and should also provide fax support.
The number of DLUs depends on how many FXS ports [lines] you activate on the SPA2102.
1 FXS port requires 3 DLUs while 2 FXS ports requires 6 DLUs.
Patrick
07-09-2009 08:20 AM
How is this configured in UCM?
Is it a 3rd party SIP phone, or do you build a SIP trunk to it?
07-09-2009 07:18 PM
In principle you could use either approach. I am not an expert in CUCM, but I think that configuring it as a SIP trunk may reduce or eliminate the DLUs required, but will most likely reduce the manageability and possibly the features that you get by configuring it as a phone. We do not have a recommendation on how to do this, because, as Patrick said earlier, it is not a scenario we support. The recommended approach is to use a VG202 which is designed for use with CUCM and is fully supported in that environment.
Cheers,
Dave.
07-10-2009 04:13 AM
Dear Sir;
SPA2102 will work with CUCM as a third party end point. You need DLUs for it. The number depends on how many lines you want to register (Basic - 1 line, Advanced- 2 lines) and whether you require authentication on subscription (basic - No auth, advanced - auth).
I would like to warn you this is a non-supported configuration, so there is no documentation and no TAC support.
Alberto
11-25-2009 01:41 PM
I have tried to get the SPA2102 to register to CUCM 6.1.2 with no luck. However, there was another way to get them to talk.
Setup a Cisco router with SP Services IOS as a SIP Gateway. Build a "voice" dial-peer for incoming calls, build another for outgoing calls to the SPA2102, and another to the CUCM.
Configure the SPA2102 to NOT register with SIP Proxy and to point to the Cisco router instead.
This costs NO DLU's.
Depending on how your dial-peer's are configured you can have both lines appear as the same number.or different numbers.
