04-16-2013 08:38 PM - edited 03-21-2019 10:02 AM
My phone stopped working, no dial tone, the light indicator for phone 1 was off.
I logged into SPA-112, went to "Voice" menu, the status of line 1 is not registered, but there's no option on the left side to access line 1.
I then tried to reset the unit to get the Quick Setup screen by using a pin to press the RESET slot for over 20 seconds, nothing happened, no reset.
I went into the Administration screen, no option to restore to factory either.
I can't post images here so I have attached the screen print of these 2 options.
How can I update line 1 information or reset the unit?
I also tried to do a firmware upgrade, but no option in Administration screen as well.
Solved! Go to Solution.
04-17-2013 11:47 AM
On the top right of the first screenshot (spa112.jpg) I can see "cisco".
This means that you have logged in with the user account cisco and not with admin account. Can you log in with full administrator account?
04-17-2013 11:47 AM
04-17-2013 04:09 PM
Thanks for letting me know. I logged in as admin and able to resolve the problem.
