09-26-2010 09:12 PM - edited 03-21-2019 09:29 AM
Hi guys.
I'm having problems with some setting on the PAP2t-eu.
I can't seem to find where i can put the settings for:
in the configfile.
I'm using xml as a template and it would be great it you could also reply with the correct xml attribute.
Thanks in advance.
09-29-2010 11:11 AM
admin guide at http://www.cisco.com/en/US/docs/voice_ip_comm/csbpvga/ata/administration/guide/ATA_AG_v3_NC-WEB.pdf
you'll want to look at parameters 'interdigit long timer' and 'interdigit short timer' and see the examples of the options for 'dial plan'.
05-19-2011 12:46 AM
Hello everybody,
parameters 'interdigit long timer' and 'interdigit short timer' instruct ATA how long to wait after the first digit has been entered.
However, which parameter control the waiting time from off-hook to first digit before playing reorder tone?
Francesco
05-19-2011 01:10 AM
Dial Time Planer is what you need and you will find it on Page 67 of the above manual.
Boris
