Problem with SPA122 and Linksys E3000
gestinfoweb.inc
i try to configure , my SPA122 and linksys, but i need your help ,,,
My ISP is Videotron with Ip Static
the WAN go on SPA122 and after go in the Wan router Linksys
My config of SPA122 is
Network Service = NAT
Internet Connection = Static IP (some parameter of ISP give me up)
Network Setting = Router Ip 192.168.15.1
DHCP = Enable
Gateway= 192.168.15.1
Starting Ip = 192.168.15.100
Maximum = 150
_____________________
My config of Linksys E3000
Internet Connection = Automatic
Network Setting = Router Ip 192.168.1.1
DHCP = Enable
Starting Ip = 192.168.1.100
Maximum = 150
When i open the port 192.168.1.108(camera) tcp/udp:1024 under SPA122 at Port Forwarding (Doesn't work, my port was stay closed)
i do the same config under Linksys at Application/Gaming the same port and ip and say the same (port closed) (under web www.canyouseeme.org)
I need some you help ,,
gestinfoweb.inc
No body as solution ,,,,
