5435
Highlighted
Beginner
Problems to send fax with SPA-3102
I have problems with sending fax. We have a multifunction printer cannon iR C2380, and a SPA-3102 ATA. I used the guide:
http://www.3cx.com/sip-phones/linksys-spa-3102-fax.html,
and we have not gotten it to work.
Please could you help me?
Thanks in advanced.
1 ACCEPTED SOLUTION
Highlighted
The problem is caused by a codec negotiation:
Alcatel:
m=audio 32588 RTP/AVP 8 18 97
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=rtpmap:97 telephone-event/8000
SPA:
CC:pc(0)=0 not in codec list
SIP/2.0 488 Not Acceptable Here
Warning: 304 spa "Media type not available"
Can you configure only one codec in both devices, Alcatel and SPA?
E.g. G.711A (a=rtpmap:8 PCMA/8000)
15 REPLIES 15
Highlighted
Rising star
If you followed the guide, you configured the SPA to use T.38 fax relay method.
Is T.38 supported from your VoIP net?
Do you already try RTP passthrough?
If no try this configuration:
- start from the configuration of the guide
- Echo Canc Enable = YES
- FAX Passthru Method = NSE
- FAX Enable T38 = NO
If it doesn't work, add the log of the SPA during a fax call.
Regards.
Highlighted
Good Mornning Daniele,
Where I can activate the logg? How I can access the logg?
Thanks!!
Highlighted
¿Disable pstn line? not need it because we are connected to a LAN.
Highlighted
with the changes that you indicated me the fax indicated the following error: #018
Highlighted
This link explains how enable syslog: https://supportforums.cisco.com/docs/DOC-9897
Is the error #018 generated from new config?
What is the error in previous config?
What is your fax? Canon?
Regards.
Highlighted
Always gives the same error. Is a cannon iR C2380.
Highlighted
Is it possible configure a faciliy in the SPA? I need it to configure syslog.
Highlighted
Is the FAX connected to FXS port of the SPA?
Please add SPA log.
Regards.
Highlighted
The SPA log with fail:
syslog server(port:514) started on Fri Jun 08 14:35:03 2012
fu:0:45f5, 001e 03cc 0001
PRV ec=27
[0]Off Hook
Calling:013346160@172.20.0.33:0
[0:0]AUD ALLOC CALL (port=16454)
[0:0]RTP Rx Up
[0]->172.20.0.33:5060(830)
INVITE sip:013346160@172.20.0.33 SIP/2.0
Via: SIP/2.0/UDP 172.19.5.65:5060;branch=z9hG4bK-be384972
To: <013346160>
Remote-Party-ID: <565030>;screen=yes;party=calling
Call-ID: 9f7e3ea5-3715831e@172.19.5.65
CSeq: 101 INVITE
Max-Forwards: 70
Contact: <565030>
Expires: 240
User-Agent: Linksys/SPA3102-5.2.13(GW002)
Content-Length: 253
Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
Supported: x-sipura, replaces
Content-Type: application/sdp
v=0
o=- 9471744 9471744 IN IP4 172.19.5.65
s=-
c=IN IP4 172.19.5.65
t=0 0
m=audio 16454 RTP/AVP 0 100 101
a=rtpmap:0 PCMU/8000
a=rtpmap:100 NSE/8000
a=fmtp:100 192-193
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:30
a=sendrecv
[0]<<172.20.0.33:5060(245)
SIP/2.0 100 Trying
To: <013346160>
CSeq: 101 INVITE
Content-Length: 0
[0]<<172.20.0.33:5060(425)
Allow: INVITE, ACK, CANCEL, BYE, PRACK, NOTIFY, REFER, SUBSCRIBE, OPTIONS, UPDATE
User-Agent: OmniPCX Enterprise R9.0 h1.301.50
To: <013346160>;tag=342446c0a7dd60c3ff477876bac5312e
CSeq: 101 INVITE
Content-Length: 0
[0]->172.20.0.33:5060(399)
ACK sip:013346160@172.20.0.33 SIP/2.0
CSeq: 101 ACK
Max-Forwards: 70
Contact: <565030>
Content-Length: 0
[0]FM Alert Stop RxTx (c=0024e22c;a=0)
[0:0]AUD Rel Call
CC:Failed w/ Calling
[0]On Hook
Sess Terminated
CC:Clean Up
--- OBJ POOL STAT ---
OP:RTPRXB =  96 ( 96  192)   OP:RTPREB =  40 ( 40   48)
OP:RTPTXB =  64 ( 64  108)   OP:TIMEOU = 111 (120   52)
OP:SIPCOR =   0 (  1   28)   OP:SIPCTS =  32 ( 32  580)
OP:SIPSTS =  32 ( 32 6064)   OP:SIPAUS =   8 (  8  588)
OP:SIPDLG =  10 ( 10  148)   OP:SIPSES =  12 ( 12 8192)
OP:SIPREG =   3 (  4  468)   OP:SIPLIN =   0 (  2  140)
OP:SUBDLG =   2 (  2 6444)   OP:STUNTS =  16 ( 16   68)
[0]Off Hook
Calling:0913346160@172.20.0.33:0
[0:0]AUD ALLOC CALL (port=16456)
[0:0]RTP Rx Up
[0]->172.20.0.33:5060(833)
INVITE sip:0913346160@172.20.0.33 SIP/2.0
Via: SIP/2.0/UDP 172.19.5.65:5060;branch=z9hG4bK-f13ce9b2
To: <0913346160>
Call-ID: 3bfbd956-bfc8eac2@172.19.5.65
CSeq: 101 INVITE
Max-Forwards: 70
Contact: <565030>
Expires: 240
Content-Length: 253
v=0
o=- 9482657 9482657 IN IP4 172.19.5.65
s=-
t=0 0
m=audio 16456 RTP/AVP 0 100 101
a=fmtp:100 192-193
a=fmtp:101 0-15
a=ptime:30
a=sendrecv
[0]<<172.20.0.33:5060(247)
SIP/2.0 100 Trying
To: <0913346160>
CSeq: 101 INVITE
Content-Length: 0
[0]<<172.20.0.33:5060(427)
To: <0913346160>;tag=0d94f452f2706e04f54b93c440ce3349
CSeq: 101 INVITE
Content-Length: 0
[0]->172.20.0.33:5060(402)
ACK sip:0913346160@172.20.0.33 SIP/2.0
CSeq: 101 ACK
Max-Forwards: 70
Contact: <565030>
Content-Length: 0
[0:0]AUD Rel Call
[0]On Hook
Sess Terminated
CC:Clean Up
[0]Off Hook
[0:0]AUD ALLOC CALL (port=16458)
[0:0]RTP Rx Up
[0]->172.20.0.33:5060(831)
Via: SIP/2.0/UDP 172.19.5.65:5060;branch=z9hG4bK-7ab66d92
To: <013346160>
Call-ID: 2ea5d500-7322320a@172.19.5.65
CSeq: 101 INVITE
Max-Forwards: 70
Contact: <565030>
Expires: 240
Content-Length: 253
v=0
o=- 9490571 9490571 IN IP4 172.19.5.65
s=-
t=0 0
m=audio 16458 RTP/AVP 0 100 101
a=fmtp:100 192-193
a=fmtp:101 0-15
a=ptime:30
a=sendrecv
[0]<<172.20.0.33:5060(246)
SIP/2.0 100 Trying
To: <013346160>
CSeq: 101 INVITE
Content-Length: 0
[0]<<172.20.0.33:5060(426)
To: <013346160>;tag=909c966554ae490c8fa3d3472c1a09f1
CSeq: 101 INVITE
Content-Length: 0
[0]->172.20.0.33:5060(400)
CSeq: 101 ACK
Max-Forwards: 70
Contact: <565030>
Content-Length: 0
[0:0]AUD Rel Call
[0]On Hook
Sess Terminated
CC:Clean Up
[0]Off Hook
SDP RTPMAP 97 --> 136
[0]<<172.20.0.33:5060(957)
INVITE sip:565030@172.19.5.65:5060 SIP/2.0
Allow: INVITE, ACK, CANCEL, BYE, PRACK, NOTIFY, REFER, SUBSCRIBE, OPTIONS, UPDATE, INFO
Supported: replaces,timer,100rel
Session-Expires: 300;refresher=uac
Min-SE: 150
To: <565030>
From: "968185096" <0968185096>;tag=fc9a3e4b302aaa7729a3a3c6ffd74afd
Contact: <172.20.0.33>
Call-ID: 60f725de874099eb6bb5f3ce11159e69@172.20.0.33
CSeq: 2127889927 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bKdcd270c551bf299a6ab6ac9107b50f0e
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339159633 1339159633 IN IP4 172.20.0.33
s=abs
c=IN IP4 172.20.0.46
t=0 0
m=audio 32748 RTP/AVP 8 18 97
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
[0]->172.20.0.33:5060(374)
SIP/2.0 100 Trying
To: <565030>
Server: Linksys/SPA3102-5.2.13(GW002)
Content-Length: 0
SIP/2.0 486 Busy Here
To: <565030>;tag=d00b639d26f55d39i0
Content-Length: 0
[0]<<172.20.0.33:5060(376)
ACK sip:565030@172.19.5.65:5060 SIP/2.0
CSeq: 2127889927 ACK
Content-Length: 0
[0:0]AUD ALLOC CALL (port=16460)
[0:0]RTP Rx Up
Via: SIP/2.0/UDP 172.19.5.65:5060;branch=z9hG4bK-e664f302
To: <0913346160>
Call-ID: 106751b1-bb93241e@172.19.5.65
CSeq: 101 INVITE
Max-Forwards: 70
Contact: <565030>
Expires: 240
Content-Length: 253
v=0
o=- 9502620 9502620 IN IP4 172.19.5.65
s=-
t=0 0
m=audio 16460 RTP/AVP 0 100 101
a=fmtp:100 192-193
a=fmtp:101 0-15
a=ptime:30
a=sendrecv
SIP/2.0 100 Trying
To: <0913346160>
CSeq: 101 INVITE
Content-Length: 0
To: <0913346160>;tag=19c2aea5b3d99db1f38c56c51df96014
CSeq: 101 INVITE
Content-Length: 0
CSeq: 101 ACK
Max-Forwards: 70
Contact: <565030>
Content-Length: 0
[0:0]AUD Rel Call
[0]On Hook
[0]Off Hook
[0:0]AUD ALLOC CALL (port=16462)
[0:0]RTP Rx Up
Via: SIP/2.0/UDP 172.19.5.65:5060;branch=z9hG4bK-257521d2
To: <013346160>
Call-ID: a9951607-484546c6@172.19.5.65
CSeq: 101 INVITE
Max-Forwards: 70
Contact: <565030>
Expires: 240
Content-Length: 253
v=0
o=- 9505442 9505442 IN IP4 172.19.5.65
s=-
t=0 0
m=audio 16462 RTP/AVP 0 100 101
a=fmtp:100 192-193
a=fmtp:101 0-15
a=ptime:30
a=sendrecv
SIP/2.0 100 Trying
To: <013346160>
CSeq: 101 INVITE
Content-Length: 0
To: <013346160>;tag=ce712b4cfd340b6dc9e8243e5a53e03b
CSeq: 101 INVITE
Content-Length: 0
CSeq: 101 ACK
Max-Forwards: 70
Contact: <565030>
Content-Length: 0
[0:0]AUD Rel Call
[0]On Hook
Sess Terminated
Sess Terminated
CC:Clean Up
[0]Off Hook
[0:0]AUD ALLOC CALL (port=16464)
[0:0]RTP Rx Up
Via: SIP/2.0/UDP 172.19.5.65:5060;branch=z9hG4bK-f34ce7e2
To: <0913346160>
Call-ID: c67e70ab-d5c947a6@172.19.5.65
CSeq: 101 INVITE
Max-Forwards: 70
Contact: <565030>
Expires: 240
Content-Length: 253
v=0
o=- 9520598 9520598 IN IP4 172.19.5.65
s=-
t=0 0
m=audio 16464 RTP/AVP 0 100 101
a=fmtp:100 192-193
a=fmtp:101 0-15
a=ptime:30
a=sendrecv
SIP/2.0 100 Trying
To: <0913346160>
CSeq: 101 INVITE
Content-Length: 0
To: <0913346160>;tag=9e19435ef61ac24996366d311beed731
CSeq: 101 INVITE
Content-Length: 0
CSeq: 101 ACK
Max-Forwards: 70
Contact: <565030>
Content-Length: 0
[0:0]AUD Rel Call
[0]On Hook
Sess Terminated
CC:Clean Up
[0]<<172.20.0.33:5060(956)
Min-SE: 150
To: <565030>
From: "968185096" <0968185096>;tag=eac6eaa19bc71c93eb94606405564b2a
Call-ID: b162b2ba9785f5e33781cd5c8d65de98@172.20.0.33
CSeq: 585591440 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bK05120edb378c5d3b3bce4f95fca0187b
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339159882 1339159882 IN IP4 172.20.0.33
s=abs
c=IN IP4 172.20.0.45
t=0 0
m=audio 32552 RTP/AVP 8 18 97
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
[0]->172.20.0.33:5060(373)
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
[0]->172.20.0.33:5060(454)
Content-Length: 0
[0]<<172.20.0.33:5060(375)
CSeq: 585591440 ACK
Content-Length: 0
Highlighted
As you can see in the log file, your SPA sends an INVITE to the IP 172.20.0.33:5060 (Alcatel) with these media informations:
The Alcatel rejects the call with the reason:
When the Alcatel send an INVITE to the SPA, it uses these media:
a=fmtp:18 annexb=no
but the SPA rejects the call with this reason:
Try to configure the codec and the NTE in the SPA to match with the Alcatel:
- Line Menu - Audio Configuration Menu
Preferred Codec = G711a
Fax Pass Through Codec = G711a
- SIP Menu - SDP Payload Types
AVT Dynamic Payload = 97 (default 101)
G726r24 Dynamic Payload = 99 (default 97)
In negative case add new log.
Regards.
Highlighted
The test has been failed. The logg:
syslog server(port:514) started on Mon Jun 11 09:04:35 2012
[0]Off Hook
[0:0]AUD ALLOC CALL (port=16466)
[0:0]RTP Rx Up
[0]->172.20.0.33:5060(832)
Via: SIP/2.0/UDP 172.19.5.65:5060;branch=z9hG4bK-745b3dad
To: <0913346160>
Call-ID: cbaac646-66522eb1@172.19.5.65
CSeq: 101 INVITE
Max-Forwards: 70
Contact: <565030>
Expires: 240
Content-Length: 252
v=0
o=- 33390016 33390016 IN IP4 172.19.5.65
s=-
t=0 0
m=audio 16466 RTP/AVP 8 100 97
a=fmtp:100 192-193
a=fmtp:97 0-15
a=ptime:30
a=sendrecv
SIP/2.0 100 Trying
To: <0913346160>
CSeq: 101 INVITE
Content-Length: 0
[0:0]RTP Rx 1st PKT @16466(2)
[0:0]DEC INIT 8
[0]<<172.20.0.33:5060(686)
SIP/2.0 180 Ringing
Contact: sip:172.20.0.33
To: <0913346160>;tag=87ebb0aa988d8058ba29f7bae2fec62e
CSeq: 101 INVITE
Content-Length: 212
v=0
o=OXE 1339398508 1339398508 IN IP4 172.20.0.33
s=abs
c=IN IP4 172.20.0.42
t=0 0
m=audio 32620 RTP/AVP 8 97
a=ptime:20
a=maxptime:30
a=sendrecv
[0:0]ENC INIT 8
[0:0]RTP Tx Up (pt=8->ac14002a:32620)
[0:0]RTCP Tx Up
CC:CallProgress
[0]adp line session start
[0]AUD:FAX Event=2
[0:0]ENC INIT 8
[0]<<172.20.0.33:5060(809)
SIP/2.0 200 OK
Session-Expires: 300;refresher=uas
P-Asserted-Identity: "RDSI" <172.20.0.33>
CSeq: 101 INVITE
Content-Length: 212
v=0
o=OXE 1339398508 1339398509 IN IP4 172.20.0.33
s=abs
t=0 0
a=ptime:20
a=maxptime:30
a=sendrecv
[0:0]RTP Tx Dn
[0:0]ENC INIT 8
CC:Remote Resume
CC:Connected
[0]->172.20.0.33:5060(391)
ACK sip:172.20.0.33 SIP/2.0
Via: SIP/2.0/UDP 172.19.5.65:5060;branch=z9hG4bK-e9e137c3
CSeq: 101 ACK
Max-Forwards: 70
Contact: <565030>
Content-Length: 0
[0]<<172.20.0.33:5060(893)
Min-SE: 150
To: sip:565030@172.20.0.33;tag=724a69428b5087e5o0
From: sip:0913346160@172.20.0.33;tag=87ebb0aa988d8058ba29f7bae2fec62e
CSeq: 1257930942 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bK4a7d765e068b62e2b320d5ae5e962b0d
Max-Forwards: 70
Content-Length: 274
v=0
o=OXE 1339398508 1339398510 IN IP4 172.20.0.33
s=abs
t=0 0
m=image 32623 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:9600
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:256
a=T38FaxMaxDatagram:256
a=T38FaxUdpEC:t38UDPRedundancy
DLG:ReAllocCodecList
[0]->172.20.0.33:5060(442)
Contact: <565030>
Content-Length: 0
[0]<<172.20.0.33:5060(323)
CSeq: 1257930942 ACK
Content-Length: 0
[0]<<172.20.0.33:5060(422)
BYE sip:565030@172.19.5.65:5060 SIP/2.0
CSeq: 1257930943 BYE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bK28704f069a3f6ec54c8957ef2d5b4098
Max-Forwards: 70
Content-Length: 0
[0]->172.20.0.33:5060(337)
SIP/2.0 200 OK
Content-Length: 0
CC:Ended
[0:0]AUD Rel Call
[0]adp line session stop
[0] duration:9 s
[0] duration:9 s
path:nb_in, did:50, start at 0 s
path:nb_out, did:51, start at 0 s
path:full, did:52, start at 0 s
DLG Terminated 298b84
Sess Terminated
[0]On Hook
[0]Off Hook
Calling:0968180220@172.20.0.33:0
[0:0]AUD ALLOC CALL (port=16468)
[0:0]RTP Rx Up
INVITE sip:0968180220@172.20.0.33 SIP/2.0
Via: SIP/2.0/UDP 172.19.5.65:5060;branch=z9hG4bK-c5bf2133
To: <0968180220>
Call-ID: f66fc022-a8a03b4f@172.19.5.65
CSeq: 101 INVITE
Max-Forwards: 70
Contact: <565030>
Expires: 240
Content-Length: 252
v=0
o=- 33397386 33397386 IN IP4 172.19.5.65
s=-
t=0 0
m=audio 16468 RTP/AVP 8 100 97
a=fmtp:100 192-193
a=fmtp:97 0-15
a=ptime:30
a=sendrecv
SIP/2.0 100 Trying
To: <0968180220>
CSeq: 101 INVITE
Content-Length: 0
[0:0]RTP Rx 1st PKT @16468(2)
[0:0]DEC INIT 8
SIP/2.0 180 Ringing
To: <0968180220>;tag=d81a9ee1c704bf270f05f027d856e3c3
CSeq: 101 INVITE
Content-Length: 212
v=0
o=OXE 1339398582 1339398582 IN IP4 172.20.0.33
s=abs
c=IN IP4 172.20.0.44
t=0 0
m=audio 32688 RTP/AVP 8 97
a=ptime:20
a=maxptime:30
a=sendrecv
[0:0]ENC INIT 8
[0:0]RTP Tx Up (pt=8->ac14002c:32688)
[0:0]RTCP Tx Up
CC:CallProgress
[0]AUD:FAX Event=2
[0:0]ENC INIT 8
SIP/2.0 200 OK
CSeq: 101 INVITE
Content-Length: 212
v=0
o=OXE 1339398582 1339398583 IN IP4 172.20.0.33
s=abs
t=0 0
a=ptime:20
a=maxptime:30
a=sendrecv
[0:0]RTP Tx Dn
[0:0]ENC INIT 8
CC:Remote Resume
CC:Connected
Via: SIP/2.0/UDP 172.19.5.65:5060;branch=z9hG4bK-6615966d
CSeq: 101 ACK
Max-Forwards: 70
Contact: <565030>
Content-Length: 0
[0]<<172.20.0.33:5060(892)
Min-SE: 150
To: sip:565030@172.20.0.33;tag=b35bb206679052bbo0
From: sip:0968180220@172.20.0.33;tag=d81a9ee1c704bf270f05f027d856e3c3
CSeq: 678974966 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bK93164b3800272258a15bfc5bd4ab3663
Max-Forwards: 70
Content-Length: 274
v=0
o=OXE 1339398582 1339398584 IN IP4 172.20.0.33
s=abs
t=0 0
m=image 32691 udptl t38
a=T38FaxVersion:0
[0]->172.20.0.33:5060(441)
Contact: <565030>
Content-Length: 0
[0]<<172.20.0.33:5060(322)
CSeq: 678974966 ACK
Content-Length: 0
[0]<<172.20.0.33:5060(421)
CSeq: 678974967 BYE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bKe73c91b4551f5255ccb5dcd50d49d90b
Max-Forwards: 70
Content-Length: 0
[0]->172.20.0.33:5060(336)
SIP/2.0 200 OK
CSeq: 678974967 BYE
Content-Length: 0
CC:Ended
[0:0]AUD Rel Call
[0] duration:26 s
[0] duration:26 s
path:nb_in, did:50, start at 9 s
path:nb_out, did:51, start at 9 s
path:full, did:52, start at 9 s
Min-SE: 150
To: <565030>
From: "966347041" <0966347041>;tag=eda684365ecf7b8c25ef679d3ce8725b
Call-ID: bcbd993b63f19705a65863b177b54482@172.20.0.33
CSeq: 943771660 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bKd6bff05ae49bf119641ccaf257350bdf
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339398629 1339398629 IN IP4 172.20.0.33
s=abs
t=0 0
m=audio 32724 RTP/AVP 8 18 97
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
Content-Length: 0
CSeq: 943771660 ACK
Content-Length: 0
DLG Terminated 298c18
Sess Terminated
[0]On Hook
CC:Clean Up
[0]Off Hook
[0:0]AUD ALLOC CALL (port=16470)
[0:0]RTP Rx Up
Via: SIP/2.0/UDP 172.19.5.65:5060;branch=z9hG4bK-dbe3bb6d
To: <0913346160>
Call-ID: f98a1e3d-d532b8ad@172.19.5.65
CSeq: 101 INVITE
Max-Forwards: 70
Contact: <565030>
Expires: 240
Content-Length: 252
v=0
o=- 33412935 33412935 IN IP4 172.19.5.65
s=-
t=0 0
m=audio 16470 RTP/AVP 8 100 97
a=fmtp:100 192-193
a=fmtp:97 0-15
a=ptime:30
a=sendrecv
SIP/2.0 100 Trying
To: <0913346160>
CSeq: 101 INVITE
Content-Length: 0
[0:0]RTP Rx 1st PKT @16470(2)
[0:0]DEC INIT 8
SIP/2.0 180 Ringing
To: <0913346160>;tag=fe6d1ed324d18bdb34d718032a6eda62
CSeq: 101 INVITE
Content-Length: 212
v=0
o=OXE 1339398737 1339398737 IN IP4 172.20.0.33
s=abs
c=IN IP4 172.20.0.43
t=0 0
m=audio 32736 RTP/AVP 8 97
a=ptime:20
a=maxptime:30
a=sendrecv
[0:0]ENC INIT 8
[0:0]RTP Tx Up (pt=8->ac14002b:32736)
[0:0]RTCP Tx Up
CC:CallProgress
[0]AUD:FAX Event=2
[0:0]ENC INIT 8
SIP/2.0 200 OK
CSeq: 101 INVITE
Content-Length: 212
v=0
o=OXE 1339398737 1339398738 IN IP4 172.20.0.33
s=abs
t=0 0
a=ptime:20
a=maxptime:30
a=sendrecv
[0:0]RTP Tx Dn
[0:0]ENC INIT 8
CC:Remote Resume
CC:Connected
Via: SIP/2.0/UDP 172.19.5.65:5060;branch=z9hG4bK-5ae328fd
CSeq: 101 ACK
Max-Forwards: 70
Contact: <565030>
Content-Length: 0
Min-SE: 150
To: sip:565030@172.20.0.33;tag=422560fd2b3254edo0
From: sip:0913346160@172.20.0.33;tag=fe6d1ed324d18bdb34d718032a6eda62
CSeq: 223660746 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bK7b9b94bbaa70c70b59bf210044bfdc56
Max-Forwards: 70
Content-Length: 274
v=0
o=OXE 1339398737 1339398739 IN IP4 172.20.0.33
s=abs
t=0 0
m=image 32739 udptl t38
a=T38FaxVersion:0
Contact: <565030>
Content-Length: 0
CSeq: 223660746 ACK
Content-Length: 0
CSeq: 223660747 BYE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bK3edb675d264ec23ea4c0d34d6c70edcb
Max-Forwards: 70
Content-Length: 0
SIP/2.0 200 OK
CSeq: 223660747 BYE
Content-Length: 0
CC:Ended
[0:0]AUD Rel Call
[0] duration:9 s
[0] duration:9 s
path:nb_in, did:50, start at 35 s
path:nb_out, did:51, start at 35 s
path:full, did:52, start at 35 s
DLG Terminated 298cac
Sess Terminated
[0]On Hook
[0]Off Hook
[0:0]AUD ALLOC CALL (port=16472)
[0:0]RTP Rx Up
Via: SIP/2.0/UDP 172.19.5.65:5060;branch=z9hG4bK-c699e18d
To: <0968180220>
Call-ID: 304f49be-312f37f1@172.19.5.65
CSeq: 101 INVITE
Max-Forwards: 70
Contact: <565030>
Expires: 240
Content-Length: 252
v=0
o=- 33420312 33420312 IN IP4 172.19.5.65
s=-
t=0 0
m=audio 16472 RTP/AVP 8 100 97
a=fmtp:100 192-193
a=fmtp:97 0-15
a=ptime:30
a=sendrecv
SIP/2.0 100 Trying
To: <0968180220>
CSeq: 101 INVITE
Content-Length: 0
[0:0]RTP Rx 1st PKT @16472(2)
[0:0]DEC INIT 8
SIP/2.0 180 Ringing
To: <0968180220>;tag=9329cc8e83d9dfc59bc7cdee744fe720
CSeq: 101 INVITE
Content-Length: 212
v=0
o=OXE 1339398811 1339398811 IN IP4 172.20.0.33
s=abs
t=0 0
m=audio 32576 RTP/AVP 8 97
a=ptime:20
a=maxptime:30
a=sendrecv
[0:0]ENC INIT 8
[0:0]RTP Tx Up (pt=8->ac14002d:32576)
[0:0]RTCP Tx Up
CC:CallProgress
[0]AUD:FAX Event=2
[0:0]ENC INIT 8
SIP/2.0 200 OK
CSeq: 101 INVITE
Content-Length: 212
v=0
o=OXE 1339398811 1339398812 IN IP4 172.20.0.33
s=abs
t=0 0
a=ptime:20
a=maxptime:30
a=sendrecv
[0:0]RTP Tx Dn
[0:0]ENC INIT 8
CC:Remote Resume
CC:Connected
Via: SIP/2.0/UDP 172.19.5.65:5060;branch=z9hG4bK-fa301f60
CSeq: 101 ACK
Max-Forwards: 70
Contact: <565030>
Content-Length: 0
Min-SE: 150
To: sip:565030@172.20.0.33;tag=504f675a3df65705o0
From: sip:0968180220@172.20.0.33;tag=9329cc8e83d9dfc59bc7cdee744fe720
CSeq: 745025091 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bK529cd3289c430c9d5e211959013176b6
Max-Forwards: 70
Content-Length: 274
v=0
o=OXE 1339398811 1339398813 IN IP4 172.20.0.33
s=abs
t=0 0
m=image 32579 udptl t38
a=T38FaxVersion:0
Contact: <565030>
Content-Length: 0
CSeq: 745025091 ACK
Content-Length: 0
CSeq: 745025092 BYE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bK6212d8839dbc1d1cffb9f9eb319f8d00
Max-Forwards: 70
Content-Length: 0
SIP/2.0 200 OK
CSeq: 745025092 BYE
Content-Length: 0
CC:Ended
[0:0]AUD Rel Call
[0] duration:25 s
[0] duration:25 s
path:nb_in, did:50, start at 44 s
path:nb_out, did:51, start at 44 s
path:full, did:52, start at 44 s
DLG Terminated 298d40
Sess Terminated
[0]On Hook
CC:Clean Up
[0]Off Hook
[0:0]AUD ALLOC CALL (port=16474)
[0:0]RTP Rx Up
Via: SIP/2.0/UDP 172.19.5.65:5060;branch=z9hG4bK-35ad6e50
To: <0913346160>
Call-ID: 8d2cf57-d20787cc@172.19.5.65
CSeq: 101 INVITE
Max-Forwards: 70
Contact: <565030>
Expires: 240
Content-Length: 252
v=0
o=- 33436856 33436856 IN IP4 172.19.5.65
s=-
t=0 0
m=audio 16474 RTP/AVP 8 100 97
a=fmtp:100 192-193
a=fmtp:97 0-15
a=ptime:30
a=sendrecv
SIP/2.0 100 Trying
To: <0913346160>
CSeq: 101 INVITE
Content-Length: 0
[0:0]RTP Rx 1st PKT @16474(2)
[0:0]DEC INIT 8
[0]<<172.20.0.33:5060(685)
SIP/2.0 180 Ringing
To: <0913346160>;tag=2d56e55b6b16803b4f9e6500dedaf500
CSeq: 101 INVITE
Content-Length: 212
v=0
o=OXE 1339398976 1339398976 IN IP4 172.20.0.33
s=abs
t=0 0
m=audio 32552 RTP/AVP 8 97
a=ptime:20
a=maxptime:30
a=sendrecv
[0:0]ENC INIT 8
[0:0]RTP Tx Up (pt=8->ac14002b:32552)
[0:0]RTCP Tx Up
CC:CallProgress
[0]AUD:FAX Event=2
[0:0]ENC INIT 8
[0]<<172.20.0.33:5060(808)
SIP/2.0 200 OK
CSeq: 101 INVITE
Content-Length: 212
v=0
o=OXE 1339398976 1339398977 IN IP4 172.20.0.33
s=abs
t=0 0
a=ptime:20
a=maxptime:30
a=sendrecv
[0:0]RTP Tx Dn
[0:0]ENC INIT 8
CC:Remote Resume
CC:Connected
[0]->172.20.0.33:5060(390)
Via: SIP/2.0/UDP 172.19.5.65:5060;branch=z9hG4bK-1f7a77c2
CSeq: 101 ACK
Max-Forwards: 70
Contact: <565030>
Content-Length: 0
Min-SE: 150
To: sip:565030@172.20.0.33;tag=fd06a1db5a903718o0
From: sip:0913346160@172.20.0.33;tag=2d56e55b6b16803b4f9e6500dedaf500
CSeq: 1282893387 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bK7865775cc65ab0fe7b60e636e8ccc4ff
Max-Forwards: 70
Content-Length: 274
v=0
o=OXE 1339398976 1339398978 IN IP4 172.20.0.33
s=abs
t=0 0
m=image 32555 udptl t38
a=T38FaxVersion:0
Contact: <565030>
Content-Length: 0
CSeq: 1282893387 ACK
Content-Length: 0
CSeq: 1282893388 BYE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bK22b34feb898bd64d6e8272f9adc30166
Max-Forwards: 70
Content-Length: 0
SIP/2.0 200 OK
Content-Length: 0
CC:Ended
[0:0]AUD Rel Call
[0] duration:8 s
[0] duration:8 s
path:nb_in, did:50, start at 69 s
path:nb_out, did:51, start at 69 s
path:full, did:52, start at 69 s
DLG Terminated 298dd4
Sess Terminated
[0]On Hook
[0]Off Hook
[0:0]AUD ALLOC CALL (port=16476)
[0:0]RTP Rx Up
Via: SIP/2.0/UDP 172.19.5.65:5060;branch=z9hG4bK-3d5fc52
To: <0968180220>
Call-ID: 77fc9f43-a70035b6@172.19.5.65
CSeq: 101 INVITE
Max-Forwards: 70
Contact: <565030>
Expires: 240
Content-Length: 252
v=0
o=- 33444254 33444254 IN IP4 172.19.5.65
s=-
t=0 0
m=audio 16476 RTP/AVP 8 100 97
a=fmtp:100 192-193
a=fmtp:97 0-15
a=ptime:30
a=sendrecv
SIP/2.0 100 Trying
To: <0968180220>
CSeq: 101 INVITE
Content-Length: 0
[0:0]RTP Rx 1st PKT @16476(2)
[0:0]DEC INIT 8
SIP/2.0 180 Ringing
To: <0968180220>;tag=03b777bce7b4b5c93d5422a4e4668440
CSeq: 101 INVITE
Content-Length: 212
v=0
o=OXE 1339399050 1339399050 IN IP4 172.20.0.33
s=abs
t=0 0
a=ptime:20
a=maxptime:30
a=sendrecv
[0:0]ENC INIT 8
[0:0]RTP Tx Up (pt=8->ac14002c:32620)
[0:0]RTCP Tx Up
CC:CallProgress
[0]AUD:FAX Event=2
[0:0]ENC INIT 8
SIP/2.0 200 OK
CSeq: 101 INVITE
Content-Length: 212
v=0
o=OXE 1339399050 1339399051 IN IP4 172.20.0.33
s=abs
t=0 0
a=ptime:20
a=maxptime:30
a=sendrecv
[0:0]RTP Tx Dn
[0:0]ENC INIT 8
CC:Remote Resume
CC:Connected
Via: SIP/2.0/UDP 172.19.5.65:5060;branch=z9hG4bK-9489018a
CSeq: 101 ACK
Max-Forwards: 70
Contact: <565030>
Content-Length: 0
Min-SE: 150
To: sip:565030@172.20.0.33;tag=bcf6d9dfb34bdbcao0
From: sip:0968180220@172.20.0.33;tag=03b777bce7b4b5c93d5422a4e4668440
CSeq: 1941543501 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bK9f16adf106c7e73148330ff2838a4c27
Max-Forwards: 70
Content-Length: 274
v=0
o=OXE 1339399050 1339399052 IN IP4 172.20.0.33
s=abs
t=0 0
a=T38FaxVersion:0
Contact: <565030>
Content-Length: 0
CSeq: 1941543501 ACK
Content-Length: 0
CSeq: 1941543502 BYE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bKfe3117f76add5572e521197fc0ed1238
Max-Forwards: 70
Content-Length: 0
SIP/2.0 200 OK
Content-Length: 0
CC:Ended
[0:0]AUD Rel Call
[0] duration:26 s
[0] duration:26 s
path:nb_in, did:50, start at 77 s
path:nb_out, did:51, start at 77 s
path:full, did:52, start at 77 s
DLG Terminated 298e68
Sess Terminated
[0]On Hook
CC:Clean Up
Highlighted
users have informed me that they could not receive fax. we have changed the parameter FAX Passthru Method to reinvite and fax them back to receive. But still having problmes to sending.
Highlighted
Now the SPA sends this SIP INVITE:
and the Alcatel responds with:
SIP/2.0 200 OK
In this way the call is estabilished and not rejected with 488 but the fax uses RTP passthrough method.
If you have changed the parameter FAX Passthru Method to reinvite you have enabled T.38 after connection.
Good.
When the call starts from Alcatel the SPA rejects it:
a=T38FaxVersion:0
SPA response:
Do you have also changed the option FAX Enable T38 to YES?
Probably the problem was only in the codec (g.711u instead of g.711a).
Regards.
Highlighted
with G711u not have dial tone.
Logg:
syslog server(port:514) started on Mon Jun 11 11:50:45 2012
Min-SE: 150
To: <565030>
From: "968522502" <0968522502>;tag=5917dc90ba398f31f8ebdb42a3d5880f
Call-ID: c46b2acb83ae3e5df73ad54fc9c552e0@172.20.0.33
CSeq: 1778336737 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bK40dd7a0dff33e60e159ae4e8fef7fb27
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339408427 1339408427 IN IP4 172.20.0.33
s=abs
t=0 0
m=audio 32664 RTP/AVP 8 18 97
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
[0]->172.20.0.33:5060(455)
Content-Length: 0
CSeq: 1778336737 ACK
Content-Length: 0
Min-SE: 150
To: <565030>
From: "968522502" <0968522502>;tag=e80bd7aa168162dd50e3125bac38c222
Call-ID: 6077c1a5366effee6c2e89e63031ae25@172.20.0.33
CSeq: 1720067806 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bK6132584bbe3a0d438eefac08f2ea689d
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339408516 1339408516 IN IP4 172.20.0.33
s=abs
t=0 0
m=audio 32684 RTP/AVP 8 18 97
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
Content-Length: 0
CSeq: 1720067806 ACK
Content-Length: 0
[0]<<172.20.0.33:5060(1009)
Min-SE: 150
Privacy: user
To: <565030>
From: sip:anonymous@anonymous.invalid;tag=a94db04d64e036aba4e3cb38ce8363e8
Call-ID: 91ffd88e84b65cc653e3c1ac7bf86916@172.20.0.33
CSeq: 847369662 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bKc99a45a88b27f4c9d58ba0b75f65d150
Max-Forwards: 70
Content-Length: 286
v=0
s=abs
t=0 0
m=audio 32692 RTP/AVP 8 18 97
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
[0]->172.20.0.33:5060(353)
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
[0]->172.20.0.33:5060(434)
Content-Length: 0
[0]<<172.20.0.33:5060(355)
CSeq: 847369662 ACK
Content-Length: 0
Min-SE: 150
To: <565030>
From: "913782233" <0913782233>;tag=78b48626173d97933c47bef635362479
Call-ID: 21ca073693f9f41acd4eebd849941e77@172.20.0.33
CSeq: 408836063 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bKe0f0a70582f0f10e84094698877edd7a
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339408584 1339408584 IN IP4 172.20.0.33
s=abs
t=0 0
m=audio 32624 RTP/AVP 8 18 97
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
Content-Length: 0
CSeq: 408836063 ACK
Content-Length: 0
Min-SE: 150
To: <565030>
From: "968185096" <0968185096>;tag=ad00598cfbbe9615bfc802e7e9cf0b3c
Call-ID: dfa323d0f11820e7dc035cbfb79d3972@172.20.0.33
CSeq: 823620935 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bKa0812c7f13282aa2fa312f8c83e3c6a4
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339408585 1339408585 IN IP4 172.20.0.33
s=abs
t=0 0
m=audio 32632 RTP/AVP 8 18 97
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
Content-Length: 0
CSeq: 823620935 ACK
Content-Length: 0
Min-SE: 150
To: <565030>
From: "968522502" <0968522502>;tag=33d0442cbee983ec619fbee279aee27f
Call-ID: c73317b02a9829e5c8d7533bb3893162@172.20.0.33
CSeq: 726514040 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bKb11e3828356c05dca2f34f438471a920
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339408766 1339408766 IN IP4 172.20.0.33
s=abs
t=0 0
m=audio 32648 RTP/AVP 8 18 97
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
Content-Length: 0
CSeq: 726514040 ACK
Content-Length: 0
Min-SE: 150
Privacy: user
To: <565030>
From: sip:anonymous@anonymous.invalid;tag=e1b664f02217d341bc39fae010e23bd0
Call-ID: 21caa5c77c6bd7e66b5fa8a760e67c08@172.20.0.33
CSeq: 637966459 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bK2b77d2bcd796a7e2de0c1ede31e39b99
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339408819 1339408819 IN IP4 172.20.0.33
s=abs
t=0 0
m=audio 32676 RTP/AVP 8 18 97
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
Content-Length: 0
CSeq: 637966459 ACK
Content-Length: 0
Min-SE: 150
To: <565030>
From: "968522502" <0968522502>;tag=0a45fa25250b89eba989e38926056ad6
Call-ID: 909457d3b1d58fe1cd30caf86be7f9f1@172.20.0.33
CSeq: 477226749 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bK9654db50bc98f067b5158f9f26614367
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339408854 1339408854 IN IP4 172.20.0.33
s=abs
t=0 0
m=audio 32660 RTP/AVP 8 18 97
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
Content-Length: 0
CSeq: 477226749 ACK
Content-Length: 0
Min-SE: 150
To: <565030>
From: "968185096" <0968185096>;tag=a83f121c8cd7986653920a0fb5641c23
Call-ID: ccc60efeea2b0f105eba2546cf341221@172.20.0.33
CSeq: 410147779 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bK7b1ab696332e6fafbeea1dab0cf54c1d
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339408889 1339408889 IN IP4 172.20.0.33
s=abs
t=0 0
m=audio 32556 RTP/AVP 8 18 97
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
Content-Length: 0
CSeq: 410147779 ACK
Content-Length: 0
Min-SE: 150
To: <565030>
From: "968504243" <0968504243>;tag=db95ff8e89cd32f3c1ad5c54959e087a
Call-ID: b358e916c5c265a3e6c5b0e4fd4d80c4@172.20.0.33
CSeq: 449486424 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bK7ca0dab57d7fd2e8a75851d69ab98c24
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339408895 1339408895 IN IP4 172.20.0.33
s=abs
t=0 0
m=audio 32752 RTP/AVP 8 18 97
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
Content-Length: 0
CSeq: 449486424 ACK
Content-Length: 0
Min-SE: 150
To: <565030>
From: "968522502" <0968522502>;tag=f3a7a5302769172ae86d67a38d3f7f86
Call-ID: 5db1980e7e740f6311cb0218d43c1720@172.20.0.33
CSeq: 173006216 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bK10c2ba19dbb6038d17b6039023e435d2
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339409105 1339409105 IN IP4 172.20.0.33
s=abs
t=0 0
m=audio 32636 RTP/AVP 8 18 97
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
Content-Length: 0
CSeq: 173006216 ACK
Content-Length: 0
Min-SE: 150
Privacy: user
To: <565030>
From: sip:anonymous@anonymous.invalid;tag=60a3364e6587d144a08e98ba7f3eb7a9
Call-ID: 6b89926d854017d06a914d0fccc0138a@172.20.0.33
CSeq: 138195710 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bKb786092b9b056f57b1af9df480f2842a
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339409120 1339409120 IN IP4 172.20.0.33
s=abs
t=0 0
m=audio 32600 RTP/AVP 8 18 97
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
Content-Length: 0
CSeq: 138195710 ACK
Content-Length: 0
Min-SE: 150
To: <565030>
From: "968520225" <0968520225>;tag=c40ae3d493f6fbfe2d4c90619e22171c
Call-ID: b224973233e4b78f649292f66b45ad29@172.20.0.33
CSeq: 1720321756 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bK7f26241204feb2356b6cac65a03ea9d3
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339409126 1339409126 IN IP4 172.20.0.33
s=abs
t=0 0
m=audio 32564 RTP/AVP 8 18 97
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
Content-Length: 0
CSeq: 1720321756 ACK
Content-Length: 0
Min-SE: 150
To: <565030>
From: "968520225" <0968520225>;tag=4a0a9e4b5407c5f0a73efaacfe3af2ea
Call-ID: 683152faff266652fd2d9d8af9ac7825@172.20.0.33
CSeq: 279525873 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bK706ae68a9ab3cbbf54bb67aeee61ae45
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339409141 1339409141 IN IP4 172.20.0.33
s=abs
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
Content-Length: 0
CSeq: 279525873 ACK
Content-Length: 0
Min-SE: 150
To: <565030>
From: "968522502" <0968522502>;tag=4ae9f933b4562cb8d90346148022889e
Call-ID: 953ed9478070d2315d5501a3f029b681@172.20.0.33
CSeq: 181988269 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bK8f9a3b4cf29200111e8cb6bae66bb0e5
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339409193 1339409193 IN IP4 172.20.0.33
s=abs
t=0 0
m=audio 32604 RTP/AVP 8 18 97
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
Content-Length: 0
CSeq: 181988269 ACK
Content-Length: 0
Min-SE: 150
To: <565030>
From: "968185096" <0968185096>;tag=c613b3b3395e1c7b1ee2ed092e4083f7
Call-ID: 757393bad38ac09ddb3297d4d4d23da1@172.20.0.33
CSeq: 2104917303 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bKfd1f496be7210d9b21c442ff6577bdce
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339409221 1339409221 IN IP4 172.20.0.33
s=abs
t=0 0
m=audio 32584 RTP/AVP 8 18 97
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
Content-Length: 0
CSeq: 2104917303 ACK
Content-Length: 0
Min-SE: 150
To: <565030>
From: "968185096" <0968185096>;tag=a868ec50a63346b1d1f7e56f53a99a1d
Call-ID: a2ae9e588bb13bd243ce448fdfa5622b@172.20.0.33
CSeq: 1592233633 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bKc1af0cb796e5203d272afa14d58d41dd
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339409488 1339409488 IN IP4 172.20.0.33
s=abs
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
Content-Length: 0
CSeq: 1592233633 ACK
Content-Length: 0
[0]<<172.20.0.33:5060(955)
Min-SE: 150
To: <565030>
From: "968522502" <0968522502>;tag=44852084273dd34412008960438aa53c
Call-ID: afae4729e855412ad64571941c836659@172.20.0.33
CSeq: 18243642 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bK7b58c88f8972e1d3256db20ab75d059c
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339409533 1339409533 IN IP4 172.20.0.33
s=abs
t=0 0
m=audio 32696 RTP/AVP 8 18 97
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
[0]->172.20.0.33:5060(372)
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
[0]->172.20.0.33:5060(453)
Content-Length: 0
[0]<<172.20.0.33:5060(374)
CSeq: 18243642 ACK
Content-Length: 0
Min-SE: 150
To: <565030>
From: "965827939" <0965827939>;tag=16f9e40baa3d12ce423a167789f54a8f
Call-ID: b114d7c8f6b5b7be0639b39d6a588d3f@172.20.0.33
CSeq: 460480818 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bKe5aa205d9ebcf4431340cb61150ec78f
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339409566 1339409566 IN IP4 172.20.0.33
s=abs
t=0 0
m=audio 32708 RTP/AVP 8 18 97
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
Content-Length: 0
CSeq: 460480818 ACK
Content-Length: 0
Min-SE: 150
To: <565030>
From: "968185096" <0968185096>;tag=016a65b13841ffdf0f5fffc449697912
Call-ID: 7b23e055ac918628d508a87ff1b74b38@172.20.0.33
CSeq: 1318880395 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bKed26768f23d0d4ca5672adfdb2ae0733
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339409789 1339409789 IN IP4 172.20.0.33
s=abs
t=0 0
m=audio 32700 RTP/AVP 8 18 97
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
Content-Length: 0
CSeq: 1318880395 ACK
Content-Length: 0
Min-SE: 150
To: <565030>
From: "965827939" <0965827939>;tag=8bd785af0772cf8887074eceadd31323
Call-ID: f59cf66427ab07e544a32d38a3164702@172.20.0.33
CSeq: 1885626745 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bK71772f4917bc4b84096498ba28043396
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339409867 1339409867 IN IP4 172.20.0.33
s=abs
t=0 0
m=audio 32524 RTP/AVP 8 18 97
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
Content-Length: 0
CSeq: 1885626745 ACK
Content-Length: 0
Min-SE: 150
To: <565030>
From: "968185096" <0968185096>;tag=cf41ff5e11bf8624d4fb2e739e6fc75f
Call-ID: 61538dfa681e8fed8cc8300bf7b59312@172.20.0.33
CSeq: 32125161 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bK0e971216eb0021d122f8a46e63b31011
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339410113 1339410113 IN IP4 172.20.0.33
s=abs
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
Content-Length: 0
CSeq: 32125161 ACK
Content-Length: 0
Min-SE: 150
To: <565030>
From: "965827939" <0965827939>;tag=a8d2ec813dae0c19012850952d2e8cb1
Call-ID: e5c7ebd48261b30d5ba3c33a648da0c1@172.20.0.33
CSeq: 842774664 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bKef02d09815dbfd788e5d95b00e220e26
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339410191 1339410191 IN IP4 172.20.0.33
s=abs
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
Content-Length: 0
CSeq: 842774664 ACK
Content-Length: 0
Min-SE: 150
To: <565030>
From: "968522502" <0968522502>;tag=2a9c8c5adff3b849e98a04c70c96787a
Call-ID: e773c73a80fe695cd3156d688d857561@172.20.0.33
CSeq: 770335440 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bK7318278f4f2574847a665bdf96d85bfd
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339410211 1339410211 IN IP4 172.20.0.33
s=abs
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
Content-Length: 0
CSeq: 770335440 ACK
Content-Length: 0
Min-SE: 150
To: <565030>
From: "965827939" <0965827939>;tag=2b346ea50aeedb276b14b94f996e5c01
Call-ID: 135e5bb04238865f40c965a22e6f2f8b@172.20.0.33
CSeq: 1899641275 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bK66ca498170293f03852b1fc52ba54644
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339410520 1339410520 IN IP4 172.20.0.33
s=abs
t=0 0
m=audio 32592 RTP/AVP 8 18 97
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
Content-Length: 0
CSeq: 1899641275 ACK
Content-Length: 0
Min-SE: 150
To: <565030>
From: "968522502" <0968522502>;tag=9da0251dc4dc21c72d8cb159cdfc54ee
Call-ID: bff778c7ca795ccb2ee4caca071532a4@172.20.0.33
CSeq: 1873632723 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bKf83594a4bd9247aad089cd7f7f05adfa
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339410551 1339410551 IN IP4 172.20.0.33
s=abs
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
Content-Length: 0
CSeq: 1873632723 ACK
Content-Length: 0
[0]Off Hook
[0:0]AUD ALLOC CALL (port=16428)
[0:0]RTP Rx Up
Via: SIP/2.0/UDP 172.19.5.65:5060;branch=z9hG4bK-d86e6327
To: <0913346160>
Call-ID: 4fb8e4f4-9c1e657b@172.19.5.65
CSeq: 101 INVITE
Max-Forwards: 70
Contact: <565030>
Expires: 240
Content-Length: 252
v=0
o=- 34599776 34599776 IN IP4 172.19.5.65
s=-
t=0 0
m=audio 16428 RTP/AVP 0 100 97
a=fmtp:100 192-193
a=fmtp:97 0-15
a=ptime:30
a=sendrecv
SIP/2.0 100 Trying
To: <0913346160>
CSeq: 101 INVITE
Content-Length: 0
To: <0913346160>;tag=00a01e1d32a5f1fcf129d5f5b7cea1d1
CSeq: 101 INVITE
Content-Length: 0
CSeq: 101 ACK
Max-Forwards: 70
Contact: <565030>
Content-Length: 0
[0:0]AUD Rel Call
[0]On Hook
Min-SE: 150
To: <565030>
From: "968522502" <0968522502>;tag=e17fc0a951de96d7706a71d6d73a68ea
Call-ID: fe70ca1730273e003ddfbbe116c62e17@172.20.0.33
CSeq: 1133496920 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bK864122c6594367b12f85f9e67dd67017
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339410617 1339410617 IN IP4 172.20.0.33
s=abs
t=0 0
m=audio 32656 RTP/AVP 8 18 97
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
Content-Length: 0
CSeq: 1133496920 ACK
Content-Length: 0
[0]Off Hook
Min-SE: 150
To: <565030>
From: "968180220" <0968180220>;tag=8bfdb592268d97427418b25ac858fe88
Call-ID: 1fc181788d0942af6f2d09629256ec32@172.20.0.33
CSeq: 359360807 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bK79e3349d99022f357ff39a98101699c4
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339410631 1339410631 IN IP4 172.20.0.33
s=abs
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
Content-Length: 0
CSeq: 359360807 ACK
Content-Length: 0
[0:0]AUD ALLOC CALL (port=16430)
[0:0]RTP Rx Up
Via: SIP/2.0/UDP 172.19.5.65:5060;branch=z9hG4bK-7e19c167
To: <0968180220>
Call-ID: d2e64feb-c24fa9f7@172.19.5.65
CSeq: 101 INVITE
Max-Forwards: 70
Contact: <565030>
Expires: 240
Content-Length: 252
v=0
o=- 34602599 34602599 IN IP4 172.19.5.65
s=-
t=0 0
m=audio 16430 RTP/AVP 0 100 97
a=fmtp:100 192-193
a=fmtp:97 0-15
a=ptime:30
a=sendrecv
SIP/2.0 100 Trying
To: <0968180220>
CSeq: 101 INVITE
Content-Length: 0
To: <0968180220>;tag=1df04cda6529970dfcd2551bf6ccade2
CSeq: 101 INVITE
Content-Length: 0
ACK sip:0968180220@172.20.0.33 SIP/2.0
CSeq: 101 ACK
Max-Forwards: 70
Contact: <565030>
Content-Length: 0
[0:0]AUD Rel Call
[0]On Hook
Sess Terminated
Sess Terminated
CC:Clean Up
[0]Off Hook
[0:0]AUD ALLOC CALL (port=16432)
[0:0]RTP Rx Up
Via: SIP/2.0/UDP 172.19.5.65:5060;branch=z9hG4bK-1a6bf0f7
To: <0913346160>
Call-ID: dde8c618-a069a11b@172.19.5.65
CSeq: 101 INVITE
Max-Forwards: 70
Contact: <565030>
Expires: 240
Content-Length: 252
v=0
o=- 34618836 34618836 IN IP4 172.19.5.65
s=-
t=0 0
m=audio 16432 RTP/AVP 0 100 97
a=fmtp:100 192-193
a=fmtp:97 0-15
a=ptime:30
a=sendrecv
SIP/2.0 100 Trying
To: <0913346160>
CSeq: 101 INVITE
Content-Length: 0
To: <0913346160>;tag=4cd6f5e49b8ecd419c20011f2e715e2c
CSeq: 101 INVITE
Content-Length: 0
CSeq: 101 ACK
Max-Forwards: 70
Contact: <565030>
Content-Length: 0
[0:0]AUD Rel Call
[0]On Hook
[0]Off Hook
[0:0]AUD ALLOC CALL (port=16434)
[0:0]RTP Rx Up
[0]->172.20.0.33:5060(829)
Via: SIP/2.0/UDP 172.19.5.65:5060;branch=z9hG4bK-ed7a247
To: <0968180220>
Call-ID: 2f29e6e4-77d821db@172.19.5.65
CSeq: 101 INVITE
Max-Forwards: 70
Contact: <565030>
Expires: 240
Content-Length: 252
v=0
o=- 34621680 34621680 IN IP4 172.19.5.65
s=-
t=0 0
m=audio 16434 RTP/AVP 0 100 97
a=fmtp:100 192-193
a=fmtp:97 0-15
a=ptime:30
a=sendrecv
[0]<<172.20.0.33:5060(244)
SIP/2.0 100 Trying
To: <0968180220>
CSeq: 101 INVITE
Content-Length: 0
[0]<<172.20.0.33:5060(424)
To: <0968180220>;tag=a63c90e6d83be4bf67110ba062473def
CSeq: 101 INVITE
Content-Length: 0
CSeq: 101 ACK
Max-Forwards: 70
Contact: <565030>
Content-Length: 0
[0:0]AUD Rel Call
[0]On Hook
Sess Terminated
Sess Terminated
CC:Clean Up
Min-SE: 150
To: <565030>
From: "968522502" <0968522502>;tag=20cc2bf33a102c5ba2116c00b6771f30
Call-ID: 24a9c469c2ee2cd3c3a022939d7ccd29@172.20.0.33
CSeq: 17913214 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bKa148ced02b5d5fece3e4caf69d11d85e
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339410890 1339410890 IN IP4 172.20.0.33
s=abs
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
Content-Length: 0
CSeq: 17913214 ACK
Content-Length: 0
Min-SE: 150
To: <565030>
From: "968180220" <0968180220>;tag=3ff3e0178c92722ae934ae437e882e8e
Call-ID: 1a6a6c8446ddd77423ef644c6ffd5430@172.20.0.33
CSeq: 1733192900 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bKcb73cb6aa7dc666d9508b02b36062eec
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339410939 1339410939 IN IP4 172.20.0.33
s=abs
t=0 0
m=audio 32744 RTP/AVP 8 18 97
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
Content-Length: 0
CSeq: 1733192900 ACK
Content-Length: 0
[0]Off Hook
[0]->172.20.0.33:5060(468)
REGISTER sip:172.20.0.33 SIP/2.0
Via: SIP/2.0/UDP 172.19.5.65:5060;branch=z9hG4bK-17699cba
To: <565030>
Call-ID: 58973500-c24f81b6@172.19.5.65
CSeq: 44309 REGISTER
Max-Forwards: 70
Contact: <565030>;expires=3600
Content-Length: 0
[0]<<172.20.0.33:5060(332)
SIP/2.0 200 OK
To: <565030>;tag=bc25e406d3009f4df0c536afd1ddedee
Content-Length: 0
[0]RegOK. NextReg in 3570 (1)
[0:0]AUD ALLOC CALL (port=16436)
[0:0]RTP Rx Up
Via: SIP/2.0/UDP 172.19.5.65:5060;branch=z9hG4bK-d004df4a
To: <0913346160>
Call-ID: 7885311b-aa03402e@172.19.5.65
CSeq: 101 INVITE
Max-Forwards: 70
Contact: <565030>
Expires: 240
Content-Length: 252
v=0
o=- 34636814 34636814 IN IP4 172.19.5.65
s=-
t=0 0
m=audio 16436 RTP/AVP 0 100 97
a=fmtp:100 192-193
a=fmtp:97 0-15
a=ptime:30
a=sendrecv
SIP/2.0 100 Trying
To: <0913346160>
CSeq: 101 INVITE
Content-Length: 0
To: <0913346160>;tag=900ac35f3897800b709a195dd3264c7a
CSeq: 101 INVITE
Content-Length: 0
CSeq: 101 ACK
Max-Forwards: 70
Contact: <565030>
Content-Length: 0
[0:0]AUD Rel Call
[0]<<172.20.0.33:5060(954)
Min-SE: 150
To: <565030>
From: "968522502" <0968522502>;tag=8334362d67b3da25d9406b28d1ea30dc
Call-ID: 5813cb4e9ef655630d4eafac8afcfd77@172.20.0.33
CSeq: 9136748 INVITE
Via: SIP/2.0/UDP 172.20.0.33;branch=z9hG4bK135cb909a11b998a8855d40a7cbda5ef
Max-Forwards: 70
Content-Length: 286
v=0
o=OXE 1339410978 1339410978 IN IP4 172.20.0.33
s=abs
t=0 0
m=audio 32572 RTP/AVP 8 18 97
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
[0]->172.20.0.33:5060(371)
SIP/2.0 100 Trying
To: <565030>
Content-Length: 0
[0]->172.20.0.33:5060(397)
Content-Length: 0
[0]<<172.20.0.33:5060(373)
CSeq: 9136748 ACK
Content-Length: 0
[0]On Hook
[0]Off Hook
[0:0]AUD ALLOC CALL (port=16438)
[0:0]RTP Rx Up
Via: SIP/2.0/UDP 172.19.5.65:5060;branch=z9hG4bK-886c192a
To: <0968180220>
Call-ID: 6e585af8-9cc46322@172.19.5.65
CSeq: 101 INVITE
Max-Forwards: 70
Contact: <565030>
Expires: 240
Content-Length: 252
v=0
o=- 34639675 34639675 IN IP4 172.19.5.65
s=-
t=0 0
m=audio 16438 RTP/AVP 0 100 97
a=fmtp:100 192-193
a=fmtp:97 0-15
a=ptime:30
a=sendrecv
SIP/2.0 100 Trying
To: <0968180220>
CSeq: 101 INVITE
Content-Length: 0
To: <0968180220>;tag=2199aaa57cae56662bdb7e05c1adcdd2
CSeq: 101 INVITE
Content-Length: 0
CSeq: 101 ACK
Max-Forwards: 70
Contact: <565030>
Content-Length: 0
[0:0]AUD Rel Call
[0]On Hook
Sess Terminated
Sess Terminated
CC:Clean Up
