Provision SPA3102: Port Forwarding Parameters
X2connect
We have been using a provisioning server to configure our population of SPA3102 ATAs. We have set up an XML file on the server based on examples provided by Cisco. This works perfectly for everything we have needed to set up so far. However we would now like to add some Port Forwarding rules on the Application page under the Router tab. The example XML script does not have any entry under the Application heading and we have tried many iterations of trying to derive the appropriate format for the settings based on all the other settings but without success. Does anyone know the correct format for adding Port Forwarding settings to our XML script? Or please can someone tell us if it is not possibole to automatically provision these settings so we can stop trying and find another way around the issue?
I would be very grateful for any help to point us in the right direction. Thanks.
nseto
Level 6
Level 6
Hi, the xml config file is for the voice side and very limited with regards to the router side.  Port forwarding wouldn't be on that list.  Thank you.
