10-24-2017 01:28 PM - edited 03-21-2019 10:41 AM
Anyone ever experience a ring voltage drop on the SPA122? First ring measured has 72 volts and there after drops to low 60's. The firmware is 1.3.5 (004p)
10-29-2017 10:23 AM
1. Ring voltage is configurable (40–90 Vpk). Which value you have configured ?
2. Ring voltage is AC superimposed on DC (about 48V). So did you measured true AC voltage (with DC component filtered out) or the values you mentioned are just sum of both voltages (e.g. we don't know if it's the AC component that has changed between rings) ? Note that some voltmeters doesn't measure properly AC voltage with non-zero DC component.
OK. Did you are experiencing an issue, or you are just curious ?
10-31-2017 06:45 AM - edited 10-31-2017 06:52 AM
Just curious on my end. Was running tests and saw this pop up. Would a ring booster help resolve this issue?
Editing to answer your questions:
Set to default of 85.
Would need to double check.
10-31-2017 12:47 PM
Sorry, only Oracle can respond it. You described no issue yet - yes, you mentioned different voltage for first and second ring, but it's rather interesting observation than issue.
If your phone recognize first ring, but no second one, then ring booster may help.
