RtpTx:Conn to ip:port Failed
tiendalinux
Hi , i have a voip network consisting only on linksys spa9xx sometimes there is no audio (RTP) while sip signalling is working.
I have disabled every form of QoS on both switches and phones trying to figure out what triggers the problem, but i haven't found a solution yet.
I have activated sip debug on the phone and when that happens the systems shows the following:
Look the line:
"Dec 14 11:54:17 172.19.4.200 RtpTx:Conn to c0a8016e:15860 Failed"
As soon as the call is triggered it shows the following:
Dec 14 11:54:17 172.19.4.200 PHN_setAudioPath(1)
Dec 14 11:54:17 172.19.4.200 [0:5060]->192.168.1.110:5060{680)
Dec 14 11:54:17 172.19.4.200 SIP/2.0 200 OK  To: <sip:291@172.19.4.200:5060>;tag=7972bd8c49c0f5cei0  From: "Nestor Diaz" <sip
:800211@192.168.1.110>;tag=as54986cdc  Call-ID: 5eedc3586e4565d15e5808ab26d16aa1@192.168.1.110  CSeq: 102 INVITE  Via: SIP/2.
0/UDP 192.168.1.110:5060;branch=z9hG4bK54371fb6  Contact: <sip:291@172.19.4.200:5060>  Server: Linksys/SPA922-5.2.8  Content-
Length: 204  Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER  Supported: replaces  Content-Type: application/sd
p    v=0  o=- 17259 17259 IN IP4 172.19.4.200  s=-  c=IN IP4 172.19.4.200  t=0 0  m=audio 10042 RTP/AVP 0 101  a=rtpmap:0 PCM
U/8000  a=rtpmap:101 telephone-event/8000  a=fmtp:101 0-15  a=ptime:20  a=sendrecv
Dec 14 11:54:17 172.19.4.200 [0:5060]<<192.168.1.110:5060
Dec 14 11:54:17 172.19.4.200 ACK sip:291@172.19.4.200:5060 SIP/2.0  Via: SIP/2.0/UDP 192.168.1.110:5060;branch=z9hG4bK79bf8c0
9;rport  From: "Nestor Diaz" <sip:800211@192.168.1.110>;tag=as54986cdc  To: <sip:291@172.19.4.200:5060>;tag=7972bd8c49c0f5cei
0  Contact: <sip:800211@192.168.1.110>  Call-ID: 5eedc3586e4565d15e5808ab26d16aa1@192.168.1.110  CSeq: 102 ACK  User-Agent: A
sterisk PBX  Max-Forwards: 70  Content-Length: 0
Dec 14 11:54:17 172.19.4.200 CC:Connected
Dec 14 11:54:17 172.19.4.200 [0:0]ENC INIT 0
Dec 14 11:54:17 172.19.4.200 [0:0]RTP Tx Up (pt=0->c0a8016e:15860)
Dec 14 11:54:17 172.19.4.200 [0:0]RTCP Tx Up
Dec 14 11:54:24 172.19.4.200 PHN_setAudioPath(0)
Your SPA with IP address 172.19.4.200 tries to connect a device with IP address  192.168.1.110.
Is there IP connectivity between these networks?
Regards.
Sure, the phone have connectivity to such ip address, i suspect is a problem with the switches, as with the linksys srw224p the system was working fine, but when we introduced some cisco switches sf300 the problem began to appear, i am not sure how can i fix it as i have tweak almost every switch option, another user had a similar issue, look at this thread: https://supportforums.cisco.com/thread/2057937 we also have some netgear switches on the network.
The phones belongs to 172.19.1.0/24 network and the data network to the 192.168.1.0/24 network.
I'm having the same issue. Also I've introduced a cisco switche sf300 and the problem started.
My PBX vendor says that the issue is with Linksys SPA9xx phones after monitoring and analyzing the network traffic. I think he is right because when testing with softphones there is no such problem.
Did you find the solution?
