08-29-2018 04:38 AM - edited 08-29-2018 04:52 AM
we would like to use a SP112. We registered this on a 3CX and connected a Brother fax.
Firmware version is 1.41SP1.
Once you have 1 fax sent, the SP112 hangs completely. It is no longer possible to access the web interface and sending further faxes is not possible.
After some time, the SP112 is no longer registered in the 3CX.
What can we do?
Here are the last logs the SP112 writes:
Aug 29 11:50:36 SPA112 syslog.notice syslog-ng[138]: syslog-ng version 1.6.12 starting |
Aug 29 11:50:36 SPA112 kern.notice [ 0.000000] Linux version 2.6.26.5 (aoliu@Payton) (gcc version 4.1.2) #1 PREEMPT Wed Aug 2 14:04:45 CST 2017 |
Aug 29 11:50:36 SPA112 kern.warning [ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177 |
Aug 29 11:50:36 SPA112 kern.warning [ 0.000000] Machine: NXP PNX8181 |
Aug 29 11:50:36 SPA112 kern.warning [ 0.000000] Memory policy: ECC disabled, Data cache writeback |
Aug 29 11:50:36 SPA112 kern.debug [ 0.000000] On node 0 totalpages: 7936 |
Aug 29 11:50:36 SPA112 kern.debug [ 0.000000] DMA zone: 62 pages used for memmap |
Aug 29 11:50:36 SPA112 kern.debug [ 0.000000] DMA zone: 0 pages reserved |
Aug 29 11:50:36 SPA112 kern.debug [ 0.000000] DMA zone: 7874 pages, LIFO batch:0 |
Aug 29 11:50:36 SPA112 kern.debug [ 0.000000] Normal zone: 0 pages used for memmap |
Aug 29 11:50:36 SPA112 kern.debug [ 0.000000] Movable zone: 0 pages used for memmap |
Aug 29 11:50:36 SPA112 kern.warning [ 0.000000] CPU0: D VIVT write-back cache |
Aug 29 11:50:36 SPA112 kern.warning [ 0.000000] CPU0: I cache: 32768 bytes, associativity 4, 32 byte lines, 256 sets |
Aug 29 11:50:36 SPA112 kern.warning [ 0.000000] CPU0: D cache: 32768 bytes, associativity 4, 32 byte lines, 256 sets |
Aug 29 11:50:36 SPA112 kern.warning [17179569.184000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 7874 |
Aug 29 11:50:36 SPA112 kern.notice [17179569.184000] Kernel command line: console=ttyS1,115200n8 rootfstype=squashfs noalign half_image=0 verify=y Hw_Model=SPA112 Router_Mode=0 |
Aug 29 11:50:36 SPA112 kern.info [17179569.184000] PNX8181: Configured 66 Interrupts |
Aug 29 11:50:36 SPA112 kern.warning [17179569.184000] PID hash table entries: 128 (order: 7, 512 bytes) |
Aug 29 11:50:36 SPA112 kern.warning [17179569.184000] Console: colour dummy device 80x30 |
Aug 29 11:50:36 SPA112 kern.info [17179569.184000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes) |
Aug 29 11:50:36 SPA112 kern.info [17179569.184000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes) |
Aug 29 11:50:36 SPA112 kern.info [17179569.188000] Memory: 31MB = 31MB total |
Aug 29 11:50:36 SPA112 kern.notice [17179569.188000] Memory: 28296KB available (2804K code, 197K data, 120K init) |
Aug 29 11:50:36 SPA112 kern.debug [17179569.188000] Calibrating delay loop... 116.99 BogoMIPS (lpj=233984) |
Aug 29 11:50:36 SPA112 kern.warning [17179569.268000] Mount-cache hash table entries: 512 |
Aug 29 11:50:36 SPA112 kern.info [17179569.268000] CPU: Testing write buffer coherency: ok |
Aug 29 11:50:36 SPA112 kern.info [17179569.272000] net_namespace: 484 bytes |
Aug 29 11:50:36 SPA112 kern.info [17179569.272000] NET: Registered protocol family 16 |
Aug 29 11:50:36 SPA112 kern.info [17179569.272000] Board: found phy at 0x03, id 0x001cc815 |
Aug 29 11:50:36 SPA112 kern.info [17179569.272000] Board: Vega_PNX8181_BaseStation low-cost version detected. |
Aug 29 11:50:36 SPA112 kern.info [17179569.272000] clock [intc] enabled |
Aug 29 11:50:36 SPA112 kern.info [17179569.272000] clock [sctu] enabled |
Aug 29 11:50:36 SPA112 kern.info [17179569.272000] clock [uart1] enabled |
Aug 29 11:50:36 SPA112 kern.info [17179569.272000] clock [uart2] enabled |
Aug 29 11:50:36 SPA112 kern.info [17179569.272000] clock [sdi] enabled |
Aug 29 11:50:36 SPA112 kern.info [17179569.272000] clock [ebi1] enabled |
Aug 29 11:50:36 SPA112 kern.info [17179569.272000] clock [ebi2] enabled |
Aug 29 11:50:36 SPA112 kern.info [17179569.272000] clock [gpio] enabled |
Aug 29 11:50:36 SPA112 kern.notice [17179569.272000] gpio_init: Registered PNX818 GPIO device |
Aug 29 11:50:36 SPA112 kern.warning [17179569.272000] Board HW MODEL : 0x3 |
Aug 29 11:50:36 SPA112 kern.info [17179569.272000] clock [extint] enabled |
Aug 29 11:50:36 SPA112 kern.info [17179569.272000] External Interrupt Controller registered |
Aug 29 11:50:36 SPA112 kern.info [17179569.288000] NET: Registered protocol family 2 |
Aug 29 11:50:36 SPA112 kern.info [17179569.324000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes) |
Aug 29 11:50:36 SPA112 kern.info [17179569.324000] TCP established hash table entries: 1024 (order: 1, 8192 bytes) |
Aug 29 11:50:36 SPA112 kern.info [17179569.324000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes) |
Aug 29 11:50:36 SPA112 kern.info [17179569.324000] TCP: Hash tables configured (established 1024 bind 1024) |
Aug 29 11:50:36 SPA112 kern.info [17179569.324000] TCP reno registered |
Aug 29 11:50:36 SPA112 kern.info [17179569.336000] NET: Registered protocol family 1 |
Aug 29 11:50:36 SPA112 kern.info [17179569.336000] clock [dmau] enabled |
Aug 29 11:50:36 SPA112 kern.info [17179569.336000] probe succeded |
Aug 29 11:50:36 SPA112 kern.info [17179569.336000] clock [iic] enabled |
Aug 29 11:50:36 SPA112 kern.info [17179569.340000] squashfs: version 3.4 (2008/08/26) Phillip Lougher |
Aug 29 11:50:36 SPA112 kern.warning [17179569.340000] squashfs: LZMA suppport for slax.org by jro |
Aug 29 11:50:36 SPA112 kern.info [17179569.340000] JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc. |
Aug 29 11:50:36 SPA112 kern.info [17179569.344000] msgmni has been set to 55 |
Aug 29 11:50:36 SPA112 kern.info [17179569.344000] io scheduler noop registered (default) |
Aug 29 11:50:36 SPA112 kern.info [17179569.352000] HDLC line discipline: version $Revision: 1.1.1.1 $, maxframe=4096 |
Aug 29 11:50:36 SPA112 kern.info [17179569.352000] N_HDLC line discipline registered. |
Aug 29 11:50:36 SPA112 kern.info [17179569.352000] Non-volatile memory driver v1.2 |
Aug 29 11:50:36 SPA112 kern.info [17179569.352000] Serial: 8250/16550 driver $Revision: 1.1.1.1 $ 2 ports, IRQ sharing disabled |
Aug 29 11:50:36 SPA112 kern.info [17179569.352000] serial8250.0: ttyS0 at MMIO 0xc2004000 (irq = 24) is a 16550A |
Aug 29 11:50:36 SPA112 kern.info [17179569.352000] serial8250.0: ttyS1 at MMIO 0xc2005000 (irq = 23) is a TI16750 |
Aug 29 11:50:36 SPA112 kern.info [17179569.352000] console [ttyS1] enabled |
Aug 29 11:50:36 SPA112 kern.info [17179569.356000] DCC: JTAG1 Serial emulation driver driver $Revision: 1.1.1.1 $ |
Aug 29 11:50:36 SPA112 kern.info [17179569.360000] ttyJ0 at MMIO 0x12345678 (irq = 0) is a DCC |
Aug 29 11:50:36 SPA112 kern.info [17179569.364000] brd: module loaded |
Aug 29 11:50:36 SPA112 kern.info [17179569.368000] PPP generic driver version 2.4.2 |
Aug 29 11:50:36 SPA112 kern.info [17179569.376000] PPP MPPE Compression module registered |
Aug 29 11:50:36 SPA112 kern.info [17179569.380000] NET: Registered protocol family 24 |
Aug 29 11:50:36 SPA112 kern.info [17179569.384000] PPPoL2TP kernel driver, V1.0 |
Aug 29 11:50:36 SPA112 kern.warning [17179569.388000] [ip3912] : Bridge Mode... |
Aug 29 11:50:36 SPA112 kern.info [17179569.392000] clock [etn1] enabled |
Aug 29 11:50:36 SPA112 kern.info [17179569.400000] ip3912_mii_bus: probed |
Aug 29 11:50:36 SPA112 kern.info [17179569.404000] eth0: IP3912 at 0xc1600000 using 0:03 phy |
Aug 29 11:50:36 SPA112 kern.info [17179569.412000] NFTL driver: nftlcore.c $Revision: 1.1.1.1 $, nftlmount.c $Revision: 1.1.1.1 $ |
Aug 29 11:50:36 SPA112 kern.notice [17179569.416000] physmap platform flash device: 02000000 at 80000000 |
Aug 29 11:50:36 SPA112 kern.debug [17179569.420000] CFI: Found no physmap-flash.0 device at location zero |
Aug 29 11:50:36 SPA112 kern.err [17179569.420000] physmap-flash physmap-flash.0: map_probe failed |
Aug 29 11:50:36 SPA112 kern.info [17179569.424000] NAND device: Manufacturer ID: 0xc2, Chip ID: 0xf1 (Unknown NAND 128MiB 3,3V 8-bit) |
Aug 29 11:50:36 SPA112 kern.debug [17179569.428000] Bad block table found at page 65472, version 0x01 |
Aug 29 11:50:36 SPA112 kern.debug [17179569.432000] Bad block table found at page 65408, version 0x01 |
Aug 29 11:50:36 SPA112 kern.debug [17179569.432000] nand_read_bbt: Bad block at 0x01040000 |
Aug 29 11:50:36 SPA112 kern.debug [17179569.432000] nand_read_bbt: Bad block at 0x06260000 |
Aug 29 11:50:36 SPA112 kern.debug [17179569.432000] nand_read_bbt: Bad block at 0x06380000 |
Aug 29 11:50:36 SPA112 kern.debug [17179569.432000] nand_read_bbt: Bad block at 0x078e0000 |
Aug 29 11:50:36 SPA112 kern.warning [17179569.432000] Using Full Image\'s RootFS |
Aug 29 11:50:36 SPA112 kern.warning [17179569.436000] Using static partition definition |
Aug 29 11:50:36 SPA112 kern.warning [17179569.440000] !!! do adler32 checksum !!! |
Aug 29 11:50:36 SPA112 kern.warning [17179571.000000] File system image checksum OK |
Aug 29 11:50:36 SPA112 kern.notice [17179571.004000] Creating 13 MTD partitions on \"gen_nand\": |
Aug 29 11:50:36 SPA112 kern.notice [17179571.008000] 0x00000000-0x00300000 : \"u-boot\" |
Aug 29 11:50:36 SPA112 kern.notice [17179571.012000] 0x00300000-0x00600000 : \"u-bootenv\" |
Aug 29 11:50:36 SPA112 kern.notice [17179571.016000] 0x00600000-0x01900000 : \"ROMIMAGE\" |
Aug 29 11:50:36 SPA112 kern.notice [17179571.020000] 0x01900000-0x02100000 : \"HALFIMAGE\" |
Aug 29 11:50:36 SPA112 kern.notice [17179571.024000] 0x00780000-0x01900000 : \"LINUX_ROOTFS\" |
Aug 29 11:50:36 SPA112 kern.notice [17179571.028000] 0x02100000-0x02500000 : \"HS_FW\" |
Aug 29 11:50:36 SPA112 kern.notice [17179571.032000] 0x02500000-0x02900000 : \"FPAR\" |
Aug 29 11:50:36 SPA112 kern.notice [17179571.040000] 0x02900000-0x02c00000 : \"CISCO\" |
Aug 29 11:50:36 SPA112 kern.notice [17179571.044000] 0x02c00000-0x02f00000 : \"EEPROM\" |
Aug 29 11:50:36 SPA112 kern.notice [17179571.048000] 0x02f00000-0x03300000 : \"NVRAM\" |
Aug 29 11:50:36 SPA112 kern.notice [17179571.056000] 0x03300000-0x03600000 : \"CA_DATA\" |
Aug 29 11:50:36 SPA112 kern.notice [17179571.060000] 0x03600000-0x05200000 : \"RESERVE1\" |
Aug 29 11:50:36 SPA112 kern.notice [17179571.064000] 0x05200000-0x08000000 : \"RESERVE2\" |
Aug 29 11:50:36 SPA112 kern.info [17179571.068000] clock [spi1] enabled |
Aug 29 11:50:36 SPA112 kern.info [17179571.072000] spi-pnx8181 spi-pnx8181: probe succeded |
Aug 29 11:50:36 SPA112 kern.info [17179571.076000] i2c /dev entries driver |
Aug 29 11:50:36 SPA112 kern.err [17179571.080000] ksz8873 0-005f: failed with status -1 |
Aug 29 11:50:36 SPA112 kern.warning [17179571.084000] ksz8873: probe of 0-005f failed with error -1 |
Aug 29 11:50:36 SPA112 kern.warning [17179571.088000] PNX8181 watchdog timer: timer margin 16 sec |
Aug 29 11:50:36 SPA112 kern.info [17179571.092000] Registered led device: led1 |
Aug 29 11:50:36 SPA112 kern.info [17179571.096000] Registered led device: led2 |
Aug 29 11:50:36 SPA112 kern.debug [17179571.100000] cordless: SCRAM mapped to 0xd0000000 |
Aug 29 11:50:36 SPA112 kern.info [17179571.100000] cordless: character device initialized (major=254) |
Aug 29 11:50:36 SPA112 kern.info [17179571.104000] coma-debug: coma debug support enabled |
Aug 29 11:50:36 SPA112 kern.warning [17179571.108000] GACT probability on |
Aug 29 11:50:36 SPA112 kern.warning [17179571.112000] Mirror/redirect action on |
Aug 29 11:50:36 SPA112 kern.warning [17179571.116000] u32 classifier |
Aug 29 11:50:36 SPA112 kern.warning [17179571.120000] Performance counters on |
Aug 29 11:50:36 SPA112 kern.warning [17179571.124000] input device check on |
Aug 29 11:50:36 SPA112 kern.warning [17179571.128000] Actions configured |
Aug 29 11:50:36 SPA112 kern.warning [17179571.132000] Netfilter messages via NETLINK v0.30. |
Aug 29 11:50:36 SPA112 kern.warning [17179571.136000] nf_conntrack version 0.5.0 (1024 buckets, 4096 max) |
Aug 29 11:50:36 SPA112 kern.info [17179571.144000] ip_tables: (C) 2000-2006 Netfilter Core Team |
Aug 29 11:50:36 SPA112 kern.warning [17179571.148000] ipt_time loading |
Aug 29 11:50:36 SPA112 kern.info [17179571.152000] TCP cubic registered |
Aug 29 11:50:36 SPA112 kern.info [17179571.156000] NET: Registered protocol family 17 |
Aug 29 11:50:36 SPA112 kern.notice [17179571.160000] Bridge firewalling registered |
Aug 29 11:50:36 SPA112 kern.info [17179571.164000] Ebtables v2.0 registered |
Aug 29 11:50:36 SPA112 kern.info [17179571.172000] RPC: Registered udp transport module. |
Aug 29 11:50:36 SPA112 kern.info [17179571.176000] RPC: Registered tcp transport module. |
Aug 29 11:50:36 SPA112 kern.info [17179571.180000] 802.1Q VLAN Support v1.8 Ben Greear<greearb@candelatech.com> |
Aug 29 11:50:36 SPA112 kern.info [17179571.184000] All bugs added by David S. Miller<davem@redhat.com> |
Aug 29 11:50:36 SPA112 kern.info [17179571.188000] LINUX_ROOTFS is 4 |
Aug 29 11:50:36 SPA112 kern.warning [17179571.200000] VFS: Mounted root (squashfs filesystem) readonly. |
Aug 29 11:50:36 SPA112 kern.info [17179571.204000] Freeing init memory: 120K |
Aug 29 11:50:36 SPA112 kern.info [17179572.068000] eth0: Link down |
Aug 29 11:50:36 SPA112 kern.info [17179573.068000] ip3912: eth0 up, speed is 100 Mbps, Full Duplex. |
Aug 29 11:50:36 SPA112 kern.info [17179575.204000] coma-config: netlink interface registered |
Aug 29 11:50:36 SPA112 kern.info [17179575.316000] coma-cpi: netlink interface registered |
Aug 29 11:50:36 SPA112 kern.info [17179575.364000] coma-ss7: netlink interface registered |
Aug 29 11:50:36 SPA112 kern.info [17179575.420000] coma-voice: character device initialized (major=253) |
Aug 29 11:50:36 SPA112 kern.info [17179575.464000] coma-userch: netlink interface registered |
Aug 29 11:50:36 SPA112 kern.info [17179575.568000] coma-dsr: netlink interface registered |
Aug 29 11:50:36 SPA112 kern.warning [17179575.600000] ***** LED_DRV init ***** |
Aug 29 11:50:36 SPA112 kern.warning [17179575.604000] ***** LED_DRV end ***** |
Aug 29 11:50:36 SPA112 kern.warning [17179575.632000] *** sys event driver initialized *** |
Aug 29 11:50:36 SPA112 kern.err [17179580.096000] br0: Dropping NETIF_F_UFO since no NETIF_F_HW_CSUM feature. |
Aug 29 11:50:36 SPA112 kern.info [17179581.760000] device eth0 entered promiscuous mode |
Aug 29 11:50:36 SPA112 kern.info [17179581.760000] br0: port 1(eth0) entering learning state |
Aug 29 11:50:36 SPA112 kern.debug [17179581.764000] sysevt_comm_sendto: (52, rc)=> |
Aug 29 11:50:36 SPA112 kern.debug [17179581.780000] sysevt_comm_sendto: (52, rc)=> |
Aug 29 11:50:36 SPA112 kern.warning [17179581.840000] Empty flash at 0x00002b5c ends at 0x00003000 |
Aug 29 11:50:36 SPA112 kern.warning [17179581.856000] Empty flash at 0x00008830 ends at 0x00009000 |
Aug 29 11:50:36 SPA112 kern.notice [17179581.856000] jffs2_scan_inode_node(): CRC failed on node at 0x0000d7cc: Read 0xffffffff, calculated 0xa381b2b4 |
Aug 29 11:50:36 SPA112 kern.warning [17179581.872000] Empty flash at 0x0000d840 ends at 0x0000e000 |
Aug 29 11:50:36 SPA112 kern.warning [17179581.928000] Empty flash at 0x00041008 ends at 0x00041800 |
Aug 29 11:50:36 SPA112 kern.warning [17179581.948000] Empty flash at 0x0004380c ends at 0x00044000 |
Aug 29 11:50:36 SPA112 kern.warning [17179581.968000] Empty flash at 0x0004849c ends at 0x00048800 |
Aug 29 11:50:36 SPA112 kern.warning [17179581.984000] Empty flash at 0x0004b01c ends at 0x0004b800 |
Aug 29 11:50:36 SPA112 kern.warning [17179581.988000] Empty flash at 0x00056e68 ends at 0x00057000 |
Aug 29 11:50:36 SPA112 kern.warning [17179581.992000] Empty flash at 0x0005ec50 ends at 0x0005f000 |
Aug 29 11:50:36 SPA112 kern.notice [17179582.068000] JFFS2 notice: (113) check_node_data: wrong data CRC in data node at 0x0000fbec: read 0x21745e69, calculated 0x29734463. |
Aug 29 11:50:36 SPA112 kern.info [17179583.760000] br0: topology change detected, propagating |
Aug 29 11:50:36 SPA112 kern.info [17179583.760000] br0: port 1(eth0) entering forwarding state |
Aug 29 11:50:37 SPA112 daemon.info system[141]: httpd server started at port 80 |
Aug 29 11:50:37 SPA112 daemon.info system[149]: httpd server (ssl support) started at port 8080 |
Aug 29 11:50:38 SPA112 daemon.notice system[1]: Ethernet WAN br0 link up |
Aug 29 11:50:39 SPA112 daemon.info dnsmasq[155]: started, version 1.10 cachesize 150 |
Aug 29 11:50:39 SPA112 daemon.err dnsmasq[155]: failed to load names from /etc/hosts: No such file or directory |
Aug 29 11:50:39 SPA112 daemon.debug dnsmasq[155]: reading /tmp/dns_resolv.conf |
Aug 29 11:50:39 SPA112 daemon.info dnsmasq[155]: using nameserver 1.1.1.1 |
Aug 29 11:50:39 SPA112 daemon.err sendmail: SSL Helper exited (1) |
Aug 29 11:50:40 SPA112 daemon.err sendmail: SSL Helper exited (1) |
Aug 29 11:50:44 SPA112 daemon.err sendmail: SSL Helper exited (1) |
Aug 29 11:50:48 SPA112 daemon.err sendmail: SSL Helper exited (1) |
Aug 29 11:50:50 SPA112 daemon.err sendmail: SSL Helper exited (1) |
Aug 29 11:50:51 SPA112 daemon.err sendmail: SSL Helper exited (1) |
Aug 29 11:50:52 SPA112 daemon.err sendmail: SSL Helper exited (1) |
Aug 29 11:50:54 SPA112 kern.info [17179602.688000] cordless: loading synergy-2015-06-09 |
Aug 29 11:50:54 SPA112 kern.err [17179602.708000] Created coma thread for processing coma control message |
Aug 29 11:50:54 SPA112 kern.info [17179602.724000] cordless: init successful |
Aug 29 11:50:54 SPA112 daemon.err sendmail: SSL Helper exited (1) |
Aug 29 11:50:55 SPA112 daemon.err sendmail: SSL Helper exited (1) |
Aug 29 11:50:56 SPA112 user.notice msgswitchd: MSGSWITCH fd_rtp fifo created 7 |
Aug 29 11:50:56 SPA112 user.notice msgswitchd: MSGSWITCH fd_ch fifo created 9 |
Aug 29 11:50:56 SPA112 user.notice msgswitchd: MSGSWITCH fd_gmep fifo created 10 |
Aug 29 11:50:57 SPA112 daemon.err sendmail: SSL Helper exited (1) |
Aug 29 11:51:05 SPA112 daemon.err sendmail: SSL Helper exited (1) |
Aug 29 11:51:08 SPA112 kern.info [17179616.920000] device eth0 left promiscuous mode |
Aug 29 11:51:08 SPA112 kern.info [17179616.940000] br0: port 1(eth0) entering disabled state |
Aug 29 11:51:09 SPA112 kern.debug [17179617.328000] sysevt_comm_sendto: (52, rc)=> |
Aug 29 11:51:09 SPA112 daemon.info system[1]: vlan-module send out delete interface(br0, 0x8) notify...(0) |
Aug 29 11:51:09 SPA112 daemon.info system[1]: delete interface br0 with vid(0)... |
Aug 29 11:51:09 SPA112 kern.err [17179617.892000] br0: Dropping NETIF_F_UFO since no NETIF_F_HW_CSUM feature. |
Aug 29 11:51:11 SPA112 daemon.info system[1]: new create interface br0 with vid(0)... |
Aug 29 11:51:11 SPA112 daemon.err sendmail: SSL Helper exited (1) |
Aug 29 11:51:11 SPA112 kern.info [17179619.700000] device eth0 entered promiscuous mode |
Aug 29 11:51:11 SPA112 kern.info [17179619.708000] br0: port 1(eth0) entering learning state |
Aug 29 11:51:11 SPA112 kern.debug [17179619.720000] sysevt_comm_sendto: (52, rc)=> |
Aug 29 11:51:11 SPA112 daemon.info system[1]: vlan-module send out update interface(br0, 0xa) notify...(0) |
Aug 29 11:51:11 SPA112 daemon.err system[1]: notify add wan1 interface(br0) |
Aug 29 11:51:11 SPA112 kern.debug [17179619.744000] sysevt_comm_sendto: (52, rc)=> |
Aug 29 11:51:11 SPA112 daemon.info system[1]: vlan-module send out add interface(br0, 0x8) notify...(0) |
Aug 29 11:51:11 SPA112 daemon.err system[1]: start 0 vlan-id... ok |
Aug 29 11:51:12 SPA112 kern.debug [17179620.536000] sysevt_comm_sendto: (52, rc)=> |
Aug 29 11:51:12 SPA112 daemon.notice system[1]: Start WAN br0 Static IP connection |
Aug 29 11:51:12 SPA112 daemon.notice system[1]: WAN br0 connected |
Aug 29 11:51:12 SPA112 daemon.notice system[1]: Link name=br0 |
Aug 29 11:51:12 SPA112 daemon.notice system[1]: IP address=192.168.1.251 |
Aug 29 11:51:12 SPA112 daemon.notice system[1]: Netmask=255.255.255.0 |
Aug 29 11:51:12 SPA112 daemon.notice system[1]: Gateway=192.168.1.253 |
Aug 29 11:51:12 SPA112 daemon.notice system[1]: hostname= |
Aug 29 11:51:12 SPA112 kern.debug [17179620.640000] sysevt_comm_sendto: (16, rc)=> |
Aug 29 11:51:12 SPA112 daemon.notice system[1]: domain= |
Aug 29 11:51:12 SPA112 kern.debug [17179620.656000] sysevt_comm_sendto: (480, rc)=> |
Aug 29 11:51:12 SPA112 daemon.err sendmail: SSL Helper exited (1) |
Aug 29 11:51:12 SPA112 kern.debug [17179620.696000] sysevt_comm_sendto: (480, rc)=> |
Aug 29 11:51:12 SPA112 daemon.err dnsmasq[155]: failed to load names from /etc/hosts: No such file or directory |
Aug 29 11:51:12 SPA112 daemon.debug system[1]: leave reload_dnsmasq_conf_default |
Aug 29 11:51:13 SPA112 kern.debug [17179621.640000] sysevt_event_sendto: =>(0, B5817EF8, ledapp) |
Aug 29 11:51:13 SPA112 kern.debug [17179621.640000] sysevt_event_sendto: =>type = 1048663 |
Aug 29 11:51:13 SPA112 kern.debug [17179621.640000] sysevt_event_sendto: =>size = 0 |
Aug 29 11:51:13 SPA112 kern.debug [17179621.640000] sysevt_comm_sendto: (12, ledapp)=> |
Aug 29 11:51:13 SPA112 kern.info [17179621.712000] br0: topology change detected, propagating |
Aug 29 11:51:13 SPA112 kern.info [17179621.716000] br0: port 1(eth0) entering forwarding state |
Aug 29 12:37:25 SPA112 daemon.notice system[116]: NTP update successfully, Year:2018,Month:8,Day:29,Hour:12,Min:37,Sec:25 |
Aug 29 12:37:25 SPA112 syslog.notice syslog-ng[138]: STATS: dropped 0 |
Aug 29 13:37:25 SPA112 daemon.notice system[116]: Adjust daylight saving time: Year:2018,Month:8,Day:29,Hour:13,Min:37,Sec:25 |
Aug 29 13:37:25 SPA112 syslog.notice syslog-ng[138]: STATS: dropped 0 |
Aug 29 13:37:25 SPA112 user.notice vsock: gch_ListenStart: Started Read thread |
Aug 29 13:37:35 SPA112 daemon.err sendmail: timed out |
Aug 29 13:37:38 SPA112 user.notice sprvoip: cmd 5, EP 2, ParameterType 22, ParameterValue 0 |
Aug 29 13:37:38 SPA112 user.notice sprvoip: cmd - 5, response 8 |
Aug 29 13:37:38 SPA112 user.notice sprvoip: cmd 5, EP 2, ParameterType 27, ParameterValue 60 |
Aug 29 13:37:38 SPA112 user.notice sprvoip: cmd 5, EP 2, ParameterType 26, ParameterValue 70 |
Aug 29 13:37:38 SPA112 user.notice sprvoip: cmd 5, EP 1, ParameterType 22, ParameterValue 0 |
Aug 29 13:37:38 SPA112 user.notice sprvoip: cmd 5, EP 1, ParameterType 27, ParameterValue 60 |
Aug 29 13:37:38 SPA112 user.notice sprvoip: cmd 5, EP 1, ParameterType 26, ParameterValue 70 |
Aug 29 13:37:42 SPA112 user.notice sprvoip: cmd - 18, response 23 |
Aug 29 13:37:42 SPA112 user.notice sprvoip: cmd - 18, response 49 |
Aug 29 13:37:43 SPA112 user.notice sprvoip: cmd - 18, response 23 |
Aug 29 13:37:43 SPA112 user.notice sprvoip: cmd - 18, response 49 |
Thanks in advance,
Tobias
08-29-2018 06:03 AM
You disclosed log of device's kernel. It have rather low value here. You should disclose log (highest level) and debug messages of device's Voice Application.
This post contain information related to other's site thus it may contain information considered Sensitive or Confidential. |
08-29-2018 06:27 AM
Thanks for your reply.
Under the menu item "Administration", I can only activate logs for kernel or system.
Where is the Voice Log?
08-29-2018 07:16 AM
08-29-2018 07:37 AM
Is this the right log?
Datum,Zeit,Stufe,Hostname,Kategorie,Programm,Nachrichten, |
2018-08-29,16:35:29,Information,192.168.1.251,local0,, |
2018-08-29,16:35:29,Information,192.168.1.251,local0,,->192.168.1.209:5060(659) |
2018-08-29,16:35:29,Information,192.168.1.251,local0,T38,CED IND Enabled |
2018-08-29,16:35:29,Information,192.168.1.251,local0,T38,Remote IP 192.168.1.209 and port 7788 |
2018-08-29,16:35:29,Information,192.168.1.251,local0,SIP,Peer Request T38 |
2018-08-29,16:35:29,Information,192.168.1.251,local0,,<<192.168.1.209:5060(940) |
2018-08-29,16:35:29,Information,192.168.1.251,local0,,->192.168.1.209:5060(621) |
2018-08-29,16:35:29,Information,192.168.1.251,local0,uchConnectEpToNode(),Error Connecting EP VoIP 0 to Node 0. -93. |
2018-08-29,16:35:29,Information,192.168.1.251,local0,Already,has a RTP channel. |
2018-08-29,16:35:29,Information,192.168.1.251,local0,***,RTCP already running on channel 0. |
2018-08-29,16:35:29,Information,192.168.1.251,local0,,<<192.168.1.209:5060(792) |
2018-08-29,16:35:26,Information,192.168.1.251,local0,, |
2018-08-29,16:35:26,Information,192.168.1.251,local0,,<<192.168.1.209:5060(255) |
2018-08-29,16:35:26,Information,192.168.1.251,local0,,->192.168.1.209:5060(1144) |
2018-08-29,16:35:26,Information,192.168.1.251,local0,,->192.168.1.209:5060(395) |
2018-08-29,16:35:26,Information,192.168.1.251,local0,,<<192.168.1.209:5060(465) |
2018-08-29,16:35:26,Information,192.168.1.251,local0,,->192.168.1.209:5060(923) |
2018-08-29,16:35:23,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:35:23,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:35:23,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:34:17,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:34:17,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:34:17,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:33:36,Information,192.168.1.251,local0,, |
2018-08-29,16:33:36,Information,192.168.1.251,local0,,->192.168.1.209:5060(385) |
2018-08-29,16:33:36,Information,192.168.1.251,local0,,<<192.168.1.209:5060(417) |
2018-08-29,16:33:14,Information,192.168.1.251,local0,, |
2018-08-29,16:33:14,Information,192.168.1.251,local0,,<<192.168.1.209:5060(417) |
2018-08-29,16:33:14,Information,192.168.1.251,local0,,->192.168.1.209:5060(659) |
2018-08-29,16:33:14,Information,192.168.1.251,local0,T38,CED IND Enabled |
2018-08-29,16:33:14,Information,192.168.1.251,local0,T38,Remote IP 192.168.1.209 and port 7782 |
2018-08-29,16:33:14,Information,192.168.1.251,local0,SIP,Peer Request T38 |
2018-08-29,16:33:14,Information,192.168.1.251,local0,,<<192.168.1.209:5060(941) |
2018-08-29,16:33:14,Information,192.168.1.251,local0,cordless_enableFaxPassthroughWithCodec,*** rtp_sessions_update() ok: 0 |
2018-08-29,16:33:14,Information,192.168.1.251,local0,,->192.168.1.209:5060(621) |
2018-08-29,16:33:14,Information,192.168.1.251,local0,uchConnectEpToNode(),Error Connecting EP VoIP 0 to Node 0. -93. |
2018-08-29,16:33:14,Information,192.168.1.251,local0,Already,has a RTP channel. |
2018-08-29,16:33:14,Information,192.168.1.251,local0,***,RTCP already running on channel 0. |
2018-08-29,16:33:13,Information,192.168.1.251,local0,, |
2018-08-29,16:33:13,Information,192.168.1.251,local0,,<<192.168.1.209:5060(793) |
2018-08-29,16:33:11,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:33:11,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:33:11,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:33:11,Information,192.168.1.251,local0,, |
2018-08-29,16:33:11,Information,192.168.1.251,local0,,<<192.168.1.209:5060(255) |
2018-08-29,16:33:11,Information,192.168.1.251,local0,,->192.168.1.209:5060(1144) |
2018-08-29,16:33:11,Information,192.168.1.251,local0,,->192.168.1.209:5060(395) |
2018-08-29,16:33:11,Information,192.168.1.251,local0,,<<192.168.1.209:5060(465) |
2018-08-29,16:33:10,Information,192.168.1.251,local0,, |
2018-08-29,16:33:10,Information,192.168.1.251,local0,,->192.168.1.209:5060(923) |
2018-08-29,16:32:05,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:32:05,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:32:05,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:30:59,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:30:59,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:30:59,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:30:12,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:30:12,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:30:12,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:29:45,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:29:45,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:29:45,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:29:34,Information,192.168.1.251,local0,,Reg Addr Change(0) 0:0->d101a8c0:5060 |
2018-08-29,16:29:33,Information,192.168.1.251,local0,,WaitTime:80 |
2018-08-29,16:29:32,Information,192.168.1.251,local0,,WaitTime:40 |
2018-08-29,16:29:31,Information,192.168.1.251,local0,,WaitTime:20 |
2018-08-29,16:29:30,Information,192.168.1.251,local0,,WaitTime:10 |
2018-08-29,16:29:29,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:29:29,Information,192.168.1.251,local0, going,to sleep 12 csec |
2018-08-29,16:29:29,Information,192.168.1.251,local0,Boot,up random delay: |
2018-08-29,16:29:28,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:27:30,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:27:30,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:27:30,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:26:24,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:26:24,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:26:24,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:25:18,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:25:18,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:25:18,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:24:12,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:24:12,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:24:12,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:23:07,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:23:07,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:23:07,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:22:01,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:22:01,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:22:01,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:20:55,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:20:55,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:20:55,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:19:49,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:19:49,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:19:49,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:18:43,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:18:43,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:18:43,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:17:37,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:17:37,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:17:37,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:16:31,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:16:31,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:16:31,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:15:25,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:15:25,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:15:25,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:14:19,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:14:19,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:14:19,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:13:13,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:13:13,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:13:13,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:12:05,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:12:05,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:12:05,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:10:59,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:10:59,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:10:59,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:09:53,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:09:53,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:09:53,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:08:47,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:08:47,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:08:47,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:07:41,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:07:41,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:07:41,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:06:35,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:06:35,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:06:35,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:05:55,Information,192.168.1.251,local0,T38,CED IND Enabled |
2018-08-29,16:05:55,Information,192.168.1.251,local0,T38,Remote IP 192.168.1.209 and port 7722 |
2018-08-29,16:05:55,Information,192.168.1.251,local0,SIP,Peer Request T38 |
2018-08-29,16:05:55,Information,192.168.1.251,local0,uchConnectEpToNode(),Error Connecting EP VoIP 0 to Node 0. -93. |
2018-08-29,16:05:55,Information,192.168.1.251,local0,Already,has a RTP channel. |
2018-08-29,16:05:55,Information,192.168.1.251,local0,***,RTCP already running on channel 0. |
2018-08-29,16:05:29,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:05:29,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:05:29,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:04:41,Information,192.168.1.251,local0,T38,CED IND Enabled |
2018-08-29,16:04:40,Information,192.168.1.251,local0,T38,Remote IP 192.168.1.209 and port 7718 |
2018-08-29,16:04:40,Information,192.168.1.251,local0,SIP,Peer Request T38 |
2018-08-29,16:04:40,Information,192.168.1.251,local0,cordless_enableFaxPassthroughWithCodec,*** rtp_sessions_update() ok: 0 |
2018-08-29,16:04:40,Information,192.168.1.251,local0,uchConnectEpToNode(),Error Connecting EP VoIP 0 to Node 0. -93. |
2018-08-29,16:04:40,Information,192.168.1.251,local0,Already,has a RTP channel. |
2018-08-29,16:04:40,Information,192.168.1.251,local0,***,RTCP already running on channel 0. |
2018-08-29,16:04:23,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:04:23,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:04:23,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:03:17,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:03:17,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:03:17,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:02:11,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:02:11,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:02:11,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,16:01:05,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,16:01:05,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,16:01:05,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,15:59:59,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,15:59:59,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,15:59:59,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,15:58:53,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,15:58:53,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,15:58:53,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,15:57:47,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,15:57:47,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,15:57:47,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,15:56:41,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,15:56:41,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,15:56:41,Information,192.168.1.251,local0,++++,retry query scaps |
2018-08-29,15:55:34,Information,192.168.1.251,local0,+++,send scaps discovery query |
2018-08-29,15:55:34,Information,192.168.1.251,local0,+++,need tftp addr.. |
2018-08-29,15:55:34,Information,192.168.1.251,local0,++++,retry query scaps |
08-29-2018 12:38 PM
Yes, it's Voice Application log, but it looks incomplete. All messages have facility local0 and severity Information while full debug uses facilities local0,local1,local2,local3 and severity Debug (among others). Debug messages are important here.
OK, just blind shot for now. Can you
and try again ? If it will work with T.38 disabled/PCMA enabled, re-enable T.38 and capture a failing session - all SIP packets from INVITE onward, all RTP packet and all log&debug messages. Use Wireshark, tcpdump or so to capture them (ask local network administrator for help in doubt).
It may (but may not) help to analyze issue in full.
Note that full log as well as full packet capture contain no passwords, but may contain other sensitive information - like phone numbers, IP addresses and so on.
08-30-2018 02:24 AM - edited 08-30-2018 03:02 AM
If I set PCMA as the only Codec allowed, then i cant send a fax.
08-30-2018 02:55 AM
OK. We know the issue is related to the use of T.38 and we identified workaround - fax can be send via aLaw audio codec.
Now I need full packet capture of failing T.38 session - SIP packets starting at INVITE, RTP packets and even syslog/debug if possible. Saved in binary form by tcpdump, wireshark or so.
But one more blind shot - there has been firmware bugs related to T.38 and particular vendor/model end fax devices observer in the past. A suspect just another one. Note that firmware bugs can be reported to SMB support center only - even fully disclosed and analyzed bug posted here are ignored by Cisco.
By the way - despite you tried to remove called number from log, skilled eye can still read it.
