06-14-2018 03:40 PM - edited 03-21-2019 10:44 AM
I've just unboxed a new SPA 122 ATA, connected it to my network, I know what address it is on, I can ping the address, I cannot access the webserver.
I log into the IVR system and confirm both IP address and the port, I am accessing the correct IP address and it's on port 80, so no surprises there.
I've tried a factory reset, same deal.
It's like the webserver is just not coming up.
Solved! Go to Solution.
06-14-2018 06:39 PM
Not only you can't access server on WAN IP address. You even can't access on LAN IP address if browser's connection come from WAN side of unit.
Use LAN IP from browser connected to LAN side.
06-14-2018 05:59 PM
Your description of issue doesn't go beyond "I'm doing things the right way". In such case there's only conclusion possible - unit is faulty, apply for warranty.
Just for the case you are trying to access wrong IP or you are connected to WAN side of unit I would like to note the WWW server is accessible from LAN side (and IP address of LAN side) of SPA122 only.
06-14-2018 06:13 PM
06-14-2018 06:27 PM
Check device's sticker. What's the exact value of PID VID printed here ?
06-14-2018 06:35 PM
06-14-2018 06:39 PM
06-14-2018 06:42 PM
Yeah, exactly.
Direct connecting from computer to ethernet port is the ticket.
Thanks to all who replied.
06-16-2018 03:16 PM
BTW, you can connect to the WAN port of the SP122 after you change the default admin password.
06-17-2018 12:41 AM
True, but consider security before you will enable access to UI from WAN side.
