spa 122 inbound problem "Number called not in service
kejriwalr
Beginner
Beginner
Hello When i call my home # for first few tries i get number is not service  then call goes thru .is there is any setting in SPa 122
nseto
Frequent Contributor
Set up the debug log so you can see if the proxy is forwarding the call to the spa122.
Info on setting up debug log at https://supportforums.cisco.com/docs/DOC-9862
After setting this up, make a call and see if the call shows up in the log file.  If it doesn't, then you'll know that the proxy isn't forwarding the call to the unit.
You can also check if the unit is/isn't registered at the time of the call.  Check the info tab of the web UI.
