Hi all,
I need to be sure if *99 toggles all subsequent calls in modem pass-through or just the one that had *99 prefixed?
Some customers report echo and since this feature disable echo canceller, it might explains why.
Is there a way to know when an ATA is in modem pass-through?
Benoit
The modem toggle code affects only the call that had *99 prefix.
You can try to reduce echo using "echo options", impedance option and volume options.
Regards.
