08-15-2012 07:39 AM - edited 03-21-2019 09:50 AM
With firmware version 5.2.13 loaded on my SPA-3102, the 'ETSI FSK with PR (UK)' caller ID delivery mechanism to the FXS port isn't working properly -- rather than sending the polarity reversal and CLID spill before the first ring, instead it does the first cycle of ringing (BT cadence of .4 on, .2 off, .4 on, 2 off), then it sends the polarity reversal and CLID spill and continues ringing.
With firmware 5.1.10 and exactly the same configuration it delivered the polarity reversal and CLID spill, then ringing.
Is this something that's known about, and if so is there a plan to fix it in a subsequent firmware release?
Many thanks,
Martin
08-16-2012 10:25 AM
Please call our support team so a bug report can be filed.
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Thank you.
08-16-2012 10:29 AM
Will do - thank you!
All the best,
Martin
