Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
1802
[SPA-3102] Hang-up on DTMF * or # after reset
I'm using a SPA-3102 in France for 1 year now without problem.
Two days ago, I had to reset my device.
after reconfiguring  to connect to my PSTN and IPBX, I'm unable ti dial * or # on external line.
It works perfectly if I connect a phone to my PSTN line or in "Pass-Thru" mode (disconnected from network).
I'm using:
SPA-504G as IP Phone on 192.168.0.110 as extension 13
IPBX 3CX v11 SP4 on 192.168.0.11
SPA-3102 on 192.168.0.100 on extension 10000
here is verbose log:
18-févr.-2013 19:47:31.395 L:12.2[Line:10000>>]: Terminating targets, reason:
18-févr.-2013 19:47:31.395 Leg L:12.2[Line:10000>>] is terminated: Cause: BYE from PBX
18-févr.-2013 19:47:31.395 Terminated from <sip:192.168.0.100:5062>;tag=351a2381a1280ba8i1 to "Cisco"<sip:10000@192.168.0.11:5060>;tag=8e46f35b; reason: LocalBye
18-févr.-2013 19:47:31.395 L:12.2[Line:10000>>] Sending: OnSendReq Send Req BYE from 0.0.0.0:0 tid=aa0480600f1e8758 Call-ID=MDRlOGQ4ZTA3OGY0ZTFjZTFjZTUwODI5ZDI4NzhiNjc.:
   BYE sip:192.168.0.100:5062 SIP/2.0
   Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-aa0480600f1e8758-1---d8754z-;rport
   Max-Forwards: 70
   Contact: <sip:10000@192.168.0.11:5060>
   To: <sip:192.168.0.100:5062>;tag=351a2381a1280ba8i1
   From: "Cisco"<sip:10000@192.168.0.11:5060>;tag=8e46f35b
   Call-ID: MDRlOGQ4ZTA3OGY0ZTFjZTFjZTUwODI5ZDI4NzhiNjc.
   CSeq: 2 BYE
   Content-Length: 0
18-févr.-2013 19:47:31.395 SendMsg from "Cisco"<sip:10000@192.168.0.11:5060>;tag=8e46f35b to <sip:192.168.0.100:5062>;tag=351a2381a1280ba8i1
18-févr.-2013 19:47:31.395 [CM503008]: Call(C:12): Call is terminated
18-févr.-2013 19:47:31.395 L:12.2[Line:10000>>]: Terminating targets, reason: SIP ;cause=200 ;text="Call terminated on user request"
18-févr.-2013 19:47:31.395 Blocking refers for the Call(C:12)
18-févr.-2013 19:47:31.395 Call(C:12) is terminated
18-févr.-2013 19:47:31.393 L:12.1[Extn:13]: Terminating targets, reason: SIP ;cause=200 ;text="User hangup"
18-févr.-2013 19:47:31.393 Leg L:12.1[Extn:13] is terminated: Cause: BYE from 192.168.0.110:5060
18-févr.-2013 19:47:31.392 L:12.1[Extn:13] got Terminated Recv Req BYE from 192.168.0.110:5060 tid=-e5c805db
Call-ID=be749b69-2eec81f4@192.168.0.110
   BYE sip:0@192.168.0.11:5060 SIP/2.0
   Via: SIP/2.0/UDP 192.168.0.110:5060;branch=z9hG4bK-e5c805db
   Max-Forwards: 70
   To: <sip:0@192.168.0.11>;tag=761ddb1e
   From: "Cisco"<sip:13@192.168.0.11>;tag=c99154e566cb6a8o0
   Call-ID:
   CSeq: 103 BYE
   Proxy-Authorization: Digest username="13",realm="3CXPhoneSystem",nonce="414d535c0733083f10:cd88d67d450e5d2bdc8e808e3d4ab65d",uri="sip:0@192.168.0.11:5060",algorithm=MD5,response="a89e6bff521b982528349a8fe4688599"
   User-Agent: Cisco/SPA504G-7.4.9c
   Content-Length: 0
18-févr.-2013 19:47:31.392 Terminated from "Cisco"<sip:13@192.168.0.11>;tag=c99154e566cb6a8o0 to <sip:0@192.168.0.11>;tag=761ddb1e; reason: RemoteBye
18-févr.-2013 19:47:31.392 L:12.1[Extn:13] Sending: OnSendResp Send 200/BYE from 0.0.0.0:0 tid=-e5c805db
   SIP/2.0 200 OK
   Contact: <sip:0@192.168.0.11:5060>
   Call-ID:
   CSeq: 103 BYE
   Content-Length: 0
18-févr.-2013 19:47:31.392 SendMsg from <sip:0@192.168.0.11>;tag=761ddb1e to "Cisco"<sip:13@192.168.0.11>;tag=c99154e566cb6a8o0
18-févr.-2013 19:47:28.065 Session 9831 of leg L:12.1[Extn:13] is confirmed
18-févr.-2013 19:47:28.065 L:12.1[Extn:13] got Confirmed Recv Req ACK from 192.168.0.110:5060 tid=-915dd161
   ACK sip:0@192.168.0.11:5060 SIP/2.0
   Via: SIP/2.0/UDP 192.168.0.110:5060;branch=z9hG4bK-915dd161
   Max-Forwards: 70
   Contact: "Cisco"<sip:13@192.168.0.110:5060>
   Call-ID:
   CSeq: 102 ACK
   Proxy-Authorization: Digest username="13",realm="3CXPhoneSystem",nonce="414d535c0733083f10:cd88d67d450e5d2bdc8e808e3d4ab65d",uri="sip:0@192.168.0.11:5060",algorithm=MD5,response="df3e6f072d2eddf61b0c13bfa8346989"
   Content-Length: 0
18-févr.-2013 19:47:28.065 ConnCfmd from "Cisco"<sip:13@192.168.0.11>;tag=c99154e566cb6a8o0 to <sip:0@192.168.0.11>;tag=761ddb1e
18-févr.-2013 19:47:27.807 [CM503007]: Call(C:12): Line:10000>> has joined, contact <sip:10000@192.168.0.100:5062>
18-févr.-2013 19:47:27.807 [CM503007]: Call(C:12): Extn:13 has joined, contact <sip:13@192.168.0.110:5060>
18-févr.-2013 19:47:27.806 Session 9831 of leg L:12.1[Extn:13] is connected
18-févr.-2013 19:47:27.806 L:12.1[Extn:13] got Connected.UAS Send 200/INVITE from 0.0.0.0:0 tid=-d76bc23c
   SIP/2.0 200 OK
   Via: SIP/2.0/UDP 192.168.0.110:5060;branch=z9hG4bK-d76bc23c
   Call-ID:
   CSeq: 102 INVITE
   Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
   Content-Type: application/sdp
   Supported: replaces
   User-Agent: 3CXPhoneSystem 11.0.27588.780 (27565)
   Content-Length: 285
   v=0
   o=3cxPS 471607541760 150172860417 IN IP4 192.168.0.11
   s=3cxPS Audio call
   c=IN IP4 192.168.0.100
   t=0 0
   m=audio 16460 RTP/AVP 0 100 101
   a=rtpmap:0 PCMU/8000
   a=rtpmap:100 NSE/8000
   a=fmtp:100 192-193
   a=rtpmap:101 telephone-event/8000
   a=fmtp:101 0-15
   a=ptime:20
   a=sendrecv
18-févr.-2013 19:47:27.806 Connected(UAS) from "Cisco"<sip:13@192.168.0.11>;tag=c99154e566cb6a8o0 to <sip:0@192.168.0.11>;tag=761ddb1e
18-févr.-2013 19:47:27.806 L:12.1[Extn:13] Sending: OnSendResp Send 200/INVITE from 0.0.0.0:0 tid=-d76bc23c
   SIP/2.0 200 OK
   Call-ID:
   CSeq: 102 INVITE
   Supported: replaces
   Content-Length: 285
   v=0
   s=3cxPS Audio call
   t=0 0
   a=fmtp:100 192-193
   a=fmtp:101 0-15
   a=ptime:20
   a=sendrecv
18-févr.-2013 19:47:27.806 SendMsg from <sip:0@192.168.0.11>;tag=761ddb1e to "Cisco"<sip:13@192.168.0.11>;tag=c99154e566cb6a8o0
18-févr.-2013 19:47:27.806 ~Target=PSTNline:@(
Ln.10000@SPA3102
18-févr.-2013 19:47:27.806 L:12.1[Extn:13]: Terminating targets, reason: SIP ;cause=200 ;text="Call completed elsewhere"
18-févr.-2013 19:47:27.804 ~Route=Dev:sip:10000@192.168.0.100:5062
18-févr.-2013 19:47:27.804 L:12.2[Line:10000>>] has joined to L:12.1[Extn:13]
18-févr.-2013 19:47:27.804 Session 9834 of leg L:12.2[Line:10000>>] is connected
18-févr.-2013 19:47:27.804 L:12.2[Line:10000>>] got Connected.UAC Recv 200/INVITE from 192.168.0.100:5062 tid=1a7c7e0c7a2a6a10 Call-ID=MDRlOGQ4ZTA3OGY0ZTFjZTFjZTUwODI5ZDI4NzhiNjc.:
   SIP/2.0 200 OK
   Via: SIP/2.0/UDP 192.168.0.11:5060;branch=z9hG4bK-d8754z-1a7c7e0c7a2a6a10-1---d8754z-
   Contact: "SPA-3102"<sip:192.168.0.100:5062>
   CSeq: 1 INVITE
   Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
   Server: Linksys/SPA3102-5.2.13(GW002)
   Supported: x-sipura, replaces
   Content-Length: 259
   Remote-Party-ID: SPA-3102 <sip:10000@192.168.0.11>;screen=yes;party=called
   v=0
   o=- 11996854 11996854 IN IP4 192.168.0.100
   s=-
   t=0 0
   a=fmtp:100 192-193
   a=fmtp:101 0-15
   a=ptime:20
   a=sendrecv
18-févr.-2013 19:47:27.804 Connected(UAC) from <sip:192.168.0.100:5062>;tag=351a2381a1280ba8i1 to "Cisco"<sip:10000@192.168.0.11:5060>;tag=8e46f35b
18-févr.-2013 19:47:27.804 Remote SDP is set for leg L:12.2[Line:10000>>]
18-févr.-2013 19:47:27.804 Answer SDP arrived on Leg L:12.2[Line:10000>>];
OnAnswer Recv 200/INVITE from 192.168.0.100:5062 tid=1a7c7e0c7a2a6a10 Call-ID=MDRlOGQ4ZTA3OGY0ZTFjZTFjZTUwODI5ZDI4NzhiNjc.:
   SIP/2.0 200 OK
   CSeq: 1 INVITE
   Content-Length: 259
   v=0
   s=-
   t=0 0
   a=fmtp:100 192-193
   a=fmtp:101 0-15
   a=ptime:20
   a=sendrecv
18-févr.-2013 19:47:27.804 [CM505002]: Gateway:[SPA3102] Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3102-5.2.13(GW002)] PBX contact: [sip:10000@192.168.0.11:5060]
18-févr.-2013 19:47:27.804 [CM503002]: Call(C:12): Alerting Line:10000>> by contact <sip:10000@192.168.0.100:5062>
18-févr.-2013 19:47:27.804 UacSession 9834 has formed leg L:12.2[Line:10000>>]
18-févr.-2013 19:47:27.804 Answer from <sip:192.168.0.100:5062>;tag=351a2381a1280ba8i1 to "Cisco"<sip:10000@192.168.0.11:5060>;tag=8e46f35b
18-févr.-2013 19:47:27.804 L:12.2[Line:10000>>] Sending: OnSendReq Send Req ACK from 0.0.0.0:0 tid=582afb151d5ad31c Call-ID=MDRlOGQ4ZTA3OGY0ZTFjZTFjZTUwODI5ZDI4NzhiNjc.:
   ACK sip:192.168.0.100:5062 SIP/2.0
   Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-582afb151d5ad31c-1---d8754z-;rport
   Max-Forwards: 70
   CSeq: 1 ACK
   Content-Length: 0
18-févr.-2013 19:47:27.804 SendMsg from "Cisco"<sip:10000@192.168.0.11:5060>;tag=8e46f35b to <sip:192.168.0.100:5062>;tag=351a2381a1280ba8i1
18-févr.-2013 19:47:27.734 [CM503025]: Call(C:12): Calling T:Line:10000>>@[Dev:sip:10000@192.168.0.100:5062] for L:12.1[Extn:13]
18-févr.-2013 19:47:27.734 Route to L:12.2[Line:10000>>] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=d52c143c0665864c Call-ID=MDRlOGQ4ZTA3OGY0ZTFjZTFjZTUwODI5ZDI4NzhiNjc.:
   INVITE sip:192.168.0.100:5062 SIP/2.0
   Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-d52c143c0665864c-1---d8754z-;rport
   Max-Forwards: 70
   CSeq: 1 INVITE
   Supported: replaces
   Content-Length: 427
   v=0
   o=3cxPS 150944612352 492713279489 IN IP4 192.168.0.11
   s=3cxPS Audio call
   c=IN IP4 192.168.0.110
   t=0 0
   m=audio 16472 RTP/AVP 0 8 9 2 18 96 97 98 101
   a=rtpmap:8 PCMA/8000
   a=rtpmap:9 G722/8000
   a=rtpmap:2 G726-32/8000
   a=rtpmap:18 G729a/8000
   a=rtpmap:96 G726-40/8000
   a=rtpmap:97 G726-24/8000
   a=rtpmap:98 G726-16/8000
   a=fmtp:101 0-15
   a=ptime:20
   a=sendrecv
18-févr.-2013 19:47:27.730 Outbound URI is used: sip:10000@192.168.0.100:5062
18-févr.-2013 19:47:27.729 Added leg L:12.2[Line:10000>>]
18-févr.-2013 19:47:27.713 Currently active calls - 1: [12]
18-févr.-2013 19:47:27.686 [Flow] Call(C:12): making call from L:12.1[Extn:13] to T:Line:10000>>@[Dev:sip:10000@192.168.0.100:5062]
18-févr.-2013 19:47:27.686 [CM503027]: Call(C:12): From: Extn:13 ("Cisco" <sip:13@192.168.0.11:5060>)  to  T:Line:10000>>@[Dev:sip:10000@192.168.0.100:5062]
18-févr.-2013 19:47:27.686 [CM503004]: Call(C:12): Route 1: from L:12.1[Extn:13] to T:Line:10000>>@[Dev:sip:10000@192.168.0.100:5062]
18-févr.-2013 19:47:27.686 Line limit check: Current # of calls for line Lc:10000(@SPA3102[<sip:10000@192.168.0.100:5062>]) is 0; limit is 1
18-févr.-2013 19:47:27.686 Call(C:12): Call from Extn:13 to 0 matches outbound rule 'Exterieur'
18-févr.-2013 19:47:27.686 [Flow] Call(C:12): has built target endpoint: Out#:>>Rule{Exterieur}>>0 for call from L:12.1[Extn:13]
18-févr.-2013 19:47:27.686 [Flow] Target endpoint for 0 is Out#:>>Rule{Exterieur}>>0
18-févr.-2013 19:47:27.686 Selected prefix: 0
18-févr.-2013 19:47:27.686 Looking for outbound rule: dialed = [0], processed: [0]; from-ext:
18-févr.-2013 19:47:27.686 [Flow] Building target endpoint to 0 from "Cisco" <sip:13@192.168.0.11:5060>
18-févr.-2013 19:47:27.686 [CM503010]: Call(C:12): Making route(s) from Extn:13 to <sip:0@192.168.0.11:5060>
18-févr.-2013 19:47:27.686 Remote SDP is set for leg L:12.1[Extn:13]
18-févr.-2013 19:47:27.686 OnOffer from "Cisco"<sip:13@192.168.0.11>;tag=c99154e566cb6a8o0
18-févr.-2013 19:47:27.686 [CM505001]: Endpoint Extn:13: Device info: Device Identified: [Man: Cisco;Mod: SPA Series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [Cisco/SPA504G-7.4.9c] PBX contact: [sip:13@192.168.0.11:5060]
18-févr.-2013 19:47:27.686 Inbound DID: ''; Phonebook Name: ''
18-févr.-2013 19:47:27.686 [CM500002]: Call(C:12): Info on incoming INVITE from Extn:13:
   Invite-IN Recv Req INVITE from 192.168.0.110:5060 tid=-d76bc23c
   INVITE sip:0@192.168.0.11:5060 SIP/2.0
   Max-Forwards: 70
   Call-ID:
   CSeq: 102 INVITE
   Expires: 240
   Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER, UPDATE
   Supported: replaces
   Content-Length: 401
   v=0
   o=- 15326154 15326154 IN IP4 192.168.0.110
   s=-
   t=0 0
   a=fmtp:101 0-15
   a=ptime:20
   a=sendrecv
18-févr.-2013 19:47:27.686 [CM503001]: Call(C:12): Incoming call from Extn:13 to <sip:0@192.168.0.11:5060>
18-févr.-2013 19:47:27.680 Outbound URI is used: sip:13@192.168.0.110:5060
18-févr.-2013 19:47:27.679 IncomingCall: C:12 from <sip:13@192.168.0.11:5060> to <sip:0@192.168.0.11:5060>
18-févr.-2013 19:47:27.679 Added leg L:C:12.1[No endpoint yet]
18-févr.-2013 19:47:27.679 UasSession 9831 started
18-févr.-2013 19:47:27.679 Call from "Cisco"<sip:13@192.168.0.11>;tag=c99154e566cb6a8o0 to <sip:0@192.168.0.11>;tag=761ddb1e 18-févr.-2013 19:47:31.395 L:12.2[Line:10000>>]: Terminating targets, reason:
   Max-Forwards: 70
   CSeq: 2 BYE
   Content-Length: 0
18-févr.-2013 19:47:31.392 L:12.1[Extn:13] got Terminated Recv Req BYE from 192.168.0.110:5060 tid=-e5c805db Call-ID=be749b69-2eec81f4@192.168.0.110:
   Max-Forwards: 70
   Call-ID: be749b69-2eec81f4@192.168.0.110
   CSeq: 103 BYE
   Content-Length: 0
18-févr.-2013 19:47:31.392 L:12.1[Extn:13] Sending: OnSendResp Send 200/BYE from 0.0.0.0:0 tid=-e5c805db Call-ID=be749b69-2eec81f4@192.168.0.110:
   SIP/2.0 200 OK
   CSeq: 103 BYE
   Content-Length: 0
18-févr.-2013 19:47:28.065 L:12.1[Extn:13] got Confirmed Recv Req ACK from 192.168.0.110:5060 tid=-915dd161 Call-ID=be749b69-2eec81f4@192.168.0.110:
   Max-Forwards: 70
   CSeq: 102 ACK
   Content-Length: 0
18-févr.-2013 19:47:27.806 L:12.1[Extn:13] got Connected.UAS Send 200/INVITE from 0.0.0.0:0 tid=-d76bc23c Call-ID=be749b69-2eec81f4@192.168.0.110:
   SIP/2.0 200 OK
   CSeq: 102 INVITE
   Supported: replaces
   Content-Length: 285
   v=0
   s=3cxPS Audio call
   t=0 0
   a=fmtp:100 192-193
   a=fmtp:101 0-15
   a=ptime:20
   a=sendrecv
18-févr.-2013 19:47:27.806 L:12.1[Extn:13] Sending: OnSendResp Send 200/INVITE from 0.0.0.0:0 tid=-d76bc23c Call-ID=be749b69-2eec81f4@192.168.0.110:
   SIP/2.0 200 OK
   CSeq: 102 INVITE
   Supported: replaces
   Content-Length: 285
   v=0
   s=3cxPS Audio call
   t=0 0
   a=fmtp:100 192-193
   a=fmtp:101 0-15
   a=ptime:20
   a=sendrecv
18-févr.-2013 19:47:27.806 ~Target=PSTNline:@(Ln.10000@SPA3102)
   SIP/2.0 200 OK
   CSeq: 1 INVITE
   Content-Length: 259
   v=0
   s=-
   t=0 0
   a=fmtp:100 192-193
   a=fmtp:101 0-15
   a=ptime:20
   a=sendrecv
   SIP/2.0 200 OK
   CSeq: 1 INVITE
   Content-Length: 259
   v=0
   s=-
   t=0 0
   a=fmtp:100 192-193
   a=fmtp:101 0-15
   a=ptime:20
   a=sendrecv
   Max-Forwards: 70
   CSeq: 1 ACK
   Content-Length: 0
   Max-Forwards: 70
   CSeq: 1 INVITE
   Supported: replaces
   Content-Length: 427
   v=0
   s=3cxPS Audio call
   t=0 0
   a=fmtp:101 0-15
   a=ptime:20
   a=sendrecv
   Invite-IN Recv Req INVITE from 192.168.0.110:5060 tid=-d76bc23c Call-ID=be749b69-2eec81f4@192.168.0.110:
   Max-Forwards: 70
   CSeq: 102 INVITE
   Expires: 240
   Supported: replaces
   Content-Length: 401
   v=0
   s=-
   t=0 0
   a=fmtp:101 0-15
   a=ptime:20
   a=sendrecv
anyone got an idea?
Thanks in advance
0 REPLIES 0
