SPA 3102 Provisioning HTTP with encryption
ross-parkinson
When I use the recomended procedure in the provisioning documentation
profile.xml
<flat-profile>
<GPP_A> 123456
</GPP_A>
</flat-profile>
openssl enc –e –aes-256-cbc –k SecretPhrase1234 –in profile.xml –out profile.cfg
and I and add the relevant key to my profile rule;
[--key "SecretPhrase1234"] http://10.1.1.10/$MA/profile.cfg
loggs say that profile resync successfull but after a refresh of browser on the spa the new profile has not taken and GPP_A is blank.
I have used the same profile in plain all ok
http://10.1.1.10/$MA/profile.cfg   # works great
I have used the same profile in with gzip all ok
cat profile.xml | gzip > profile.cfg
I have tried changing the key and resync fails, I have tried it without "" in the key resync sucessfull problem still exisit
I have tried decrypting the file using openssl enc and I get the original file back.
It has been driving me spare... cisco can you help
Alberto Montilla
Dear Sir;
Can you send us the debug information that SPA3102 is generating? This should work properly.
Could you also indicate us the firmware version you are using?
Alberto
Hi Alberto
Attached are the logs as requested see brief description of each file
1. web server access log.
2. Syslog 0 and syslog 3.
3. spa file plain
4. same file gz
5. same file with gz then encyption
key is as per my original post.
The SW is version is 5.1.10
Dear Sir;
Can you please send me the html configuration of the device (in admin advanced mode). I see the unit is downloading the file correctly so not sure of what the issue is.
One thing I have see is that you are using a different header on the XML file (compared to what the xml template is for the SPA3102). I suggest you take the complete header of the file included in the SPC for the product and try again...not sure It is the issue but think it will be easy to test.
Alberto
