02-14-2011 06:28 AM - edited 03-21-2019 09:33 AM
Good morning to everyone,
i write from italy and i have a problem by two weeks. I have bought 2 spa 3102 linksys to make a point to point system. My first 3102 (192.168.0.1) is linked to pstn and then , when the line is voip,it gives the line to the other 3102 (192.168.0.2) whitch is linked by ethernet,or wifi. Now, at my ..0.2 is linked the analogic phone. I have made all the configuration, i am able to make and receive calls without any problem. But when i receive calls, and it has closed by me , the caller remains connected to the line, hearing my telephone speaker, despite my phone is hooked.If i put up the receiver, the caller can still hear me. I have made upgrade to 5.1.10 (GW) firmware,but i have read that it has some bugs around disconnect tones. I have attached my personal configuration of two spa-3102. I hope you will be able to help me. Sorry for my bad english. If you need other informations about my spa 3102 configuration,please contact me.
Have a nice day.
Vittorio
02-15-2011 09:42 PM
You may be cabling the adapters using the "ethernet" jack instead of the "internet" jack. If so, I think it will work better if you use an external router and cable the SPA3102's "internet" attachment to the router.
If possible I would also setup the router with a different local subnet than 192.168.0.xxx just to avoid any confusion in the SPA3102 between the internet port and its default local subnet in the built-in SPA3102 router. For instance, 192.168.1.xxx would be better.
In each SPA3102 you have the same sip port number setup on Line 1 Tab and the PSTN Line Tab. I would setup different sip port numbers for each tab. You can use any numbers you wish, but adjust your dial plans accordingly.
12-02-2012 07:31 AM
