SPA 8000 Connection with IP PBX
mshamsheer1
I have SPA 8000 8 Port Analog Telephone Adapter , i want connect this with IP PBX and use Analog telephone in my home (Assign extension number for each room)
Can you please explain to me how to configure and get extension number from IP PBX to ATA adaptor
Thanks in advance
Shamsheer
Dan Miley
Level 3
Level 3
There are multiple ways to configure this device but the most simple requires 3 items, proxy, username and password for each line.
choose admin--> advanced --> voice --> line1
go to Proxy and Registration, enter the IP address or name of your IP pbx
go to subscriber info  and enter the username (usually the extension) and password.
Once you have tested one line this way, you can change other parms as needed (display name to change the caller ID for instance)
repeat for line2, 3, etc.  giving each one a separate extension on your pbx.
the configuration guide is here
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/csbpvga/ata/administration/guide/ATA_AG_v3_NC-WEB.pdf
Flag helpful posts, Please.
Dan
