I have a single line analog phone connected to Phone Port 1 of SPA2012 with firmware 5.2.13. I have 2 voip services configured, Callcentric on line 1 and LocalPhone on line 2. Questions:
1. Is there a way to dial out using service configured on line 2 with a single line analog phone physically connected to Phone Port 1. Any code like Obi110 has **2? Can dial plan be set to do this via ip dialling? if yes can someone provide some config help and dialplan help for the same?
2. I read the below(https://communities.cisco.com/message/11826#11826). Can someone tell me how that works as it is not working in my case. Any special setting?
"Line1 / Line2 => Phone Port Line 1" is a feature of SPA2102.
For my experience the first case is not possible with SPA2102.
The second is possible with 4 wire cable (2 couple).
Regards.
So for second if I use a 4 wire 2 couple cable/jack, incoming will be resolved agreed. Challenge is which line will dial out if I dial out and how do I control that dialout only happens with one line and not both simultaneously
