Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
Get the latest news in this issue of the Cisco Small Business Monthly Newsletter
1567
Highlighted
Advocate
Re: SPA112 can not restore konfiguration on firmware 1.4.1 SR3
Sorry, spacfg.xml is name for SPA3xx/SPA5xx devices. For SPA1xx/SPA2xx the config.xml needs to be used instead.
See SPA ATA: Saving Configuration for Analysis Using admin/config.xml for details.
I prefer XML form of configuration because
1. configuration saved by Save function is in proprietary binary format. You can do nothing with it but load - and even this may not work.
2. XML can be generated by a custom tool or edited in plain text editor
I will not claim it "good practice" - I just consider it better.
why do you advise not using SPC to convert an existing .cfg file to xml
Note that cfg produced by "Save" is not the same as text cfg suitable to be used by SPC. Those are completely different beasts. The first one is proprietary binary blob, the second is text file (but different format than XML). It's why you can't compile saved CFG by SPC.
I'm unsure the SPC can convert CFG (text CFG created for SPC, not the [Save]d one) to XML. I'm not using SPC at all, so I don't know what features has been added into it in the mean time.
But even if it can convert, I have no reason to do it. Plain text CFG for SPC and XML are bot text files. Both are readable by naked eye, both can be edited by text editor or generated by simple custom tool. But text CFG for SPC needs to be compiled while plain text XML can be used as is. The first one require external binary program, while the second method require nothing.
May be better question is - why I should use SPC for anything ...
Highlighted
Beginner
Ahh, <IPaddress/admin/config.xml> works fine, though how to access it without using the http://userid:password@... syntax (which leaves the admin credentials lying around in browser history and doesn't work anyway) isn't immediately obvious.
An attempt to use SPC to compile an existing, working XML configuration, just out of curiosity, resulted in 28 “unrecognised parameter names”.
I'll probably maintain the XML configuration now as you suggest.  It isn't as user-friendly as the interactive utility, but it does allow the differences between two files to be spotted easily using a text-compare utility.  Maybe an associated style would help?
Thanks for your assistance.
Highlighted
Advocate
attempt to use SPC to compile ... resulted in 28 “unrecognised parameter names”.
Did you downloaded the latest SPC compiler (just blind shot, I'm not using SPC) ?
It works for me, but it may be matter of browser used. Also, my browser doesn't save passwords in history. Moreover, it's one-time step. Once configuration gets saved, you need no to access the URL again. But it's not main security issue you have.
SPAxxx devices are NOT designed to be exposed in unfriendly environment. They lacks countermeasures against DoS, brutal-force style of password guessing and there in the past severe security bugs has been discovered including those allowing unauthorized access to the device. So you are in risk of tool fraud and it may be costly experience.
You should keep phone network separated from regular network, so regular users have no access to SPAxxx devices at all. Of course, overall security design of your network depends on local conditions, risks you wish to avoid and - of course - budget and skills you have ...
We have phone network in separate LAN with no connection outside, so no one can arrange DoS against them nor misuse a firmware vulnerability. Devices can speak with local PBX only (just free Asterisk) and PBX can access outside. Configuration are loaded from server via HTTPS protocol, SPAxxx authorizes self to server by in-device embedded certificate - so even if someone connects computer to phone network, he have no chance to fetch configuration of a phone (e.g. passwords stored in configuration can't be compromised) - it in turn mean he can't connect to PBX, so he can't make unauthorized calls (and possible tool fraud).
Highlighted
Beginner
I believe this issue persists with the recent November 1.4.1 SR5 release, I tried to restore my SPA112_1.3.5.cfg file & it returns the same "Restore Failed" error, seems strange that they chose not to rectify it after it's been a well documented bug since the April 2019 release of 1.4.1 SR3.
Highlighted
Advocate
You can restore backup from same version only. If it doesn't work, then bug is still here.
Don't restore backup created with different firmware version. It's not bug if it fails.
Highlighted
Beginner
I didn't realise that, thanks for letting me know, I saved a backup file with the new SR5 release and tried to restore it but the issue is still present & returns a "Restore failed" error, it's a shame they couldn't manage the time to rectify it as I guess it isn't a priority but I believe Cisco support are aware of it, is there a way to notify them that this bug is still not fixed?
Highlighted
Advocate
While you may wait for Cisco, my experience claim it so risky. Don't depend on backup/restore feature. Learn how provision phone from XML configuration file. Such file allows you to restore phone configuration from file anytime, even on different firmware version (and with some restrictions, even on different model).
Highlighted
Beginner
I'll support that.  The differences between two XML configurations can also be instantly identified using an appropriate utility (even Windows-7 has a rather basic CLI command for differencing text files).
However it took me a while to discover a process which works; one of the options in the book didn't work for me.  You'll need to install the 'curl' utility on the system used to download an existing XML configuration or upload a new one; curl is standard on Linux and there's a version for Windows.
More details are available if you need help...
Highlighted
Advocate
You have configuration in the file already. You provisioned phone from such file.
What's the reason to fetch it ? Assuming you didn't deleted the file by accident (but you have backup of all of important files, isn't it ?)
or upload a new one
Phone download's file from a server. What's the role of curl here ?
Highlighted
Beginner
You have configuration in the file already. You provisioned phone from such file.  What's the reason to fetch it?  Phone download's file from a server. What's the role of curl here ?
Oniiz86 had a problem uploading the binary version (.cfg) of a configuration file.  The provisioning system is designed for environments containing many ATAs, and I think it's inappropriate for users who may only have one or two devices.
However page-36 of the Provisioning Guide mentions the use of curl under "Direct HTTP Post using cURL" and it's a much better solution for those maintaining only one or a few devices.
DavidL
Highlighted
Advocate
I strongly disagree with "much" word you used and even without it I have different opinion. Despite of it, you described plausible method which may help and I missed it.  Thanks.
I'm not using it because I consider it "unstable". It works for some combinations of SPA models and firmware versions while it doesn't works for others. Also, it's subject of another pending firmware bug CSCud52670
Highlighted
Beginner
Thanks...
I've used the curl method using both Windows and Linux and with all (SR1,SR3,SR4,SR5) versions of SPA1x2 firmware and so far, so good.
Oniiz86 is beginning with a .cfg configuration file.  Its XML version can be downloaded by (1) logging into the admin account of an SPA device and then (2) executing the curl command:
http://<SPA-IP-addr>/admin/config.xml
before the browser session times out.  curl uses HTTP so it just "looks like" another browser command.  Files can be uploaded with:
curl  -d  @/<path>config.xml  "http://<SPA-IP-addr>/admin/config.xml"
Completely replacing the old binary configuration-file system with XML seems pretty straightforward from this distance, after all most of the firmware is already in place.
David L.
Highlighted
Advocate
@Oniiz86 is beginning with a .cfg configuration file.  Its XML version can be downloaded
Just for completeness, it should be noted the config.xml is not full backup (and XML equivalent of .cfg file). Passwords are not disclosed by phone this way. Passwords needs to be re-entered into file before it can be used as "backup" e.g. pushed back into virgin phone.
