Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
115
Beginner
SPA112 lock outgoing calls with pin code
Hi everybody,
our small non-profit organization had to migrate to a IP-phone network but we had to keep compatibility with some equipment which only handle analog line phone.
That's why we chose SPA112 to keep analog line phones. Also we had to change our network switch, now we're running a CISCO 3560 24 ports Gigabit PoE
Here's the issue : with our old analog phone network, we were able to lock outgoing calls on some endpoint phones with a pin code.
My question is : is it possible to do the same with SPA112 ?
You have to know that our small phone/internet network is provided by a larger "master" network which we do not manage. But we're constantly in touch with the network administrator.
Thanks a lot.
Max
Everyone's tags (4)
2 REPLIES 2
Engager
Re: SPA112 lock outgoing calls with pin code
The SPA112 is just bridge between analog line and SIP/IP phone network. Count  analog phone+SPA112  as single IP phone.
On the phone system you are leaving, the PIN code feature has been provided by PBX, not by end phone. Even on IP phone network the feature is not provided by end phone (analog phone+SPA112 bundle) - it's still feature of PBX.
Yo should ask someone familiar with PBX/softswitch you are going to use.
Beginner
Hello @Dan Lukes
Thank you for your answer, i will ask someone who has access to the pbx/softswitch.
Best regards.
