What firmware version are you using on your SPA112 ? If it is the latest version v1.1.0 then log in to the web configuration utility and navigate to Netwrok Setup > Time Settings. NTP server settings should be there. Let me know if you need help.
Also if you need help with time settings or NTP Server. Here is an article that will be very helpful.
