SPA112 Scripted Reboot
mozambeak
Beginner
Beginner
Does anyone know a command line script that can periodically soft reboot the SPA112?
Firmware 1.2.1 still hasn't fixed the uptime issues and the unit reguarly locks up after 2-3 days with no dial tones and response to web admin requests.
You then need to hard reset the unit by pulling the power cable and replugging again.
Tried using the following command:
http://spa112ip/reboot&xuser=username&xpassword=password
but receive a "405 Method Not Allowed!" error.
Tried using Curl but there are ASP session ID's for the login and Javscript prompts when hitting the Reboot page directly:
http://spa112ip/Reboot.asp
7 Replies 7
nseto
Frequent Contributor
Since you are having regular lock ups, can you send a debug log of this?  I'd like to get a developer to take a look at the log to see what's happening.
Logging details at https://supportforums.cisco.com/docs/DOC-9862
Sage Major
Beginner
Beginner
We started having this issue as soon as we started using 1.2.1  We had about 20 with this problem in the field out of 20
I have reverted back to 1.1.0
nseto
Can you get a log of this?  We need to get at the bottom of this problem.  Thanks.
I like my customers too much to run known buggy code.  I will try in my lab but I have not seen this issue.  I only see the devices unregistered and when I plugged in a phone they re register
Sage Major
Beginner
Beginner
I just noticed.  You need admin before reboot so
Http://(ip)/admin/reboot
Also you can try wget
elight942
Beginner
Beginner
I've tried evrything in this thread with no luck.
Sending SIP NOTIFY "reboot" and "restart" commands seems to work, but device hangs up anyway.
The only working method I found is sending command via web interface. You can script this via Perl (see attachment).
This appears to be related to https://supportforums.cisco.com/message/3779434#3779434
Patrick
Recognize Your Peers
