SPA112 - shcedule rebooting
Hi, I have the SPA112 for a wile, and I put the latest firmware update.
Unfortunately some time the spa not work,  I missing a call.  the spa not ring my phone, but other device (spa 924) continue to work with my ring group.  After I reboot spa112 the adapter work perfectly.
if is possible to add on the new firmware, a reboot schedule, per week or per month.
I think this feature will emprove this adapter.
Dan Lukes
Periodic reboot can be triggered externally, so you can implement the feature by self. Moreover, reboot can be triggered by periodic internal provisioning.
But I'm almost sure you need no reboots at all. Reboot cures the symptoms, not the cause.  There's a NAT or configuration bug that causes your issue. Once tuned properly according your network environment, reboot will be necessary no more.
