SPA122 Log Module Recommended Settings
George Spanos
I am sending logs to my syslog server from my SPA122 but also want to be able to view them on the device in the case that there's a device issue and it can't send out to the syslog server. If I were to log kernel & system in the "Log Module," what's a safe debug level to use if i were to keep this on constantly? Considering there's no way to check CPU utilization I'm looking for the option that uses the least about of CPU so it doesn't impact calls.
zimtiaz
George,
Please use this article that eexplains about Log module settings and how to setup the syslog server. Let me know if you need anything else.
http://www6.nohold.net/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=2716
Zubair
