03-25-2021 05:12 PM
Hey there,
I can't access the web interface of my ATA with Router. I even fixed a Static DHCP on it's default ip address. Please help me!
Solved! Go to Solution.
03-28-2021 02:07 PM
Did you read Administrators guide ?
There are two methods possible:
1. The Built-in IVR System
The complete IVR initiated reboot sequence will take a full 150 seconds, or 2.5 minutes to complete.
This IVR restore method is a full restore. In other words, it restores both Network and Voice settings.
Note: It is possible to Password Protect access to the SPA122 IVR system. If protected and you know no password, you can't initiate reset this way.
2. The Rear-Panel Reset Button
When the power LED stops blinking (after ~ 150 seconds, or 2.5 minutes has elapsed), you should be able to log back into the SPA112, if desired.
NOTE: The rear-panel RESET button (Factory Restore feature) can be disabled. In such case it's not possible to initiate reset this way.
03-25-2021 06:28 PM - edited 03-25-2021 06:29 PM
You may need to factory reset the device.
Are you able to ping it's IP?
03-26-2021 11:35 AM
Hi rais,
I use Advanced IP Scanner to map my ip network and now even if I think I linked the SPA122 with it's default ip address, the Advanced IP Scanner software say the ip address of the SPA122 is something else. Anyways I can't acces the web interface. I pushed the reset button for about 30 seconds, is it enough to factory reset the device?
PS : I can't see in the manual how to factory reset.
03-28-2021 02:07 PM
04-13-2021 05:22 AM - edited 04-13-2021 05:40 AM
Hi there,
I have a Cisco Router, a Cisco Switch and even if I plugged the Ethernet and Internet ports of the SPA122 into the Switch I can't access the web interface. I still can't access the web interface even if I restart to the factory settings. I can access it when I plugged the SPA122 on my PC, but I wonder how to access the web interface from my network, from my Cisco Switch. Thank you
04-13-2021 12:02 PM
New issue, new thread, please. As you are claiming networking issue, you should describe your network configuration - e.g. network configuration of both parties (the SPA122 and the client you wish to access WWW UI from).
